Benchmarks for CircuitPython?
by kevinjwalters on Sat Oct 10, 2020 7:50 am
Are there any benchmarks for CircuitPython? I noticed something in HackSpace recently (edition 34, page 67) and I was trying to reproduce the numbers in it which didn't look quite right to me for the two M4-based procesors mentioned, nRF52840 (64MHz) and SAMD51 (120MHz).
CircuitPython FP benchmark table from HackSpace Edition 34 page 67
Here's some very simple floating point tests, primary use here being to compare performance across boards. The speed difference here looks appropriate given the clock speeds of the two M4 boards. ALL running CircuitPython 5.3.1.
Feather M4 Express
Adafruit CircuitPython 5.3.1 on 2020-07-13; Adafruit Feather M4 Express with samd51j19
>>> import simple_benchmarks
>>> simple_benchmarks.run()
platform: MicroChip SAMD51
version: 3.4.0
modules: {'simple_benchmarks': <module 'simple_benchmarks' from 'simple_benchmarks.py'>}
001AdditionA: 1.511477s (330802.226067Hz)
002MultiplicationA: 1.517326s (329526.972771Hz)
003DivisionA: 1.584962s (315464.997292Hz)
version: 3.4.0
001AdditionA: 1.511183s (330866.622925Hz)
002MultiplicationA: 1.517409s (329509.019852Hz)
003DivisionA: 1.584792s (315498.876572Hz)
CLUE (alpha hardware)
Adafruit CircuitPython 5.3.1 on 2020-07-13; Adafruit CLUE nRF52840 Express with nRF52840
platform: nRF52840
version: 3.4.0
001AdditionA: 3.610917s (138468.933105Hz)
002MultiplicationA: 3.594544s (139099.681854Hz)
003DivisionA: 3.706118s (134912.061691Hz)
platform: nRF52840
version: 3.4.0
001AdditionA: 3.612694s (138400.876999Hz)
002MultiplicationA: 3.606740s (138629.317284Hz)
003DivisionA: 3.705397s (134938.311577Hz)
Circuit Playground Express (CPX)
Adafruit CircuitPython 5.3.1 on 2020-07-13; Adafruit CircuitPlayground Express with samd21g18
platform: Atmel SAMD21
version: 3.4.0
001AdditionA: 9.364471s (53393.297195Hz)
002MultiplicationA: 10.113869s (49437.060356Hz)
003DivisionA: 13.884789s (36010.622978Hz)
version: 3.4.0
001AdditionA: 9.364391s (53393.750191Hz)
002MultiplicationA: 10.113922s (49436.793327Hz)
003DivisionA: 13.884777s (36010.656357Hz)
Code is in https://github.com/kevinjwalters/circui ... chmarks.py
kevinjwalters
Re: Benchmarks for CircuitPython?
by tannewt on Mon Oct 12, 2020 4:51 pm
We don't maintain or track any ourselves. Generally, it can be a bit of a trap because there is always performance to gain at an increasing cost.
I've tweeted at Hackspace about how they got their numbers: https://twitter.com/tannewt/status/1315754129206042624
tannewt
by kevinjwalters on Fri Jan 08, 2021 8:42 am
The ESP32-S2 numbers also looked odd in that HackSpace benchmark but I've only just got a board with that chip to puts its floating point through its paces:
FeatherS2 (ESP32-S2)
sys.version: 3.4.0
sys.modules: {}
os.sysname: esp32s2
os.nodename: esp32s2
os.release: 6.0.0
os.version: 6.0.0 on 2020-11-16
os.machine: FeatherS2 with ESP32S2
001AdditionA: 1.4886s,1.3293s,1.4772s,1.3329s,1.4849s (14059Hz)
002MultiplicationA: 1.3424s,1.5280s,1.3663s,1.3788s,1.3277s (14403Hz)
003DivisionA: 1.9622s,1.9824s,1.9818s,1.9905s,1.9863s (10098Hz)
004ArchimedesPiA: 1.3958s,1.3141s,1.4156s,1.2751s,1.4064s (147Hz)
There's something curious going on with the addition and multiplication, it's almost like they are getting scheduled onto two different units running at different speeds.
