LSM6DS33_data_visualisation
by pandeyashwani on Tue Sep 29, 2020 9:59 am
Hi
I am using lsm6ds33 breakout board for my project. I am using lsm6ds33 and raspberry pi for I2C Interface. Currently i have acquired raw data of acceleration and gyroscope.
I am try to visualise these raw data graphically. Since i am new to python can you please help me with suitable python code.
Sincerely
Ashwani
pandeyashwani
Re: LSM6DS33_data_visualisation
by mikeysklar on Wed Sep 30, 2020 6:44 pm
Hello Ashwani,
Since you are acquiring data already it might be possible to use the Web Serial API in your Chrome browser, but it would expect a serial port to read from.
https://learn.adafruit.com/how-to-fuse- ... visualizer
Another option to consider would be how the BN055 sensor uses WebGL to visual data from a Pi.
https://learn.adafruit.com/adafruit-bno ... gl-example
mikeysklar
by pandeyashwani on Thu Oct 01, 2020 3:17 am
Dear Mikeysklar
I am extremely thankfull for your response. Actually i am trying to visualise the 3D Acceleartion and 3D Gyroscope data graphically in real time. I want to use matplotlib
for that. Can you please tell me how i should do that. Below you can see my python code and raw data of 3D Acceleration and 3D Gyroscope in real time.
Sincerely Yours
Ashwani pandey
pandeyashwani
by mikeysklar on Thu Oct 01, 2020 10:25 am
I see the Jupyter notebook guide for this accelerometer is using matplotlib.
Is this close to what you are describing?
https://learn.adafruit.com/jupyter-on-a ... elerometer
mikeysklar
by siddacious on Thu Oct 01, 2020 12:54 pm
I'm unsure if it's what you're looking for, but the plotter in the Mu editor works well for visualizing data. I use it nearly daily!
You'll just need to configure your program to print out the tuple returned by the acceleration and gyro directly like so:
print(sensor.acceleration)
or
print(sensor.gyro)
once you see the raw tuples printed on the serial console, you can close it and open the mu plotter to see the charts :)
siddacious
by mikeysklar on Fri Oct 02, 2020 11:41 am
Thanks siddacious.
Ashwani had asked about using matplotlib so I was stearing him that way, but good tip on a third option to use the built-in Mu plotter. I've not used it myself.
mikeysklar
by pandeyashwani on Mon Oct 05, 2020 4:09 am
Dear mikeysklar and siddacious
I am extremely thankful for your support and help. It work for me. However, i am just getting real time 3D Acceleration, but i am not getting 3D Gyroscope in real time. I want to acquire and visualise acceleration and gyroscope value simulataneously in real time.
Please have a look.
Sincerely
Ashwani pandey
pandeyashwani
by pandeyashwani on Mon Oct 05, 2020 10:06 am
Can you please provide me a python code by which i can convert the time domain acceleration into frequency domain. As i have to analyse the frquency and its amplitude.
Sincerely Yours
Ashwani pandey
pandeyashwani
by pandeyashwani on Tue Oct 06, 2020 5:14 am
Can you please tell me how i can visualise frequency after this.
Sincerely Yours
Ashwani pandey
pandeyashwani
by mikeysklar on Tue Oct 06, 2020 5:26 pm
pandeyashwani -
Please try using a single print statement.
print(sensor.accelleration, sensor.gyro)
That should give you both acceleration and gyro data. You can learn a bit more by reading this Plotting Data with Mu guide:
https://codewith.mu/en/tutorials/1.0/plotter
If you want to get into data rate the accelerometer and gyro are using:
print(sensor.accelerometer_data_rate, sensor.gyro_data_rate)
More here about which values you can see from the sensor library:
https://circuitpython.readthedocs.io/pr ... t/api.html
mikeysklar
by pandeyashwani on Thu Oct 08, 2020 6:05 am
Hello Mikesklar
Thanks for your quick response. I am trying to analyse the frequency response of lsm6ds33 sensor, since i am learning python i actually dont know how to implement this in code
in order to read and analyse the frequency response. Please help.
Sincerely Yours
Ashwani
pandeyashwani
by pandeyashwani on Thu Oct 15, 2020 8:30 am
Hi Siddacious
Can you please suggets me how i can make this graph sinusoidal. I am getting a randam graph, so i am not able to interpret the graph of the data.
Sincerely Yours
Ashwani
pandeyashwani
