RFM9x Lora and Sleep Mode(s)? Lipo uptime very short
Re: RFM9x Lora and Sleep Mode(s)? Lipo uptime very short
* The Things Network - Sensor Data Example
* Example of sending a valid LoRaWAN packet with DHT22 temperature and
* humidity data to The Things Networ using a Feather M0 LoRa.
* Learn Guide: https://learn.adafruit.com/the-things-network-for-feather
* Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
* Copyright (c) 2018 Terry Moore, MCCI
* Copyright (c) 2018 Brent Rubell, Adafruit Industries
* Permission is hereby granted, free of charge, to anyone
* obtaining a copy of this document and accompanying files,
* to do whatever they want with them without any restriction,
* including, but not limited to, copying, modification and redistribution.
* NO WARRANTY OF ANY KIND IS PROVIDED.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <Wire.h>;
#include <Adafruit_SleepyDog.h>
//integrate the cayene payload (and an "n" to cayene)
#include <CayeneLPP.h>
CayeneLPP lpp(51);
//Sensor Library
#include <Adafruit_MPL115A2.h>
Adafruit_MPL115A2 mpl115a2;
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
#define VBATPIN A7
// For normal use, we require that you edit the sketch to replace FILLMEIN
// with values assigned by the TTN console. However, for regression tests,
// we want to be able to compile these scripts. The regression tests define
// COMPILE_REGRESSION_TEST, and in that case we define FILLMEIN to a non-
// working but innocuous value.
#ifdef COMPILE_REGRESSION_TEST
#define FILLMEIN 0
#else
#warning "You must replace the values marked FILLMEIN with real values from the TTN control panel!"
#define FILLMEIN (#dont edit this, edit the lines that use FILLMEIN)
#endif
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8] = { xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8] = { xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx };
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from the TTN console can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = { xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx, xxxx };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
// payload to send to TTN gateway
static uint8_t payload[5];
static osjob_t sendjob;
[color=#FFFF00]// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 600;[/color]
// Pin mapping for Adafruit Feather M0 LoRa
const lmic_pinmap lmic_pins = {
.nss = 8,
// .nss = 11,
.rxtx = LMIC_UNUSED_PIN,
.rst = 4,
// .rst = 12,
.dio = {3, 6, LMIC_UNUSED_PIN},
// .dio = {5, 6, LMIC_UNUSED_PIN},
.rxtx_rx_active = 0,
.rssi_cal = 8, // LBT cal for the Adafruit Feather M0 LoRa, in dB
.spi_freq = 8000000,
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
break;
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
break;
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
break;
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
break;
case EV_JOINING:
Serial.println(F("EV_JOINING"));
break;
case EV_JOINED:
Serial.println(F("EV_JOINED"));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("artKey: ");
for (size_t i=0; i<sizeof(artKey); ++i) {
if (i != 0)
Serial.print("-");
Serial.print(artKey[i], HEX);
Serial.println("");
Serial.print("nwkKey: ");
for (size_t i=0; i<sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print("-");
Serial.print(nwkKey[i], HEX);
Serial.println("");
// Disable link check validation (automatically enabled
// during join, but because slow data rates change max TX
// size, we don't use it in this example.
LMIC_setLinkCheckMode(0);
break;
|| This event is defined but not used in the code. No
|| point in wasting codespace on it.
