Is this the correct link for what you want me to look at?dastels wrote:The arduino library from Garmin provides a method for setting the alternate address. What you have looks good, but there's more to their method: (optionally) disabling the default address, and disabling/relocking flash, plus 100mS delays at appropriate times. See https://www.kickstarter.com/projects/co ... escription
Lidar Lite V4
- TekTao
Re: Lidar Lite V4
- dastels
Re: Lidar Lite V4
Doh... my copy buffer was stale for some reason.. I swear I copied the github link. Let's try again: https://github.com/garmin/LIDARLite_Ard ... _v4LED.cpp
That looks better. BTW if you fancy Norse themed D&D, Svilland does look pretty sweet, though the kickstarter is long closed.
I fixed the original link for posterity.
- TekTao
Re: Lidar Lite V4
I attempted this and it gets me nothing
Adding the sleep into this does not seem to work. Also, I noticed on the Arduino version that the code sends all of this information to address 0x16. I do not understand why this works on the Arduino I2C address change function.
sensor._write_reg(0xEA,0x11)
time.sleep(0.1)
sensor._write_reg(0x16,0x00)
time.sleep(0.1)
sensor._write_reg(0x17,0x00)
time.sleep(0.1)
sensor._write_reg(0x18,0x00)
time.sleep(0.1)
sensor._write_reg(0x19,0x00)
time.sleep(0.1)
sensor._write_reg(0x1A,0x55) # any new address
time.sleep(0.1)
sensor._write_reg(0x1B,0x02) # use new address
print('turkey')
- dastels
Re: Lidar Lite V4
It uses a multi-register write starting at 0x16 in a single transaction. That might be what you need to do.
You put a delay after each byte. The C++ code doesn't do that. It has a delay:
- after enabling flash
- after writing the new address
- after disabling the default
- after disabling flash
When you get it working, we can add it to the class.
- imhavoc
Re: Lidar Lite V4
Using Dave's library, I'm getting solid readings until the whole thing comes crashing down:
python3 lidartest.py
(355,)
(353,)
(354,)
(354,)
(353,)
(354,)
(353,)
(354,)
(353,)
(353,)
(354,)
(352,)
File "lidartest.py", line 15, in <module>
print((sensor.distance,))
File "/home/pi/adafruit_lidarlite.py", line 132, in distance
return self.read_distance(self._bias_count == 0)
File "/home/pi/adafruit_lidarlite.py", line 121, in read_distance
self.wait_while_busy()
File "/home/pi/adafruit_lidarlite.py", line 155, in wait_while_busy
while self.status & STATUS_BUSY:
File "/home/pi/adafruit_lidarlite.py", line 139, in status
i2c.write_then_readinto(buf, buf)
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 131, in write_then_readinto
in_end=in_end,
File "/home/pi/.local/lib/python3.7/site-packages/busio.py", line 183, in writeto_then_readfrom
stop=stop,
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 88, in writeto_then_readfrom
address, buffer_out[out_start:out_end], in_end - in_start
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_PureIO/smbus.py", line 273, in read_i2c_block_data
ioctl(self._device.fileno(), I2C_RDWR, request)
OSError: [Errno 121] Remote I/O error
- imhavoc
Re: Lidar Lite V4
Oh, by the way, I'm running a Raspberry Pi 3A.
- imhavoc
Re: Lidar Lite V4
I am still getting failed samples, but the script stopped crashing when I gave up on printing the exception error.
import time
import board
import busio
import adafruit_lidarlite
# Create library object using our Bus I2C port
# Default configuration, with only i2c wires
sensor = adafruit_lidarlite.LIDARLiteV4LED(i2c)
while True:
try:
distance = sensor.distance
print((distance,))
time.sleep(1) # you can remove this for ultra-fast measurements!
except:
print ("failed sample")
- Robaird
Re: Lidar Lite V4
Thank you dastels, for the revised v4 module!
Someone should drop a note on Garmin Lidar Lite v4 product page to this thread--rather than the current link to the v3 adafruit.lidar.msy module which after a couple hours of angst, I now know isn't forward compatible with the v4. Thank goodness you posted the link to this thread on github--saved halloween, haha (using the Lidar Lite v4 and the Feather RP2040 as a distance triggered air harp playing a couple software synths).
