FRAM SPI device not found
by ArdeaSolutionsBelgium on Wed Sep 23, 2020 7:47 am
I'm using an "Adafruit SPI Non-Volatile FRAM Breakout - 4 Mbit / 512 KBytes - MB85RS4MT PID: 4719" combined with an "Adafruit Feather M4 Express - Featuring ATSAMD51 - ATSAMD51 Cortex M4 PID: 3857"
I'm using the standard provided source (see below) with lib version = "1.3.2"
i get the following error : "OSError: FRAM SPI device not found."
some suggestions? and yes i connected the wires like shown in the example ;)
wkr,
Stefan
"## Simple Example For CircuitPython/Python SPI FRAM Library
import board
import busio
import digitalio
import adafruit_fram
## Create a FRAM object.
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
cs = digitalio.DigitalInOut(board.D5)
fram = adafruit_fram.FRAM_SPI(spi, cs)
## Write a single-byte value to register address '0'
fram[0] = 1
## Read that byte to ensure a proper write.
## Note: 'read()' returns a bytearray
print(fram[0])
## Or write a sequential value, then read the values back.
## Note: 'read()' returns a bytearray. It also allocates
## a buffer the size of 'length', which may cause
## problems on memory-constrained platforms.
# values = list(range(100)) # or bytearray or tuple
# fram[0] = values
# print(fram[0:99])
Re: FRAM SPI device not found
by jerryn on Wed Sep 23, 2020 8:58 am
The error you are reporting sounds like a wiring issue. Even the old release should "see" the breakout.
Double check the pins -- make sure MISO/MOSI are not swapped.
Just a heads up -- For the 4Mbit breakout, you will need to get the version 1.3.3 release of the adafruit_fram library -- In todays (9/23/2020) bundle.
To get to the addresses above 8K you will need to set the max_size to 524288 ((or hex 0x80000) in the line:
fram = adafruit_fram.FRAM_SPI(spi, cs, max_size = 0x80000)
I don't represent Adafruit. Just trying to help.
jerryn
