MS8607 and CircuitPython
by Tom_Henry on Tue Sep 01, 2020 10:31 pm
Tuesday, September 1, 2020
I have read that it's supposed to be very easy to set up CircuitPython and easily run CircuitPython programs.
Well, I disagree.
I have spend hours trying to figure out why I can't make a simple sensor, MS8607, work with CircuitPython and my Raspberry Pi 4.
Ok, so I decided to try a clean install of Raspberry Pi OS. I followed very carefully the steps on Adafruit's website and documented all the steps below. Maybe someone can help me with this. Otherwise I have no choice but to return the module to Adafruit a defective.
Step 1:
Completed all directions from the following website:
https://learn.adafruit.com/circuitpytho ... spberry-pi
Step 2:
Ran the python3 blinkatest.py program at the command line:
Here are the results:
pi@raspberrypi:~ $ python3 blinkatest.py
Hello blinka!
Digital IO ok!
I2C ok!
SPI ok!
Done!
Step 3:
Went to this website for the CircuitPython installation of the MS8607 library.
https://learn.adafruit.com/adafruit-te- ... cuitpython
Step 4:
First I connected my Raspberry Pi 4 to the Adafruit’s MS8607 sensor using the Stemma QT connectors.
Step 5:
I used pip3 to install the driver for the ms8607.
Installing from PyPI
On supported GNU/Linux systems like the Raspberry Pi, you can install the driver locally from PyPI. To install for current user:
pip3 install adafruit-circuitpython-ms8607
I received the message:
Successfully installed adafruit-circuitpython-ms8607-1.0.1
Step 6:
I tried to run the following Adafruit program:
from time import sleep
import board
import busio
from adafruit_ms8607 import MS8607
i2c = busio.I2C(board.SCL, board.SDA)
sensor = MS8607(i2c)
while True:
print("Pressure: %.2f hPa" % sensor.pressure)
print("Temperature: %.2f C" % sensor.temperature)
print("Humidity: %.2f %% rH" % sensor.relative_humidity)
sleep(1)
Step 7: Error messages:
File "/home/pi/ms8607.py", line 4, in <module>
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_ms8607.py", line 38, in <module>
import adafruit_bus_device.i2c_device as i2c_device
ModuleNotFoundError: No module named 'adafruit_bus_device'
I keep getting module not found. Tis a mystery to me.
Hope someone can put me on the right track.
Thanks.
Tom_Henry
Re: MS8607 and CircuitPython
by smccamy1 on Tue Sep 01, 2020 11:39 pm
Try
pip3 install adafruit_bus_device
and/or
pip3 install adafruit-circuitpython-busdevice
smccamy1
by tannewt on Wed Sep 02, 2020 11:28 am
This is a bug in the configuration of the MS8607 library. It should have Bus Device as a dependency so pip always installs it.
I've filed an issue to fix it: https://github.com/adafruit/Adafruit_Ci ... 7/issues/1
tannewt
by Tom_Henry on Wed Sep 02, 2020 3:23 pm
tannewt
Perfect.
Just what I didn't need for my first circutpython sensor.
Now that I know it really works, I'll be purchasing several more sensors.
Thanks very much,
Tom Henry
Python Program:
import board
import busio
while True:
sleep(1)
Results
Python 3.7.3 (/usr/bin/python3)
>>> %Run ms8607.py
Pressure: 1012.35 hPa
Temperature: 24.90 C
Humidity: 53.07 % rH
Pressure: 1012.27 hPa
Temperature: 24.91 C
Humidity: 53.05 % rH
Pressure: 1012.28 hPa
Temperature: 24.92 C
Humidity: 53.04 % rH
Pressure: 1012.30 hPa
Humidity: 53.02 % rH
Temperature: 24.93 C
Humidity: 53.01 % rH
Tom_Henry
by tannewt on Wed Sep 02, 2020 6:42 pm
Great! Sorry for the trouble.
Looks like it's been fixed but not released yet: https://github.com/adafruit/Adafruit_Ci ... 607/pull/2
tannewt
