_EVE Bridgetek Gameduino Help
by AS_TCC on Sun Aug 09, 2020 2:58 pm
I noticed the _EVE module was added to support Bridgetek display drivers, but I cannot find documentation that explains how it’s used. For instance, how do I configure the module for a specific Bridgetek driver? Is the module solely intended for use with Gameduino hardware or can it be used with other EVE displays?
AS_TCC
Re: _EVE Bridgetek Gameduino Help
by siddacious on Mon Aug 10, 2020 2:20 pm
I'm not aware of any Adafruit library that uses the _EVE module, however I did find this python library that seems to do something similar, however I know nothing about it and cannot provide any help with it.
https://github.com/jamesbowman/py-bteve
good luck!
siddacious
by AS_TCC on Tue Aug 11, 2020 2:15 pm
Hello siddacious,
Thank you for your response. the module I am referring to is [url]https://circuitpython.readthedocs.io/en/latest/shared-bindings/_eve/index.html, which I believe is what you have linked to. I have a display similar to https://www.newhavendisplay.com/nhd4348 ... -9569.html which has an EVE driver, but I am not understanding how to utilize _eve to get my feather m4 express and the display to talk. I couldn't find a guide or tutorial that would illuminate the subject, do you see anything I am missing? Is it just so dead simple that I shouldn't have to ask?
Hope your day is going great!
AS_TCC
by tannewt on Tue Aug 11, 2020 2:20 pm
We don't have an Adafruit guide or tutorial because we didn't add the driver to CircuitPython. jamesbowman added it https://github.com/adafruit/circuitpython/pull/2581 So, I'd recommend reaching out to them.
I do know that the _eve module was meant to be a private module so you'll likely want to start with the library that siddacious linked.
tannewt
by AS_TCC on Wed Aug 12, 2020 12:09 pm
Hi tannewt,
Thank you for the details, and explanation. I'll look into james' library and reach out there.
Kindly,
Travis Carter
AS_TCC
