Lidar Lite V4
Lidar Lite V4
by slowjim on Tue Sep 15, 2020 8:18 am
Hi
I am having trouble getting my Garmin LiDAR-Lite V4 (Product ID 4441) to fire up. I am using the sample code below to print the distance in the REPL, however I receive a repeated error message:
Measurement failure
Measurement failure
Measurement failure
Measurement failure
I also get the occasional "System failure" message from time to time.
In terms of hardware, I am using a Feather M4 Express with a AP3602A to get 5Vi for the sensor with a 470uF capacitor. My intent is to shrink to a Trinket M0 at some point with a PowerBoost 1000C and maybe an LCD screen).
I am wondering if anyone has any experience with these sensors and may be able to pick up on what I'm missing.
As always, thanks for your help.
Cheers
SlowJim
import time
import busio
import board
import adafruit_lidarlite
i2c = busio.I2C(board.SCL, board.SDA)
sensor = adafruit_lidarlite.LIDARLite(i2c)
while True:
    try:
        print(sensor.distance)
    except RuntimeError as e:
        # If we get a reading error, just print it and keep truckin'
        print(e)
    time.sleep(0.5)
slowjim
Re: Lidar Lite V4
by dastels on Tue Sep 15, 2020 9:21 am
From a quick check of the product pages, the AP3602A can supply 100mA, while the LIDAR-Lite draws 130 during measurements. I suggest powering from USB to confirm this is your problem.
dastels
Re: Lidar Lite V4
by slowjim on Tue Sep 15, 2020 9:29 am
Hi Dave
Thanks for your reply. I was still having a tweak on the test bench as your reply came through. I have just tried with 5Vin and the USB pin, unfortunately I still get the same result.
Cheers
SlowJim
slowjim
Re: Lidar Lite V4
by dastels on Tue Sep 15, 2020 10:59 am
Hmm. Same Code (other that printing to the 7-segment display) as I used (https://learn.adafruit.com/garmin-lidar-lite-range-finder). It sounds like your wiring is pretty much the same as well. I just fired this up and watched the REPL output... not a single error.
I have to ask... the lenses are43 clean, yes?
Also, does the error frequency vary with what the LIDAR is pointed at? The angle to that surface?
dastels
Re: Lidar Lite V4
by dastels on Tue Sep 15, 2020 11:22 am
For your reference:
The CircuitPython module: https://github.com/adafruit/Adafruit_CircuitPython_LIDARLite/blob/master/adafruit_lidarlite.py
Garmin's docs: https://static.garmin.com/pumac/LIDAR_L ... ations.pdf
The status/error register and bitmask are on page 8 of Garmin's doc. Se the read_distance function in the LIDARLite class.
dastels
Re: Lidar Lite V4
by slowjim on Wed Sep 16, 2020 6:21 am
Hi Dave
Thanks for the tips, but unfortunately no joy. The lens are now extremely clean although I think they were probably not too bad to begin with. I spent about 10 minutes pointing it at different objects and at different distances but to no avail. I did see that you linked the V3 sensor. I am using the V4 should I expect any different behavior?
Cheers
SlowJim
slowjim
Re: Lidar Lite V4
by dastels on Wed Sep 16, 2020 9:22 am
My bad. The v4 is a completely different beast. Same thing applies with leneses and targets, though.
Looking at it's CP code, try calling sensor.reset() before the while loop.
dastels
Re: Lidar Lite V4
by slowjim on Wed Sep 16, 2020 10:09 am
Hi Dave
Not good news from tonight's testing. I have set up the same as yesterday. First try and I got the request for asked for pull resistors error. I added 4k7 on SCL and SDA. On subsequent attempts, multiple resets etc the feather cannot even see the sensor (eg no i2c device at address 62). So unfortunately I cannot even test your reset theory. Maybe I should have saved some more money and bought the V3. Anyway in my part of the world it is time to let frustration give way to some sleep. I will try again tomorrow.
Thanks again for your help. Your responses on the forums and your tutorials are excellent. I have learnt so much from them. Despite getting stuck with sensors from time to time this hobby is awesome and I thank you and the team.
Cheers
SlowJim
slowjim
Re: Lidar Lite V4
by dastels on Wed Sep 16, 2020 12:39 pm
The LIDAR already has pullups. This seems to happen occasionally in CircuitPython (the "needs pullups" error). Disconnect power from everything and power up again. That will often correct it.
You're right... it is fun, and also sometimes extremely frustrating.
dastels
