🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
graphical plotting of lsm6ds33
by pandeyashwani on Thu Nov 12, 2020 8:21 am
Hello i am trying to visualize the lsm6ds33 acceleration sensor data. But i am getting blank graph can you please
help. Whats wrong with the code.
Sincerely
MCP2221_Test (1).py
(5.74 KiB) Downloaded 3 times
pandeyashwani
Re: graphical plotting of lsm6ds33
by mikeysklar on Fri Nov 13, 2020 2:48 pm
Have you made any changes to our stock example code from this guide:
https://learn.adafruit.com/jupyter-on-a ... elerometer
Which platform are you running on? Did you have any problems with setup?
https://learn.adafruit.com/circuitpytho ... 2221/setup
mikeysklar
by pandeyashwani on Fri Nov 13, 2020 3:00 pm
Hello Mikeysklar
Actually, I have used Jupiter notebook for that, I have installed all the required libraries for MCP2221, but I am getting blank graph without any data.
I have used Mu editor to visualise the raw data using a plotter. In Mu editor, I am getting raw data but I am not able to acquire time base on X - axis.
So my main intention is to visualise the data in Y-axis and Time in X-axis.
Sincerely
pandeyashwani
by mikeysklar on Sat Nov 14, 2020 3:06 pm
@pandeyashwani,
Which guide are you following for the Jupyter visualizer + MCP2221 usage?
I don't think Mu can handle more than one axis (y-only) for now. Just a stream of sensor data without x-axis time stamps.
Were you using following Adafruit SensorLab Guide? That seems like the type of Jupyter + LSM6D with 2-axis charts you are going for:
https://learn.adafruit.com/adafruit-sen ... th-jupyter
mikeysklar
by pandeyashwani on Sun Nov 15, 2020 2:20 pm
Hi Mikeysklar
I am extremely thanks for helping me. Actually, I am using this guide,
Moreover, my intention is to visualise the acceleration data with respect to time. Precisely, I want to visualise the acceleration data on Y-axis and Time in X- axis.
I am using a raspberry pi with LSM6DS33 sensor. I am a beginner in Python so I need your help.
Sincerely Yours
Ashwani pandey
pandeyashwani
by mikeysklar on Mon Nov 16, 2020 8:11 pm
Ashwani,
Take a look at the Magnetometer calibration. There is an example of plotting multiple axis that could be something you can practice with the LSM6DS33 you have.
Also to pull code from another on-line example you could start your own millis counter to get an idea of time for the x-axis:
https://ozzmaker.com/berryimu/
startInt = mymillis();
//Each loop should be at least 20ms.
while(mymillis() - startInt < 20)
        usleep(100);
mikeysklar
by pandeyashwani on Tue Nov 17, 2020 9:19 am
Good Evening Mikeysklar
Can you please have a look into my code why i am not getting any graph. Can you please suggest. I want to visualise the raw data of accelerometer in real time.
Sincerely
pandeyashwani
by pandeyashwani on Tue Nov 17, 2020 9:23 am
Please suggest what changes i should make, so that i can visualise the acceleration value in real time.
sincerely
pandeyashwani
by pandeyashwani on Tue Nov 17, 2020 10:43 am
Please examine both the codes given above and please suggest what changes i should make in the code
Sincerely
pandeyashwani
by tannewt on Tue Nov 17, 2020 6:26 pm
Take a look at this guide for how to use CircuitPython libraries on Raspberry Pi: https://learn.adafruit.com/circuitpytho ... rypi-linux
It'll tell you how to construct an I2C bus on Raspberry Pi.
tannewt
by pandeyashwani on Wed Nov 18, 2020 3:02 am
Good Morning Tannewt
Thanks for your suggestions. I already installed all the required libraries of adafruit blinka and I am getting data from the LSM6DS33.
My intention is to plot the graph of LSM6DS33 in real time, with acceleration on Y - axis and Time on X - axis. Further, I want to log
data as csv file and plot the real time graph using Matplotlib. I am struggling to achieve this can you please help.
Sincerely Yours
pandeyashwani
by pandeyashwani on Wed Nov 18, 2020 3:11 am
This is preliminary python code to read LSM6DS33 data.
Sincerely
pandeyashwani
