Neopixel Software Problems
by cry1123 on Fri Jul 31, 2020 1:05 am
I've been having difficulty installing the software for driving Neopixels. I worked through the guide and had no luck. I kept running into error messages concerning Blinka. Finally, I read a response by MakerMelissa who prompted another person to use:
pip install <package name> rather than sudo pip install <package name>
This seemed to work as the Blinka errors went away and the installs finished.
I ran:
sudo python neopixel_rpi_simpletest.py
to check the installations and it failed. The Import statements for Board and Neopixel both failed (I changed the order as a check) with the messages:
ImportError: No module named board and ImportError: No module named neopixel
My system: Raspberry Pi 3B running the latest Raspberry Pi OS with Python 3.7.3.
I searched the file system and found the downloaded files in directory:
/home/pi/.local/lib/python3.7/site-packages
Any help you can offer would be appreciated.
cry1123
Re: Neopixel Software Problems
by dastels on Fri Jul 31, 2020 10:58 am
Try running without sudo. Your user and root are different environments and may be (probably) looking in different places for the modules.
dastels
by cry1123 on Fri Jul 31, 2020 12:46 pm
Dave: I tried running without sudo before I posted. Besides some error messages, the final message was that I have to run with sudo (paraphrasing here)'
cry1123
