🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
CP Build error make python command not found - Solved
by ghhann on Sat Oct 24, 2020 9:57 am
I followed the update my local git pull of the CP firmware by the following (Im running ubuntu 20.04 in WSL2)
git pull
git submodule sync
git submodule update --init
this is the arm tool chain
ghhann@ghhann-PC:~/Programs/circuitpython/ports/atmel-samd$ which arm-none-eabi-gcc
/home/ghhann/Programs/gcc-arm-none-eabi-9-2019-q4-major/bin/arm-none-eabi-gcc
I get the following error when building the firmware for circuitplayground_express
ghhann@ghhann-PC:~/Programs/circuitpython/ports/atmel-samd$ make BOARD=circuitplayground_express
Use make V=1, make V=2 or set BUILD_VERBOSE similarly in your environment to increase build verbosity.
FREEZE ../../frozen/Adafruit_CircuitPython_BusDevice ../../frozen/Adafruit_CircuitPython_CircuitPlayground ../../frozen/Adafruit_CircuitPython_HID ../../frozen/Adafruit_CircuitPython_LIS3DH ../../frozen/Adafruit_CircuitPython_NeoPixel ../../frozen/Adafruit_CircuitPython_Thermistor
make: python: Command not found
arm-none-eabi-gcc: error: missing argument to '-flto='
make: *** [Makefile:409: build-circuitplayground_express/firmware.elf] Error 1
create a symbolic link
ghhann@ghhann-PC:/usr/bin$ sudo ln /usr/bin/python3 python
Then test again
250336 bytes used, 3104 bytes free in flash firmware space out of 253440 bytes (247.5kB).
11392 bytes used, 21376 bytes free in ram for stack and heap out of 32768 bytes (32.0kB).
Converting to uf2, output size: 500736, start address: 0x2000
Wrote 500736 bytes to build-circuitplayground_express/firmware.uf2
And it should now work...
ghhann
Re: CP Build error make python command not found - Solved
by siddacious on Mon Nov 02, 2020 3:52 pm
Glad you got it sorted, thanks for sharing! I'm sure others will find this useful
siddacious
by danhalbert on Thu Nov 12, 2020 4:24 pm
You can also do `sudo apt install python-is-python3`, which creates the link you are talking about, but does it in a controlled way, as a package.
danhalbert
