ImportError: no module named 'serial'
by alpierce on Wed Sep 23, 2020 7:03 pm
trying to use example code for UART ranging module, Adafruit part # 4665. Fails to compile with error
code.py output:
File "code.py", line 2, in <module>
I can find no mention of a function module called "serial" in any of the documentation
There is no such library in the bundle
Have tried 5.3.1 and 6.0 beta
Does this function even exist?
import time
import serial
SERIAL_PORT = "/dev/ttyS15"   # or "COM4" or whatever
serialport = serial.Serial(SERIAL_PORT, 9600)
def read_me007ys(ser, timeout = 1.0):
    ts = time.monotonic()
    buf = bytearray(3)
    idx = 0
    while True:
        # Option 1, we time out while waiting to get valid data
        if time.monotonic() - ts > timeout:
            raise RuntimeError("Timed out waiting for data")
        c = ser.read(1)[0]
        #print(c)
        if idx == 0 and c == 0xFF:
            buf[0] = c
            idx = idx + 1
        elif 0 < idx < 3:
            buf[idx] = c
            idx = idx + 1
        else:
            chksum = sum(buf) & 0xFF
            if chksum == c:
                return (buf[1] << 8) + buf[2]
            idx = 0
    return None
while True:
    dist = read_me007ys(serialport)
    print("Distance = %d mm" % dist)
code.py output:
alpierce
Re: ImportError: no module named 'serial'
by siddacious on Wed Sep 23, 2020 7:54 pm
What board or computer are you trying to run this code with?
It looks like the example code is meant to be run on a computer using Python and the pyserial module.
I don't have one of these sensors so I can't test, but you should be able to replace the serial connection setup with code to use the UART class in the busio module
import board
import busio
serialport = busio.UART(board.TX, board.RX, baudrate=9600)
You'll of course need to hook then sensor up to the TX and RX pins of your board.
Remember! RX on the sensor goes to TX on the board. It's a common mistake I make regularly to connect to the pin with the same name.
Let me know if that works for you
siddacious
by alpierce on Wed Sep 23, 2020 8:15 pm
Thanks siddacious,
I was trying to run it on a Trinket M0, and an ItsyBitsy M4, so that explains it.
I just mis-read the Python as CircuitPython!
I saw the busio example in an older post for a GPS sensor, but thought it was deprecated or something.
I'll try it and let you know.
Anyway, thanks again for the quick reply!
alpierce
by alpierce on Wed Sep 23, 2020 8:34 pm
Oh well, more work to do yet, i'll keep you posted.
code.py output:
File "code.py", line 35, in <module>
File "code.py", line 18, in read_me007ys
TypeError: 'NoneType' object is not subscriptable
import time
import board
import busio
    buf = bytearray(3)
    idx = 0
    while True:
        c = ser.read(1)[0]
        #print(c)
            buf[0] = c
            idx = idx + 1
        elif 0 < idx < 3:
            buf[idx] = c
            idx = idx + 1
        else:
            if chksum == c:
            idx = 0
    return None
while True:
Reason: put code tags around code
alpierce
by alpierce on Thu Sep 24, 2020 2:25 pm
Enjoy
# CircuitPython code for Adafruit UART Ranging module P4665
# Al Pierce Sept 9, 2020
# Based on Adafruit CircuitPython_UART.py example code
import board
import busio
import digitalio
led = digitalio.DigitalInOut(board.D13)
led.direction = digitalio.Direction.OUTPUT
uart = busio.UART(board.TX, board.RX, baudrate=9600)
while True:
    data = uart.read(32)  # read up to 32 bytes
    if data is not None:
        led.value = True
        # convert bytearray to distance in mm
        distance = data[1] * 256 + data[2]
        # print distance in cm
        print(distance/10)
        led.value = False
alpierce
