Use CTRL-D programmatically
by john_doe1337 on Fri Sep 04, 2020 8:09 am
is it possible to use the CTRL-D (Use CTRL-D to reload) programmatically.
So for example, instead of raising an Error reload the programm?
john_doe1337
Re: Use CTRL-D programmatically
by danhalbert on Fri Sep 04, 2020 8:33 am
You can call `supervisor.reload()`, which is equivalent to typing ctrl-D: https://circuitpython.readthedocs.io/en ... sor.reload
danhalbert
by kevinjwalters on Fri Sep 25, 2020 1:49 pm
What's the intended behavour of supervisor.reload() in REPL? It doesn't appear to do anything immediately visible based on the prompt. The pwm output continues afterwards uninterrupted too.
Press any key to enter the REPL. Use CTRL-D to reload.
Adafruit CircuitPython 5.3.1 on 2020-07-13; Adafruit CLUE nRF52840 Express with nRF52840
>>> import board
>>> import pulseio
>>> pwm_p2=pulseio.PWMOut(board.P2, duty_cycle=32768)
>>> import supervisor
>>> supervisor.reload()
kevinjwalters
by tannewt on Fri Sep 25, 2020 1:58 pm
I suppose it should exit the REPL. I don't know why you'd use it over ctrl-d though. I believe you can also type `exit` or `quit` too.
tannewt
