🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
CircuitPython 6.0.0 Release Candidate 2 Released!
by danhalbert on Thu Nov 12, 2020 12:00 pm
This is the third release candidate of CircuitPython 6.0.0. We don't know of any stability issues overall. See port status below for more stability detail. If you find any issues with it, please file an issue. If no issues are found in the near future, we'll release this version as stable.
Download from circuitpython.org
Downloads are available from circuitpython.org. The site makes it easy to select the correct file and language for your board. The downloads page is here. Downloads are no longer available from the GitHub release pages because of the large number of files for each release.
Installation
To install follow the instructions in our new Welcome to CircuitPython! guide. To install the latest libraries, see this page in that guide.
Try the latest version of the Mu editor for creating and editing your CircuitPython programs and for easy access to the CircuitPython serial connection (the REPL).
Port status
CircuitPython has a number of "ports" that are the core implementation for a variety of microcontroller families. Stability varies on a per-port basis. As of this release, atmel-samd, nrf, and stm for the F4 family are stable. cxd56, esp32s2, and stm for other chip families are being actively improved but may be missing functionality and have bugs. litex and mimxrt10xx are in an alpha state and will have bugs and missing functionality.
New features and improvements since 6.0.0 Release Candidate 0
Full commit log is here.
Fixes and enhancements
  • RGBMatrix: validate bit-depth argument in constructor (#3661). Thanks @aocole for the issue, @jepler for the fix, and @FoamyGuy for testing.
  • Update protomatter library, used for RGBMatrix (#3666). Thanks @MaxMckinney for the issue, @jepler for the fix.
Board- and port-specific changes
  • Nothing in this release.
Documentation
  • No changes in this release.
Internals and build process
Breaking changes since 5.x
  • i2cslave is now i2cperipheral and the class in it is changed as well.
  • The stop kwarg has been removed from I2C.writeto(). If no stop is desired, then use writeto_then_readfrom.
  • The default speed of busio.I2C and board.I2C is now 100khz, not 400khz as before. Use busio.I2C to set the speed explicitly. #3471 Thanks @caternuson, @ladyada, @hierophect and @tannewt
  • _bleio.ConnectionError has been removed. Code will now raise the native ConnectionError instead.
New boards since 6.0.0-rc.1
  • No new boards in this release.
Known issues
Thank you to all who used, tested, and contributed since 6.0.0 Release Candidate 1, including @jepler, @aocole, @FoamyGuy, @tannewt, @MaxMcKinney, and many more on Discord. Join us on the Discord chat to collaborate.
Documentation
Documentation is available in readthedocs.io.
This release is based on MicroPython 1.9.4 @25ae98f. Support upstream MicroPython by purchasing a PyBoard (from Adafruit here) or sponsoring MicroPython on GitHub.
Translations
One important feature of CircuitPython is translated control and error messages. With the help of fellow open source project Weblate, we're making it even easier to add or improve translations. Sign in with an existing account such as Github, Google or Facebook and start contributing through a simple web interface. No forks or pull requests needed!
Troubleshooting
Check out this guide for info on common problems with CircuitPython. If you are still having issues, then post to the Adafruit Support Forums and join Discord.
Assets
Builds are no longer stored as assets on this release page, because there are too many of them. Please see the Download from circuitpython.org section above.
danhalbert
