WiFi for matrix portal m4 board
by discoeye on Fri Jan 08, 2021 2:35 pm
Hi to all,
noob discoeye here from the uk. I recently bought a matrix portal M4 and 32x64 board, I am a complete novice to this world of Adafruit but have had a small bit of tinkering around with raspberry pi's and falcon player for pixel node lights.
However i have fumbled my way through the basic setup and used the monster eyes code somebody has kindly posted and all is well but I can't get my head round the wifi side of the board I know there is a great guide on here but I am lost as how to write the relevant code and test it is connected.
Any help out there would be much appreciated.
Kind Regards Discoeye
discoeye
Re: WiFi for matrix portal m4 board
by dastels on Fri Jan 08, 2021 4:46 pm
You don't mention what language you'd like to use. In any case any PyPortal or AirLift guides should be applicable.
For Example, see https://learn.adafruit.com/adafruit-airlift-breakout.
dastels
by discoeye on Fri Jan 08, 2021 5:37 pm
thanks. I was under the impression the matrix portal m4 board had wifi built in already . I did manage to run an example test and it says the firmware needs to be updated esp32 1.3 firmware.
Im sorry im such a novice but I thought that was the point to learn and I am trying honestly now im completely stuck with a firmware upgrade.
Regards lee
P.S I guess you mean my language which is English .
discoeye
by dastels on Fri Jan 08, 2021 5:43 pm
Yes, the ESP32 is on the board, but from a software point of view, it's just an ESP that is connected - regardless of where or how it's connected.
dastels
by discoeye on Fri Jan 08, 2021 5:48 pm
thanks for the reply. So will upgrading the firmware get to where I want to be and that's the board connected to wifi, im out of my depth here so please be gentle .
discoeye
by dastels on Fri Jan 08, 2021 8:03 pm
It sounds like the first step is getting the firmware updated.
dastels
