http server on a pyportal
by MVB57 on Sun Aug 02, 2020 2:27 am
Hi there,
For my pyportal I am trying to add a http server so I can interact with it remotely. I am working with the Adafruit_CircuitPython_ESP32SPI library and Circuitpython 5.3.1. I am using the "start_server(port, socket_num, conn_mode=0, ip=None)" function to set up a server on port 80 of my board. The server can be seen in my local network when I scan for open ports on the IP address of the pyportal.
How can I check if a request is made by a client and send a response in return? I have not been able to find any example online sofar.
Thanks in advance,
Michiel
PS Here is the code I have been working with so far:
import time
import board
import busio
from digitalio import DigitalInOut
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
from secrets import secrets
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
if esp.status == adafruit_esp32spi.WL_IDLE_STATUS:
    print("ESP32 found and in idle mode")
print("Connecting to AP...")
while not esp.is_connected:
    try:
        esp.connect_AP(secrets["ssid"], secrets["password"])
    except RuntimeError as e:
        print("could not connect to AP, retrying: ", e)
        continue
print("My IP address is", esp.pretty_ip(esp.ip_address))
socketnumber = esp.get_socket()
esp.start_server(80, socketnumber)
while True:
    print(esp.server_state(socketnumber))
    time.sleep(2)
MVB57
Re: http server on a pyportal
by tannewt on Mon Aug 03, 2020 10:51 am
tannewt
