RFID using pn532 in circuit python
by lerosser on Wed Sep 02, 2020 5:02 pm
I have been trying to implement the pn532 module in circuit python using a Feather M0 express board designed for circuit python. I am getting a "memory error: memory allocation failed, ....". I am using the PN532 library, which is all .py files. I understand that .mpy take up less memory and might solve my problem. I can't seem to find the .mpy versions, and it seems rather complicated to try and generate them. Can someone point me to a source for these files?
thanks
Leigh
lerosser
Re: RFID using pn532 in circuit python
by tannewt on Wed Sep 02, 2020 6:45 pm
Hi Leigh, the mpy versions should be available in the bundle: https://github.com/adafruit/Adafruit_Ci ... ses/latest
If that still has the problem, could you please post your complete code.py here in CODE tags? That way we can suggest improvements.
tannewt
by lerosser on Thu Sep 03, 2020 11:50 am
Excellent, thanks so much for the prompt reply. The code is now running for the pn532_simpletest.py example file.
I was wondering if you could point me to any example circuitpython files that use an RIFD tag to trigger the play back of sound files? I want to have maybe five unique sound files and corresponding rfid tags that trigger them. Will be using the PN532 breakoutboard, a Feather M0 express and a Audio FX sound board.
thanks for any assistance you can offer.
Regards,
Leigh
lerosser
by tannewt on Thu Sep 03, 2020 2:19 pm
Unfortunately I don't know of an example that does that. I'd suggest by getting the Audio FX sound board going and then combining that code with the PN532 example.
tannewt
by lerosser on Thu Sep 10, 2020 2:38 pm
So have attempted to cobble together some example code to do what I want. Which is ultimately to read an RFID card and play an associated sound file. My sample code (attacted) listens for a card, reads a specific block, and checks if the data in that block is equal or not equal to a set value. It works, sort of. I get a "equal" or "not equal" to print, but then I get an error code.
File "main.py", line 26, in <module>
File "adafruit_pu532/adafruit_pn532.py", line 507, in ntag2xx_read_block
TypeError: 'NoneType' object is not subscriptable
Can anyone give me some insight on what is failing? Ultimately I will have more conditional statement to compare the block data to one of five specific IDs, and then I will play the associated sound file.
Sorry, I am not a programmer, any help would be much appreciated.
Leigh
main.py
(982 Bytes) Downloaded 1 time
lerosser
by tannewt on Thu Sep 10, 2020 2:51 pm
Hi Leigh,
This looks like a bug in the library. It isn't handling the case where the tag isn't read correctly. The bug is here: https://github.com/adafruit/Adafruit_Ci ... 32.py#L500
I think you can call `mifare_classic_read_block(6)` directly yourself and handle if it returns None. Here is where None is returned: https://github.com/adafruit/Adafruit_Ci ... 32.py#L456
You are programming, so you are a programmer. :-) We all have more to learn.
tannewt
by lerosser on Thu Sep 10, 2020 4:13 pm
I am not sure if I understand. Are you saying to use the mifare_classic_read_block function instead of ntag2xx_read_block? Also I am not sure what you mean by "handle if it returns None"?
thanks
On another topic, are there programmers on this forum who offer their services for hire? I enjoy learning, but I don't enjoy banging my head against the wall ;)
Leigh
lerosser
by tannewt on Fri Sep 11, 2020 3:28 pm
lerosser wrote:I am not sure if I understand. Are you saying to use the mifare_classic_read_block function instead of ntag2xx_read_block? Also I am not sure what you mean by "handle if it returns None"?
Yup! I mean you'll want to check the return value of mifare_classic_read_block before reading a portion of it.
lerosser wrote:On another topic, are there programmers on this forum who offer their services for hire? I enjoy learning, but I don't enjoy banging my head against the wall ;)
Leigh
Take a look at the jobs board: https://jobs.adafruit.com/
tannewt
