UART between two Feathers STM32F405
by ramsh on Wed Sep 09, 2020 12:08 pm
I have two Feathers STM32F405 connected via UART (crossed RX, TX) to one another and share a ground, but i cant transmit data from one to another...
both run CircuitPython:
Adafruit CircuitPython 5.3.1 on 2020-07-13; Feather STM32F405 Express with STM32F405RG
I added the "adafruit_bus_device" folder to both feathers lib folders and have the following code for the transmit data:
import busio
uart = busio.UART(board.TX, board.RX, baudrate=9600)
print('1\n')
and on the receiving end:
import busio
while True:
    data = uart.readline(2)  # read up to 2 bytes
    print(f'>>>>> {data}')
the results is always:
>>>>> None
>>>>> None
>>>>> None
>>>>> None
>>>>> None
>>>>> None
>>>>> None
the wires are connected as it should, i have tripled checked it and it is not a wiring problem...
can you please help me figure this out?
many thanks in advance!!
Best,
Ram
ramsh
Re: UART between two Feathers STM32F405
by tannewt on Wed Sep 09, 2020 7:11 pm
Hi Ram, instead of `print()`ing try doing `uart.write()`. Print only outputs to the USB CDC connection, not the UART objects.
tannewt
by ramsh on Thu Sep 10, 2020 4:49 am
Yay! that works, just need to send the data as byte:
send:
uart.write(b'1')
recieve:
while True:
    data = uart.readline(1)  # read 1 byte
    if data == b'1':
        print('Yay!')
many thanks for your support!
Best,
Ram
ramsh
