🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
PyPortal Titano Quote Display
by jammininmypjs on Wed Nov 18, 2020 8:17 pm
I am trying to get this project: https://learn.adafruit.com/pyportal-adafruit-quote-board/code-pyportal-with-circuitpython running on the pyportal titano, but when I save the file I get the following error:
  File "code.py", line 23, in <module>
  File "adafruit_pyportal.py", line 251, in __init__
  File "adafruit_pyportal.py", line 249, in __init__
  File "adafruit_pyportal.py", line 575, in play_file
AttributeError: 'module' object has no attribute 'WaveFile'
I made sure to download the uf2 for the Titano
jammininmypjs
Re: PyPortal Titano Quote Display
by dastels on Wed Nov 18, 2020 8:48 pm
Have you made sure CP and all the modules are up to date? I.e. the latest 6.x versions.
dastels
by jammininmypjs on Wed Nov 18, 2020 9:50 pm
Yes they are all the latest versions
jammininmypjs
by dastels on Thu Nov 19, 2020 11:10 am
And you have installed the PyPortal build of CircuitPython?
dastels
by jammininmypjs on Thu Nov 19, 2020 11:21 am
https://circuitpython.org/board/pyportal_titano/ this is where I got circuitpython. It was for PyPortal Titano
jammininmypjs
by dastels on Thu Nov 19, 2020 11:47 am
OK. I just updated CP, installed the required modules from the latest 6.x bundle (Nov 18 2020), and the project files. It works fine... hmmm
CP is:
Adafruit CircuitPython 6.0.0 on 2020-11-16; Adafruit PyPortal Titano with samd51j20
dastels
by jammininmypjs on Thu Nov 19, 2020 11:52 am
I'll start from scratch at lunch and see if I can get it working
jammininmypjs
by jammininmypjs on Thu Nov 19, 2020 1:31 pm
Nope same thing. I redownloaded circuit python, hit the reset button twice and moved that over. I took a picture of my libraries and such if that helps
jammininmypjs
by dastels on Thu Nov 19, 2020 10:08 pm
You would appear to have a bunch of old module files in lib.
Replace them with ones from the latest 6.x bundle.
And to confirm, you have the latest CircuitPython 6.0.0 installed?
dastels
by jammininmypjs on Fri Nov 20, 2020 6:30 am
Okay I will give that a shot. I do have 6.0.0 for circuit python
jammininmypjs
by jammininmypjs on Fri Nov 20, 2020 6:59 am
Oh awesome that did it, thank you for your help! Sorry I didn't recognize there were old modules in here
jammininmypjs
by dastels on Fri Nov 20, 2020 10:18 am
I've made a habit of downloading the latest bundle every few days and deleting & replacing modules on the project I'm working on. It helps avoid getting things out of sync.
dastels
by mrbluegrass on Wed Dec 02, 2020 3:30 pm
Hi I am trying to get this working on my new Titano as well with not much luck.. BUT first: the demo code has nothing to connect to WiFi ? how does this even work with out that code ? I assume I should just copy some other wifi connect (manager) stuff into if first?
mrbluegrass
by dastels on Wed Dec 02, 2020 3:55 pm
mrbluegrass wrote:Hi I am trying to get this working on my new Titano as well with not much luck.. BUT first: the demo code has nothing to connect to WiFi ? how does this even work with out that code ? I assume I should just copy some other wifi connect (manager) stuff into if first?
It would be appreciated if you created a new thread for your question.
dastels
