Hallowing m0
Hallowing m0
by Teddygag on Fri Aug 07, 2020 1:44 pm
Can someone please write a simple turtle graphics program in python to draw to the hallowing display. I have tried myself and all I get is a black display. No error messages. I’m sure it’s because the backlight is turned off. I don’t know how to turn it on with python. Then maybe my turtle graphics will show up.
Teddygag
Re: Hallowing m0
by dastels on Fri Aug 07, 2020 6:01 pm
There's this I wrote a while ago https://learn.adafruit.com/circuitpython-turtle-graphics, though it probably won't fit on an M0.
An example of manipulating the backlight is shown in this project. See around lines 85-106. https://learn.adafruit.com/hallowing-jump-scare-trap/code-with-circuitpython
dastels
Re: Hallowing m0
by Teddygag on Fri Aug 07, 2020 6:45 pm
Thanks Dave. Can you use that super power you have for code and isolate the exact code I need to turn on the tft display and nothing else. I want to make this a function I can include as I experiment with the turtle graphics. I simply can not separate out exactly what I need from the second program you specified.
It is strange to me that the simple turtle program of a few lines makes it run out of memory while the huge second program does not. What am I missing. The hallowing has 8gigs of memory.
Teddygag
Re: Hallowing m0
by Teddygag on Fri Aug 07, 2020 7:31 pm
Yup, you are correct. The 15 line code to draw a simple square returns a memory allocation error.
In the larger second program of 152 lines of code, I get the error:
code.py output:
File "code.py", line 86, in <module>
ValueError: TFT_BACKLIGHT in use
I can go no further to test out the backlight code.
help please ?
Teddygag
Re: Hallowing m0
by dastels on Fri Aug 07, 2020 10:07 pm
Hmm.. I'm not sure yet what's going on.
>>> import board
>>> import pulseio
>>> backlight = pulseio.PWMOut(board.TFT_BACKLIGHT)
  File "<stdin>", line 1, in <module>
Ok. It's used by board.DISPLAY which gives you access to it.
>> display = board.DISPLAY
>>> display.brightness = 0.5
>>> display.brightness = 0.0
>>> display.brightness = 1.0
That should give you what you need.
dastels
