CLUE question
CLUE question
by photodoc on Mon Aug 03, 2020 10:00 pm
Used the CLUE (from box 15) to build the Bonsai Buckaroo. The wiring setup and code is pretty straightforward, and it appears to run correctly. My question is regarding the inputs for detecting soil moisture percentage. Despite everything being connected, the soil percentage starts at and remains zero no matter what, so that left to its own devices, the CLUE would water the plant forever. I'm assuming it is the resistance between the nails that is calculated? I even tried touch the nails to each other and the display continued to read zero. So the question is - what would be the easiest way to check the board function for those pins? Thanks!
Jeremy
photodoc
Re: CLUE question
by adafruit_support_carter on Tue Aug 04, 2020 2:13 pm
Just to make sure - you are running the code from this guide?
https://learn.adafruit.com/chauncey-flo ... e-the-clue
If so, it may be a connection issue. Make sure all the fasteners on the Buckaroo are on and snug. Also make sure the alligator clips have good contact with the pads.
