🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
CIrcuitPython 6.1.0 Beta 1 released!
by tannewt on Thu Nov 19, 2020 10:26 pm
From the GitHub release page:
This is the second beta release of 6.1.0. (This first was broken.) It includes many changes that were done while 6.0.0 release candidates were in pre-release. Please use 6.0.x if you need a stable version of CircuitPython on all ports except ESP32-S2. Please use this release or newer for the ESP32-S2. See port status below for more stability details.
Download from circuitpython.org
Downloads are available from circuitpython.org. The site makes it easy to select the correct file and language for your board. The downloads page is here. Downloads are no longer available from the GitHub release pages because of the large number of files for each release.
Installation
To install follow the instructions in our new Welcome to CircuitPython! guide. To install the latest libraries, see this page in that guide.
Try the latest version of the Mu editor for creating and editing your CircuitPython programs and for easy access to the CircuitPython serial connection (the REPL).
Port status
CircuitPython has a number of "ports" that are the core implementation for a variety of microcontroller families. Stability varies on a per-port basis. As of this release, atmel-samd, nrf, and stm for the F4 family are stable. cxd56, esp32s2, and stm for other chip families are being actively improved but may be missing functionality and have bugs. litex and mimxrt10xx are in an alpha state and will have bugs and missing functionality. For all unstable ports, please use the latest pre-release.
New features and improvements since 6.0.0
All ports
  • Added grayscale E-Ink support. (IL0373 control chip.) Thanks to @tannewt
  • Added support for transparent_color support in ColorConverter. Allows transparency with full color bitmaps. Thanks to @jensechu
  • Fix accumulating tracebacks in REPL. Thanks to @DavePutz
  • Luma computation for grayscale conversion corrected. Thanks to @tannewt
  • Fixed unhiding a TileGrid. Thanks to @FoamyGuy
  • Fixed sharp memory display memory error. Thanks to @jepler
  • Added native binascii to most boards. Thanks to @dhalbert
  • README typo fix. Thanks to @ehagerty
  • Stub (.pyi) fixes and CI check added. Thanks to @sw23
  • Translation updates for French, Portuguese (Brazil), and Swedish. Thanks to @bergdahl, @Edrig, @hexthat, @jepler, and @wtuemura.
ESP32-S2
  • Fix TLS certificate errors when root certificate is signed by SHA-1. (Fixes io.adafruit.com and others.) Thanks to @jepler, @tannewt and @bennyE
  • time.sleep() can now be interrupted by CTRL-C. Thanks to @DavePutz
  • touchio, rotaryio, watchdog, and countio support added. Thanks to @microdev1
  • canio support added. Thanks to @jepler
  • Added more Network parameters. Thanks to @astrobokonon
  • Fix I2C crashing. Thanks to @jepler
  • Fixed brief AP mode when starting wifi. Thanks to @BennyE
  • Fixed stack size. Thanks to @jepler
  • Fixed Socket.recv behavior to return available bytes immediately when fewer than requested. Thanks to @tannewt
  • Fixed concurrent NeoPixel strip use. Thanks to @hierophect and @ladyada
  • Fixed wifi reset. Thanks to @astrobokonon
  • Add recv_into argument size check. Thanks to @gamblor21
  • Added native display init for MagTag eInk display. Thanks to @tannewt and @ladyada
  • Fixed SCL and SDA pins for UnexpectedMaker FeatherS2. Thanks to @askpatrickw
  • Add default SPI, UART and I2C busses for UnexpectedMaker FeatherS2 and microS2. Thanks to @FoamyGuy and @microdev1
  • Added IO pin naming to Metro ESP32-S2. Thanks to @kattni and @ladyada
  • ESP32-S2 README improvements. Thanks to @hierophect
See the 6.0.0 release notes for breaking changes since 5.x.
New boards since 6.0.0
  • Adafruit MagTag Thanks to @tannewt
  • Targett Module Clip W ROOM Thanks to @targett363
  • Targett Module Clip WROVER Thanks to @targett363
  • AtelierDuMaker Breakout NRF52840 v1 Thanks to @Edrig
Known issues
Thank you to all who used, tested, and contributed since 6.0.0. Join us on the Discord chat to collaborate.
Documentation
Documentation is available in readthedocs.io.
This release is based on MicroPython 1.9.4 @25ae98f. Support upstream MicroPython by purchasing a PyBoard (from Adafruit here) or sponsoring MicroPython on GitHub.
Translations
One important feature of CircuitPython is translated control and error messages. With the help of fellow open source project Weblate, we're making it even easier to add or improve translations. Sign in with an existing account such as Github, Google or Facebook and start contributing through a simple web interface. No forks or pull requests needed!
Troubleshooting
Check out this guide for info on common problems with CircuitPython. If you are still having issues, then post to the Adafruit Support Forums and join Discord.
Assets
Builds are no longer stored as assets on this release page, because there are too many of them. Please see the Download from circuitpython.org section above.
tannewt
Re: CIrcuitPython 6.1.0 Beta 1 released!
by FriehoffT on Fri Nov 20, 2020 3:52 am
I have successfully installed CIrcuitPython 6.1.0 Beta 1 on a MagTag as a *bin file via esp_tool.
Note: I was unable to put the MagTag into Bootloader mode.
I tried the double tap many times and also my favourite:
import microcontroller
microcontroller.on_next_reset(microcontroller.RunMode.BOOTLOADER)
microcontroller.reset()
does not work. After .reset() the board "disappears" but does not come back.
Is this not supported? At this time?
FriehoffT
by tannewt on Mon Nov 23, 2020 5:42 pm
Double tap should work if you load TinyUF2 onto it separately.
I don't believe `on_next_reset` is implemented yet. Please file an issue for it here: https://github.com/adafruit/circuitpython/issues
Thanks for testing the beta!
tannewt
by marine_hm on Tue Nov 24, 2020 10:23 pm
I'm an amateur hobbyist, playing around with wifi modules. I love the little Wemos D-1 Minis(ESP8266). Looks like they are being squeezed out by big brother LOLIN ESP32 modules. I was able to program ESP8266 modules using the Arduino IDE. I have two ESP32 modules now. Neither one can I get to connect to my windows 7 PC with Arduino IDE. What is your recommendation for the best method of connecting and programming an ESP32? I also have a Raspberry Pi 3b if that's a better option.
Thanks. Nick
marine_hm
by tannewt on Wed Nov 25, 2020 5:46 pm
Hi Nick,
Please start a separate thread in the appropriate forum. Your question is unrelated to CircuitPython.
~Scott
tannewt