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
break;
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
break;
break;
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.txrxFlags & TXRX_ACK)
Serial.println(F("Received ack"));
if (LMIC.dataLen) {
Serial.println(F("Received "));
Serial.println(LMIC.dataLen);
Serial.println(F(" bytes of payload"));
// Schedule next transmission
//os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
do_send(&sendjob);
[color=#FFFF00]for (int i=0; i<int(TX_INTERVAL/8); i++) {
// Use library from https://github.com/rocketscream/Low-Power
//LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
// going to deepsleep VMA
digitalWrite(LED_BUILTIN, LOW); // Show we're asleep
Watchdog.sleep(8000);
digitalWrite(LED_BUILTIN, HIGH); // Show we're awake again
}[/color]
break;
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
break;
case EV_RESET:
Serial.println(F("EV_RESET"));
break;
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
break;
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
break;
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
break;
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
Serial.println(F("EV_TXSTART"));
break;
default:
Serial.print(F("Unknown event: "));
Serial.println((unsigned) ev);
break;
void do_send(osjob_t* j){
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F("OP_TXRXPEND, not sending"));
} else {
// reset lpp for Cayene
lpp.reset();
// read the temperature from the mp1152a
float temperature = 0;
float pressure = 0;
mpl115a2.getPT(&pressure,&temperature);
Serial.print("Temperature: (°C):"); Serial.print(temperature);
Serial.println(" *C");
lpp.addTemperature(1, temperature);
pressure = pressure * 10;
Serial.print("press (hPa):");
Serial.println(pressure);
lpp.addBarometricPressure(2, pressure);
VL53L0X_RangingMeasurementData_t measure;
lox.rangingTest(&measure, false);
float distance = 0;
if (measure.RangeStatus != 4) { // phase failures have incorrect data
distance = measure.RangeMilliMeter;
Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
} else {
Serial.println(" out of range ");
Serial.print("distance that will be sent: ");
distance = distance/100; //distance in dm
Serial.println(distance);
lpp.addAnalogInput(3, distance);
float measuredvbat = analogRead(VBATPIN);
measuredvbat *= 2; // we divided by 2, so multiply back
measuredvbat *= 3.3; // Multiply by 3.3V, our reference voltage
measuredvbat /= 1024; // convert to voltage
Serial.print("VBat (V) :" );
Serial.println(measuredvbat);
lpp.addAnalogInput(4, measuredvbat);
// prepare upstream data transmission at the next possible time.
// transmit on port 1 (the first parameter); you can use any value from 1 to 223 (others are reserved).
// don't request an ack (the last parameter, if not zero, requests an ack from the network).
// Remember, acks consume a lot of network resources; don't ask for an ack unless you really need it.
Serial.print("buf size: ");
Serial.println(lpp.getSize());
Serial.print("Error: ");
Serial.println(lpp.getError());
LMIC_setTxData2(1, lpp.getBuffer(), lpp.getSize(), 0);
// Next TX is scheduled after TX_COMPLETE event.
delay(5000);
// while (! Serial);
digitalWrite(13, LOW);
Serial.begin(9600);
Serial.println(F("Starting"));
mpl115a2.begin();
lox.begin();
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
// Disable link-check mode and ADR, because ADR tends to complicate testing.
// Set the data rate to Spreading Factor 7. This is the fastest supported rate for 125 kHz channels, and it
// minimizes air time and battery power. Set the transmission power to 14 dBi (25 mW).
LMIC_setDrTxpow(DR_SF7,14);
// in the US, with TTN, it saves join time if we start on subband 1 (channels 8-15). This will
// get overridden after the join by parameters from the network. If working with other
// networks or in other regions, this will need to be changed.
// LMIC_selectSubBand(1);
#if defined(CFG_eu868)
Serial.println("European Channels");
for (int i = 1; i <= 8; i++) LMIC_disableChannel(i);
#elif defined(CFG_us915)
// NA-US channels 0-71 are configured automatically
// but only one group of 8 should (a subband) should be active
// TTN recommends the second sub band, 1 in a zero based count.
// https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
#endif
// Start job (sending automatically starts OTAA too)
do_send(&sendjob);
// we call the LMIC's runloop processor. This will cause things to happen based on events and time. One
// of the things that will happen is callbacks for transmission complete or received messages. We also
// use this loop to queue periodic data transmissions. You can put other things here in the `loop()` routine,
// but beware that LoRaWAN timing is pretty tight, so if you do more than a few milliseconds of work, you
// will want to call `os_runloop_once()` every so often, to keep the radio running.
os_runloop_once();
adafruit2 wrote:the radio chip has sleep modes, you also have to put the mainboard into sleep. deep sleep in circuitpython is new, but heres some info https://learn.adafruit.com/deep-sleep-w ... cuitpython
here's an arduino library https://github.com/adafruit/Adafruit_SleepyDog
Vmarinus wrote:Hello,
Some time ago I played with Lorawan and The things network. I found some intersting code on the web and modified it.
