uart.read() takes one second to execute?
by ramsh on Thu Sep 10, 2020 5:17 am
Using two Feathers STM32F405 connected by RX/TX both running:
Adafruit CircuitPython 5.3.1 on 2020-07-13; Feather STM32F405 Express with STM32F405RG
it takes one second for the receiver side that waits and reads the incoming data to execute the uart.read() line:
while True:
    timeIt = time.monotonic()
    data = uart.read(1)  # read 1 byte
    print(f'>>>>> {data} {time.monotonic() - timeIt}')
and the output:
>>>>> None 1.0
>>>>> None 1.0
>>>>> None 1.0
>>>>> None 1.0
>>>>> None 1.0
>>>>> None 1.0
>>>>> None 1.0
is this normal or (once again) I miss something?
Thanks much in advance!
Ram
ramsh
Re: uart.read() takes one second to execute?
by westfw on Thu Sep 10, 2020 6:38 am
It would be "common" for a uart read function to "time out" when there is no data.
The similar Arduino Serial.readBytes() function also does this.
(There's probably a different function that is "non-blocking" and returns immediately if there is no data.)
westfw
by jerryn on Thu Sep 10, 2020 6:51 am
jerryn
by ramsh on Thu Sep 10, 2020 7:44 am
Thank you all for your valuable feedback!
I've updated my code and it works as needed:
uart = busio.UART(board.TX, board.RX, baudrate=115200, timeout=0.01)
Many thanks to this great community!!!
ramsh
by kevinjwalters on Thu Sep 10, 2020 11:19 am
Depending on what you're ultimately going to be doing with it uart.in_waiting (mentioned in the docs @jerryn cited) may be useful too.
kevinjwalters
by ramsh on Thu Sep 10, 2020 4:24 pm
kevinjwalters wrote:Depending on what you're ultimately going to be doing with it uart.in_waiting (mentioned in the docs @jerryn cited) may be useful too.
good tip, much appreciated!
ramsh
