Matrixportal MQTT
Matrixportal MQTT
by kwalkerk on Wed Oct 14, 2020 1:46 pm
How do I get the MatrixPortal to run MQTT. I've tried everything and cannot get it working. Seems to hang up on setting a socket. I'm trying to connect to a broker on my local network.
Ken
kwalkerk
Re: Matrixportal MQTT
by dastels on Wed Oct 14, 2020 1:56 pm
dastels
by kwalkerk on Wed Oct 14, 2020 2:13 pm
I have. Can't get past line 226:
# Initialize MQTT interface with the esp interface
MQTT.set_socket(socket, esp)
kwalkerk
by dastels on Wed Oct 14, 2020 3:36 pm
Odd there doesn't look to be anything that could get locked up. Can you post yourt code or a link if you're using an example verbatim?
dastels
by kwalkerk on Wed Oct 14, 2020 3:51 pm
The sample code link you referred to is for the PyPortal, not the MatrixPortal. Far too much modification for me. All of the stuff I do for the MatrixPortal works fine until I add MQTT. Just can't get past the need to initialize MQTT.set_socket(socket, esp).
kwalkerk
by dastels on Wed Oct 14, 2020 4:35 pm
Hmm.. that shouldn't be different. Let me fiddle with it a bit.
dastels
by kwalkerk on Wed Oct 14, 2020 5:35 pm
kwalkerk
by dastels on Thu Oct 15, 2020 10:12 am
It would help if you could post your code.
dastels
by kwalkerk on Thu Oct 15, 2020 12:37 pm
Below is the code. I get an error when I try to initialize the MatrixPortal on line 93.
# Quote board matrix display
import time
import board
import terminalio
from adafruit_matrixportal.matrixportal import MatrixPortal
import busio
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
import adafruit_minimqtt.adafruit_minimqtt as MQTT
broker_ip = "10.0.1.32"
ourTopic = 'frontporchmusic'
mqtt_message = ""
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets)
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connected(client, userdata, flags, rc):
    # This function will be called when the client is connected
    # successfully to the broker.
    print("Connected to Adafruit IO! Listening for topic changes on %s" % ourTopic)
    # Subscribe to all changes on the onoff_feed.
    client.subscribe(ourTopic)
def disconnected(client, userdata, rc):
    # This method is called when the client is disconnected
    print("Disconnected from Adafruit IO!")
def message(client, topic, message):
    global mqtt_message
    # This method is called when a topic the client is subscribed to
    # has a new message.
    print("New message on topic {0}: {1}".format(topic, message))
    mqtt_message = message
# Connect to WiFi
print("Connecting to WiFi...")
wifi.connect()
print("Connected!")
# Set up a MiniMQTT Client
mqtt_client = MQTT.MQTT(
    broker=broker_ip,
    port = 1883
# Setup the callback methods above
mqtt_client.on_connect = connected
mqtt_client.on_disconnect = disconnected
mqtt_client.on_message = message
# Connect the client to the MQTT broker.
print("Connecting to Adafruit IO...")
mqtt_client.connect()
# --- Display setup ---
matrixportal = MatrixPortal(status_neopixel=board.NEOPIXEL, debug=True)
# Create a new label with the color and text selected
matrixportal.add_text(
    text_font=terminalio.FONT,
    text_position=(0, (matrixportal.graphics.display.height // 2) - 1),
    scrolling=True,
# Static 'Connecting' Text
    text_position=(2, (matrixportal.graphics.display.height // 2) - 1),
SCROLL_DELAY = 0.04
UPDATE_DELAY = 600
def update_data():
    print("Updating data from Adafruit IO")
    matrixportal.set_text("Connecting", 1)
update_data()
last_update = time.monotonic()
matrixportal.set_text(" ", 1)
while True:
    # Set the quote text
    matrixportal.set_text(mqtt_message)
    # Set the text color
    matrixportal.set_text_color(0xFFFFFF)
    # Scroll it
    matrixportal.scroll_text(SCROLL_DELAY)
    if time.monotonic() > last_update + UPDATE_DELAY:
        update_data()
kwalkerk
