🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
Surprised by how slow i2c commands for MCP23017 are.
by SeattleDavid on Mon Nov 16, 2020 11:42 pm
I was surprised by how slow i2c was on an Adafruit Metro ESP32-S2 when talking to an MCP23017 I/O chip. I am only getting about 30 I/O (writes) per second.
Perhaps this is considered normal (I am a newbie) but I would have expected it to be far faster...with i2c running at 100 or 400 kHz, and commands being just a few bytes, it seems like I should have been able to turn 16 relays on in less than half a second.
Here is the test code that I used...it would do 100 loops in 6 seconds (each loop does an ON and an OFF, so this is 200 i2c relay commands in 6 seconds, hence the 30-per-second determination.)
This means that controlling i2c devices is pretty limiting in terms of how many or how fast.
This this normal/typical/reasonable?
import time
import board
import busio
from digitalio import Direction
#import digitalio
import time
from adafruit_mcp230xx.mcp23017 import MCP23017
i2c = busio.I2C(board.SCL, board.SDA)
mcp0x27 = MCP23017(i2c,address=0x27)
index=0
loopCount=0
relay=0
relayBuzzPin=7
relayBuzz=mcp0x27.get_pin(relayBuzzPin)
relayBuzz.direction = Direction.OUTPUT
relayBuzz.value = True # high logic level
time.sleep(1)
relayBuzz.value = False # low logic level
time.sleep(1)
time.sleep(1)
while True:
    loopCount += 1
    if (loopCount % 100) == 0:
        print("Loop #",loopCount)
print("Done")
SeattleDavid
Re: Surprised by how slow i2c commands for MCP23017 are.
by tannewt on Tue Nov 17, 2020 6:22 pm
It's hard to say what is typical. I'd suggest comparing it against the performance of a SAMD51 doing the same thing. We're seeing some weirdness with I2C on ESP32-S2 now and that might be related.
Also note that in 6.x we default to 100khz. So, you'll need to set it to 400khz if you want it faster.
tannewt
by SeattleDavid on Tue Nov 17, 2020 6:38 pm
So little data is being sent—a few bytes—that I can’t imagine it makes any difference if you transmit at 100,000 bits or 400,000 bits per second.
It still seems quite odd that you can only send 30 i2c commands/packets per second. It means you cant do very much I/O in a second.
I benchmarked the Metro ESP32-S2 and it is executing something crazy like 100,000 lines per second...shockingly fast.
But only being able to do 30 I/O per second is concerning.
SeattleDavid
by SeattleDavid on Sun Nov 22, 2020 6:04 pm
30 i2c commands—maximum—per second seems to be so slow as to make it nearly useless.
It would take a minimum of 1/2 second to turn on all outputs of a single MCP23017.
The problem is clearly not i2c Buss speed, so what the heck is making i2c I/O so hideously slow?
SeattleDavid
