Coral dev board drive sg90 servo motor problem
by YOUWEILIN on Wed Aug 26, 2020 1:32 am
I use Coral dev board to drive the sg90 servo motor. I follow the instructions on the official website, but I can’t drive the motor. What's wrong?
This web: https://learn.adafruit.com/circuitpython-on-google-coral-linux-blinka/pwm-outputs-servos
code:
import time
import board
import pulseio
from adafruit_motor import servo
# create a PWMOut object on Pin PWM3.
pwm = pulseio.PWMOut(board.PWM3, duty_cycle=2 ** 15, frequency=50)
# Create a servo object, my_servo.
my_servo = servo.Servo(pwm)
while True:
for angle in range(0, 180, 5): # 0 - 180 degrees, 5 degrees at a time.
my_servo.angle = angle
time.sleep(0.05)
for angle in range(180, 0, -5): # 180 - 0 degrees, 5 degrees at a time.
time.sleep(0.05)
YOUWEILIN
Re: Coral dev board drive sg90 servo motor problem
by mikeysklar on Wed Aug 26, 2020 4:47 pm
Code looks good.
Can you show us a photo of your wiring? You should be connected to pin #15 on the Coral if you are using PWM3.
Please verify that the PWMs are enabled with this command:
 ls /sys/class/pwm/
mikeysklar