micro:bit V1
sys.platform: microbit
sys.version: 3.4.0
os.sysname: microbit
os.nodename: microbit
os.release: 1.0.1
os.version: micro:bit v1.0.1+b0bf4a9 on 2018-12-13; MicroPython v1.9.2-34-gd64154c73 on 2017-09-01
os.machine: micro:bit with nRF51822
001AdditionA: 20.8069s,20.8069s,20.8070s,20.8069s,20.8070s (961Hz)
002MultiplicationA: 22.4981s,22.4982s,22.4982s,22.4982s,22.4982s (888Hz)
003DivisionA: 35.0681s,35.0681s,35.0682s,35.0682s,35.0682s (570Hz)
004ArchimedesPiA: 18.7679s,18.7679s,18.7679s,18.7680s,18.7679s (11Hz)
micro:bit V2
I'd assumed the nRF52833 would have very similar performance to nRF52840 as they are both down as "64 MHz Arm Cortex-M4 with FPU" but apparently not
sys.version: 3.4.0
sys.modules: {}
os.release: 2.0.0-beta.3
os.version: micro:bit v2.0.0-beta.3+d6c01d0 on 2020-12-21; MicroPython v1.13 on 2020-12-21
os.machine: micro:bit with nRF52833
001AdditionA: 7.6184s,7.6231s,7.6225s,7.6213s,7.6215s (2624Hz)
002MultiplicationA: 7.2355s,7.2386s,7.2354s,7.2372s,7.2362s (2764Hz)
003DivisionA: 9.2329s,9.2380s,9.2330s,9.2333s,9.2348s (2166Hz)
004ArchimedesPiA: 5.6066s,5.6113s,5.6098s,5.6072s,5.6111s (36Hz)
kevinjwalters
by kevinjwalters on Sat Jan 09, 2021 12:36 pm
6.1.0-rc0 has made the FeatherS2 more consistent and faster! Or perhaps time.monotonic_ns() was buggy on ESP32-S2 6.0.0 and these have been fixed??
sys.version: 3.4.0
sys.modules: {}
os.sysname: esp32s2
os.release: 6.1.0
os.version: 6.1.0-rc.0 on 2021-01-06
001AdditionA: 0.9988s,0.9986s,0.9985s,0.9986s,0.9985s (20028Hz)
002MultiplicationA: 1.0196s,1.0194s,1.0193s,1.0193s,1.0194s (19619Hz)
003DivisionA: 1.5855s,1.5853s,1.5852s,1.5854s,1.5853s (12616Hz)
004ArchimedesPiA: 1.3531s,1.3614s,1.3529s,1.3530s,1.3699s (147Hz)
005MixedBigIntA: 2.7977s,2.9087s,2.7851s,2.9026s,2.8022s (1268Hz)
kevinjwalters
by kevinjwalters on Thu Jan 14, 2021 10:27 am
kevinjwalters
by kevinjwalters on Sat Jan 23, 2021 7:09 pm
The new kid on the block:
sys.platform: rp2
sys.version: 3.4.0
sys.modules: {'simple_benchmarks': <module 'simple_benchmarks'>, 'rp2': <module 'rp2'>}
os.sysname: rp2
os.nodename: rp2
os.release: 1.13.0
os.version: v1.13-290-g556ae7914 on 2021-01-21 (GNU 10.2.0 MinSizeRel)
os.machine: Raspberry Pi Pico with RP2040
001AdditionA: 4.2262s,4.2260s,4.2261s,4.2261s,4.2261s (4732Hz)
002MultiplicationA: 4.2939s,4.2938s,4.2938s,4.2938s,4.2939s (4658Hz)
003DivisionA: 4.5120s,4.5119s,4.5119s,4.5119s,4.5120s (4433Hz)
004ArchimedesPiA: 3.0561s,3.0561s,3.0560s,3.0560s,3.0638s (65Hz)
005MixedBigIntA: 2.5699s,2.5777s,2.5773s,2.5697s,2.5770s (1398Hz)
kevinjwalters
