🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
SD CARD access on arduino MKR ZERO
by seidler on Tue Nov 10, 2020 1:05 am
I'm looking for complete documentation for the adafruit_sdcard library, or (even better!) perhaps an example of write/read to the SD card for an arduino MKR ZERO.
seidler
Re: SD CARD access on arduino MKR ZERO
by siddacious on Tue Nov 10, 2020 11:36 pm
The main page of the docs is here, which includes an example of a basic write to an SD card:
https://circuitpython.readthedocs.io/pr ... en/latest/
For the MKR Zero, the SPI setup line will need to refer to the SPI pins that are dedicated to the SD card:
 spi = busio.SPI(board.SD_SCK, board.SD_MOSI, board.SD_MISO)
It is likely also worth reading the 'storage' section of the CircuitPython Essentials guide:
https://learn.adafruit.com/circuitpytho ... on-storage
siddacious
by seidler on Wed Nov 11, 2020 3:32 pm
Thanks, I'll give it a shot. I had seen the discussion at the first link that you posted, but it appeared to be specific to the SD card add-on board for other adafruit products so it wasn't clear how to generalize. If/when I get it to work, I'll post a code snippet here.
Thanks again.
seidler
