BNO055 Quaternion returns None
by RossU on Fri Sep 18, 2020 2:43 pm
I'm trying to use the BNO055 to provide orientation so I can correct the output of an array of lis3mdl magnetometers. My issue is that a lot of the time bno055.quaternion returns [None, None, None, None], which means I don't have the data to do the rotation correction. (I get lots of Nones even running the simple test example). I've tried the simple fix of asking multiple times until I get something that isn't None, but this is commonly taking more than 100 requests. Is there a way to get it to return useful data more frequently.
I set things up with
self._absOr = adafruit_bno055.BNO055_I2C(self._i2c)
self._absOr.mode = adafruit_bno055.IMUPLUS_MODE
and then read sometime later with
opBuf = self._absOr.quaternion
but as I say, even the simple test returns a lot of Nones
RossU
Re: BNO055 Quaternion returns None
by siddacious on Tue Sep 22, 2020 5:00 pm
The quaternion property is returning Nones because it is not enabled in the IMUPLUS_MODE.
If you take a look at the documentation for the mode property, it has a table of what is enabled in each mode:
[url]https://circuitpython.readthedocs.io/projects/bno055/en/latest/api.html#adafruit_bno055.BNO055.mode
[/url]
You have a few options, but the default NDOF_MODE will work
siddacious
by RossU on Wed Sep 23, 2020 8:29 am
Okay. I saw the system wouldn’t return absolute position, but the documentation I looked at suggested it would do relative position, which would have been good enough. Also, I think the NDOF mode is supposed to be relatively slow. When I tried it previously, I had to ask on average 7 times before I got a non None reply. Still, if that is what is required, I can work with that.
RossU
by gammaburst on Wed Sep 23, 2020 9:27 am
Hi RossU, you are correct, the BNO055 does provide relative quaternion in IMUPLUS mode.
Here's a working sketch for Arduino IDE. It's not CircuitPython, but maybe it will help you.
Notice that I use an additional output pin to reset the BNO055.
On an Arduino Uno it outputs 100 measurements per second in either IMUPLUS or NDOF mode.
#include <Adafruit_BNO055.h>
#define BNO_RST     11      // pin number of BNO055 RST
#define BAUDRATE    115200  // serial port baud rate
#define PERIOD_MS   10      // time between measurements, milliseconds
Adafruit_BNO055 bno = Adafruit_BNO055(1);
unsigned long tprev;
void setup(void)
  Serial.begin(BAUDRATE);
  Wire.begin();
  Wire.setClock(400000L);           // I2C speed
  digitalWrite(BNO_RST,0);
  pinMode(BNO_RST, OUTPUT);         // assert BNO RST
  delay(2);
  pinMode(BNO_RST, INPUT_PULLUP);   // deassert BNO RST
  delay(800);                       // allow time for BNO to boot
  bno.setMode(bno.OPERATION_MODE_IMUPLUS);
  delay(10);                        // allow time for BNO to switch modes
  tprev = millis();
void loop(void)
  imu::Quaternion q = bno.getQuat();
  Serial.print("Quaternion: ");
  Serial.print(q.w(), 4);  Serial.print(" ");
  Serial.print(q.x(), 4);  Serial.print(" ");
  Serial.print(q.y(), 4);  Serial.print(" ");
  Serial.print(q.z(), 4);  Serial.println("");
  while (millis() - tprev < PERIOD_MS);  // wait until next measurement
  tprev += PERIOD_MS;
gammaburst
by viennamike on Thu Apr 01, 2021 10:58 pm
siddacious wrote:The quaternion property is returning Nones because it is not enabled in the IMUPLUS_MODE.
[/url]
I believe this is incorrect, per the documentation. RELATIVE position IS available (including Euler Angles and Quaternion values from the chip. I think it's an error on Adafruit's part. They don't return values for IMUPLUS or M4G modes, but they should. In adafruit_bno055.py, add 0x08 and 0x0A to the list of values in the if statements in def euler and def quaternion. I'll submit an issue.
viennamike
