CIRCUITPY Drive incorrect on Feather STM32F405 Express
by water35 on Fri Aug 14, 2020 6:09 pm
When CircuitPython finishes installing (5.3.1 and 6.0.0 Alpha 2), firmware from https://circuitpython.org/board/feather_stm32f405_express/,
the CIRCUITPY Drive not appear in Windows file browser (and Linux also),
Adafruit Board Drivers installed:
and Windows device manager appear strange device,
I ensure the hardware configure correct, I try to install MicroPython 1.12 with Feather STM32F405 Express firmware, the pyboard Drive works fine on same computer,
and Windows device manager appear this device:
water35
Re: CIRCUITPY Drive incorrect on Feather STM32F405 Express
by tannewt on Sun Aug 16, 2020 11:25 pm
What version of Windows are you using?
tannewt
by water35 on Mon Aug 17, 2020 12:23 am
tannewt wrote:What version of Windows are you using?
I using Windows 8.1 Professional, but CIRCUITPY Drive can't show up in Linux also.
The REPL run correctly.
water35
by water35 on Mon Aug 17, 2020 3:09 pm
water35
by tannewt on Mon Aug 17, 2020 3:55 pm
Sorry, I don't know Windows or STM very well. I believe the windows drivers are only for Windows 7 and may mess up Windows 8.
That wouldn't explain why Linux doesn't work though.
Does the status neopixel blink? What color is it?
tannewt
by water35 on Tue Aug 18, 2020 2:09 am
tannewt wrote:Sorry, I don't know Windows or STM very well. I believe the windows drivers are only for Windows 7 and may mess up Windows 8.
neopixel blink in Green.
When in REPL via 'screen /dev/ttyACM0 115200' neopixel is white (not blink).
water35
by water35 on Tue Aug 18, 2020 1:46 pm
And I try to list files on internal flash, but nothing on it, there should be have some files.
import os
os.listdir('/')
water35
by tannewt on Tue Aug 18, 2020 2:06 pm
Ah! Sometimes the filesystem can be corrupted. Please try erasing it from the REPL. See here for instructions: https://learn.adafruit.com/welcome-to-c ... 2978456-22
tannewt
by water35 on Tue Aug 18, 2020 4:53 pm
I think it is't filesystem corrupted, I try full chip erase and re-flash the firmware serveral times, this problem arise still.
storage.erase_filesystem()
File "<stdin>", line 1, in <module>
ValueError: Hardware busy, try alternative pins
water35
by danhalbert on Tue Aug 25, 2020 11:36 am
Windows 8.1 does need drivers, like Windows 7. The driver installer will work on Windows 8.1. There is some kind of bug or change in Windows 8.1 that causes the driver names to be incorrectly set, but the drivers are still present.
danhalbert
by hierophect on Tue Aug 25, 2020 11:44 am
I'm unfortunately unable to replicate this issue on Windows 10, and I've asked another maintainer to try it on Linux (debian buster kernel 5.2.17) and they also do not report any issues. It also does not occur on my Mac OSX machine.
The much more concerning message is the
message you are receiving when you attempt to access the NOR flash. This may indicate that the flash chip is damaged or disconnected somehow, or that the pins on it were somehow re-defined or overwritten in software. Have you ever loaded a program successfully onto this feather before, that might have affected pin options? Otherwise, I would suspect a hardware issue.
hierophect
by water35 on Sat Aug 29, 2020 4:15 pm
hierophect wrote:The much more concerning message is the
Thanks, solved, it's hardware issue.
water35
