USB HID on iPad (iOS)
Re: USB HID on iPad (iOS)
by kmevans on Sun Aug 30, 2020 11:51 pm
Dan - thanks a lot. I will try doing a build. I already have a build environment setup, so it should be easy. I'll try tomorrow morning.
kmevans
by kmevans on Mon Aug 31, 2020 1:19 am
Ok - I couldn't resist a quick build and testing. It looks like this fixes it. I'll try to control iOS minecraft tomorrow and that should be a pretty good test + verifying that the MSC still mounts.
kmevans
by hathach on Mon Aug 31, 2020 4:07 am
Right, iOS won't accept generic gamepad either with usb or ble. Apple reall restrict what csn connect to their ios. However, I think ps4 controller can connect and work well with iOS. Maybe it is worth to take a look at how ps4 controller present itself.
https://support.playstation.com/s/artic ... uage=en_US
hathach
by kmevans on Mon Aug 31, 2020 2:02 pm
As far as I can tell this is fine, and I was able to use the mouse and keyboard. I got a little sidetracked because it wasn't working in iOS Minecraft, but apparently this is an issue with the app itself. There are forum threads about it. I verified that a USB mouse/keyboard and Apples own BLE keyboard don't work for iOS Minecraft either.
kmevans
by nineseventytwo on Sun Sep 13, 2020 8:32 pm
I've read thru this entire post and would like to use CircuitPython running on an ItsyBitsy M4 Express as a keyboard and mouse. I've used CircuitPython version 3 susessfully in the past to do this but I'm revisiting this project and updated to CircuitPython 6. I'm running into the same problem with it not functioning on IOS as a keyboard. I can follow that I would need to change a line to not include GAMEPAD. Can you point me in the right direction on how to do this? I'm basically inexperienced.
nineseventytwo
by kmevans on Sun Sep 13, 2020 8:54 pm
Start here and see if this is too much for you to do: https://learn.adafruit.com/building-circuitpython
If not then you can edit mpconfigboard.mk as described above. The one I edited was in ports/atmel-samd/boards/itsybitsy_m4_express/mpconfigboard.mk. You can look at a copy here https://github.com/adafruit/circuitpython/blob/main/ports/atmel-samd/boards/itsybitsy_m4_express/mpconfigboard.mk
If it's too complicated then perhaps someone else could build it for you.
kmevans
by nineseventytwo on Sun Sep 13, 2020 9:12 pm
Thanks for the quick reply. I'm half way through the how to build CircuitPython tutorial. Thanks for the link. So the file I'm changing should look like this then?
USB_VID = 0x239A
USB_PID = 0x802C
USB_PRODUCT = "ItsyBitsy M4 Express"
USB_MANUFACTURER = "Adafruit Industries LLC"
CHIP_VARIANT = SAMD51G19A
CHIP_FAMILY = samd51
QSPI_FLASH_FILESYSTEM = 1
EXTERNAL_FLASH_DEVICE_COUNT = 1
EXTERNAL_FLASH_DEVICES = GD25Q16C
LONGINT_IMPL = MPZ
# No I2S on SAMD51G
CIRCUITPY_AUDIOBUSIO = 0
CIRCUITPY_BITBANG_APA102 = 1
USB_HID_DEVICES=KEYBOARD,MOUSE,CONSUMER
nineseventytwo
by kmevans on Sun Sep 13, 2020 9:24 pm
That looks correct to me.
kmevans
by nineseventytwo on Sun Sep 13, 2020 9:39 pm
Thank you so much! I was able to build firmware, and it actually worked.
nineseventytwo
by kmevans on Sun Sep 13, 2020 9:42 pm
Great!
kmevans
