🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
Metro ESP32-S2 crash on reload with I2C and WiFi
by hsimons on Sat Nov 21, 2020 2:58 pm
I am having an issue on the Metro ESP32-S2 running CircuitPython 6.1.0-beta.1. If I initialize I2C (busio.I2C) the board appears to hang/crash when executing wifi.radio.connect after a reload. It works fine after a hard reset but just the once.
If I comment out the busio.I2C line, I can do repeated reloads and wifi.radio.connect executes fine. I2C alone seems stable as well... I left the board running overnight reading the pressure from 15 sensors I've been testing and it was fine. I am only seeing this issue when using WiFi and I2C simultaneously.
Below is the slimmed down code I've been using for troubleshooting.
import board
import time
import wifi
import busio
from secrets import secrets
time.sleep(2)
print("Connecting to %s"%secrets["ssid"])
wifi.radio.connect(secrets["ssid"], secrets["passphrase"])
print("Connected to %s!"%secrets["ssid"])
print("My IP address is", wifi.radio.ipv4_address)
time.sleep(2)
# Create I2C bus as normal
i2c = busio.I2C(board.SCL, board.SDA)
hsimons
Re: Metro ESP32-S2 crash on reload with I2C and WiFi
by tannewt on Mon Nov 23, 2020 6:18 pm
Thanks for the report! We've known about this issue for a little while but have had trouble tracking it down.
I believe this is the same issue: https://github.com/adafruit/circuitpython/issues/3743
Please follow that issue to see when we think we have a fix. Thanks!
tannewt
by hsimons on Tue Nov 24, 2020 1:15 pm
Thanks Scott... it appears it could very well be the same issue. I've subscribed to that thread as you've suggested.
Howard
hsimons