The build I made runs for months on a single old 1600mAh battery from a smartphone.
I's a matter of using the good sleep library and putting in the right spot. and to keep it asleep. So put the sleep command in a loop that runs till you want it to wake. (see colored code)
To get you on the way. here is my code.
- Code: Select all | TOGGLE FULL SIZE
#include <lmic.h>
#include <SPI.h>
#include <Wire.h>;
CayeneLPP lpp(51);
//Sensor Library
#define VBATPIN A7
#define FILLMEIN 0
#else
#endif
// 0x70.
.nss = 8,
// .nss = 11,
.rst = 4,
// .rst = 12,
Serial.print(": ");
switch(ev) {
break;
break;
break;
break;
case EV_JOINING:
break;
case EV_JOINED:
u4_t netid = 0;
u1_t nwkKey[16];
u1_t artKey[16];
if (i != 0)
Serial.print("-");
Serial.println("");
if (i != 0)
Serial.print("-");
Serial.println("");
break;
|| case EV_RFU1:
|| break;
break;
break;
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
do_send(&sendjob);
}[/color]
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
|| case EV_SCAN_FOUND:
|| break;
case EV_TXSTART:
break;
default:
break;
} else {
lpp.reset();
float pressure = 0;
float distance = 0;
} else {
delay(5000);
Serial.begin(9600);
mpl115a2.begin();
lox.begin();
// LMIC init
os_init();
LMIC_reset();
#endif
do_send(&sendjob);
os_runloop_once();
Attention Spamchecking refues to use Cayene with two "n" so i removed one "n" in the code in order to submit it.
import alarm
import alarm.pin
import time
import board
import digitalio
import adafruit_rfm9x
if alarm.wake_alarm:
#print("awake", alarm.wake_alarm, alarm.wake_alarm.pin)
print("awake", alarm.wake_alarm)
alarm.sleep_memory[0] += 1
else:
print("no wake up alarm")
alarm.sleep_memory[0] = 0
#turn on the LED while it is awake
led=digitalio.DigitalInOut(board.LED)
led.switch_to_output()
led.value = True
# this is the alarm pin
pin=digitalio.DigitalInOut(board.IO5)
pin.pull = digitalio.Pull.UP
print("count:", alarm.sleep_memory[0])
# Define radio parameters.
RADIO_FREQ_MHZ = 915.0 # Frequency of the radio in Mhz. Must match your
# module! Can be a value like 915.0, 433.0, etc.
# Define pins connected to the chip.
CS = digitalio.DigitalInOut(board.IO3)
RESET = digitalio.DigitalInOut(board.IO7)
# Initialize SPI bus.
#spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
spi = board.SPI()
# Initialze RFM radio
rfm9x = adafruit_rfm9x.RFM9x(spi, CS, RESET, RADIO_FREQ_MHZ)
rfm9x.tx_power = 23
# send a broadcast mesage as long as the pin is low
while not pin.value:
rfm9x.send(bytes("I'm awake {}".format(alarm.sleep_memory[0]), "UTF-8"))
time.sleep(5.)
#free the alarm pin
pin.deinit()
rfm9x.sleep()
print("packet sent - rfm9x sleeping")
#create an alarm on Pin IO5
pin_alarm = alarm.pin.PinAlarm(pin=board.IO5, value=False, pull=True)
print("about to deep_sleep")
# exit and set the alarm
alarm.exit_and_deep_sleep_until_alarms(pin_alarm)
jerryn wrote:FYI -- I also tried using an RFM9x feather wing - powered normally (via LDO1) and it works as well.
I also ran this on a metro_esp32s2 as well with the same results.
