I got it working (at least the basics)....
Here's what I did with the capacitive display:
- Code: Select all | TOGGLE FULL SIZE
import digitalio
import board
from PIL import Image, ImageDraw, ImageFont
import adafruit_rgb_display.ili9341 as ili9341
import os
from time import sleep
import busio
from adafruit_stmpe610 import Adafruit_STMPE610_SPI
import adafruit_focaltouch
# definitions
pos = (0,0)
#Colors
WHITE = (255,255,255)
RED = (255,0,0)
# Configuration for CS and DC pins (these are PiTFT defaults):
cs_pin = digitalio.DigitalInOut(board.CE0)
dc_pin = digitalio.DigitalInOut(board.D25)
reset_pin = digitalio.DigitalInOut(board.D24)
# Config for display baudrate (default max is 24mhz):
BAUDRATE = 24000000
# Setup SPI bus using hardware SPI:
spi = board.SPI()
disp = ili9341.ILI9341(
spi,
rotation=90, # 2.2", 2.4", 2.8", 3.2" ILI9341
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
height = disp.width
width = disp.height
image = Image.new("RGB", (width, height))
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
# Clear the display - color it white
draw.rectangle((0, 0, width, height), fill=WHITE)
disp.image(image)
i2c=board.I2C()
ft = adafruit_focaltouch.Adafruit_FocalTouch(i2c, debug=False)
while True:
if ft.touched:
disp.image(image)
print(ft.touches)
ts = ft.touches
point = ts[0]
# perform transformation
y = 240 - point["x"]
x = point["y"]
print("x:" + str(x) + ", y:" + str(y))
# Draw the circle
draw.ellipse((x-10, y-10, x+10, y+10), fill=RED, width=2)
disp.image(image)
sleep(.25)
And here's my test of the resistive. I'm getting values, but they don't appear correct. Since I have the capacitive working (and that's my preference), I won't be working on this any longer. But I figured I'd include it for anyone in the future that comes across this...
import digitalio
import board
import os
import busio
from adafruit_stmpe610 import Adafruit_STMPE610_I2C
# definitions
pos = (0,0)
#Colors
RED = (255,0,0)
cs1_pin = digitalio.DigitalInOut(board.CE1)
BAUDRATE = 24000000
spi = board.SPI()
spi,
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
height = disp.width
width = disp.height
disp.image(image)
# Draw the circle
draw.ellipse((-10, -10, 10, 10), fill=RED, width=2)
disp.image(image)
#i2c=busio.I2C(board.SCL,board.SDA)
i2c=board.I2C()
st = Adafruit_STMPE610_SPI(spi, cs1_pin)
#st = Adafruit_STMPE610_I2C(i2c, 65)
while True:
if st.touched:
print(st.read_data())
sleep(.25)
Danny
