🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
Does PyPortal support BLE?
by shawng on Sat Nov 21, 2020 1:29 pm
I wanted to try https://learn.adafruit.com/adafruit-pyp ... python-ble but I keep getting the error... File "adafruit_airlift/esp32.py", line 170, in start_bluetooth
Attribute: 'module' object has no attribute 'ESP_TX'
I loaded the libraries:
* adafruit_airlift
* adafruit_ble
And I used with NINA_W102-1.7.1.bin and both adafruit-circuitpython-pyportal-en_US-6.0.0.uf2 / adafruit-circuitpython-pyportal-en_US-6.1.0-beta.1.uf2.
The specs do not say anything about bluetooth... maybe it is just not available on this device. https://www.adafruit.com/product/4116#technical-details. However the setup page https://learn.adafruit.com/adafruit-pyp ... python-ble mentioned pyportal having everything wired up... so I was not sure.
shawng
Re: Does PyPortal support BLE?
by dastels on Sat Nov 21, 2020 4:09 pm
PyPortals are WiFi devices, not Bluetooth.
dastels
by shawng on Sat Nov 21, 2020 4:22 pm
Thanks. I was not clear if we just needed to reflash the ESP to access BLE mode instead of WIFI mode.
It's easy to use Adafruit AirLift ESP32 co-processor boards for Bluetooth Low Energy (BLE) with CircuitPython. When you reset the ESP32, you can put it in WiFi mode (the default), or in BLE mode; you cannot use both modes simultaenously. from https://learn.adafruit.com/adafruit-air ... python-ble
And the data sheet of the ESP chip in my PyPortal mentions BLE... https://www.espressif.com/sites/default ... eet_en.pdf
shawng
by dastels on Sat Nov 21, 2020 5:18 pm
Ah. Ok, that's more advanced usage. As typically used in projects, the PyPortals are Wifi based.
dastels
by jerryn on Sat Nov 21, 2020 5:26 pm
You will need to update the ESP32 Firmware to access the BLE features. See https://learn.adafruit.com/adafruit-airlift-breakout/circuitpython-ble#update-the-airlift-firmware-3076330-14
jerryn
