WIZnet5K can't obtain IP from OpenWRT.
by water35 on Fri Sep 11, 2020 9:56 am
CircuitPython 6.0.0 Alpha-3,
(use 1.4.1 library from : https://github.com/adafruit/Adafruit_CircuitPython_Wiznet5k/releases/download/1.4.1/adafruit-circuitpython-wiznet5k-py-1.4.1.zip)
initialise WIZnet5K using
eth = WIZNET5K(spi_bus, cs, debug = True)
to enable debug.
Connect WIZnet5K to Mikrotik router, obtain IP success,
then connect to OpenWRT router, return these message below (I tested use PC can obtain IP from this OpenWRT):
How to know what's going wrong?
Wiznet5k WebClient Test
* Initializing DHCP
*** Get socket
Allocated socket #0
* w5k socket connect, protocol=2, port=67, ip=255.255.255.255
*** Opening socket 0
* Opening W5k Socket, protocol=2
* DHCP: Discover
* DHCP: Parsing OFFER
* socket_available called with protocol 2
Bytes avail. on sock: 308
* Processing 8 bytes of data
* Received DHCP Message is not OFFER
*** Closing socket #0
File "<stdin>", line 1, in <module>
File "wiznet5k_simpletest.py", line 17, in <module>
File "adafruit_wiznet5k/adafruit_wiznet5k.py", line 196, in __init__
AssertionError: Failed to configure DHCP Server!
I'm not skill to configure router, so most parameter use by default, screenshot below:
water35
Re: WIZnet5K can't obtain IP from OpenWRT.
by siddacious on Tue Sep 22, 2020 5:09 pm
I'll forward this to someone who may be able to help!
siddacious
by brubell on Wed Sep 23, 2020 2:04 pm
This issue is addressed on https://github.com/adafruit/Adafruit_Ci ... -697412226
User found solution:
I use random.randint() replace random.randrange() in adafruit_wiznet5k_dhcp.py line 364, seems better, need more time to confirm.
brubell
