MagTag .reset() causes crash
by snaxter on Sun Jan 10, 2021 3:22 pm
I am trying to reset my MagTag after multiple network errors. Calling microcontroller.reset() cases a hard crash "CircuitPython core code crashed hard. Whoops! Crash into the HardFault_Handler." Is there a better way to reset the MagTag?
Here is a simple code snippet that reproduces the problem when you hit button "C".
I'm running 6.1.0 RC0, with mpy bundle 20210109
import time
import microcontroller
import terminalio
from adafruit_magtag.magtag import MagTag
magtag = MagTag()
magtag.peripherals.neopixel_disable = False
magtag.add_text(
    text_font=terminalio.FONT,
    text_position=(120, 55),
    text_scale=2,
magtag.set_text("Idle")
while True:
    if magtag.peripherals.button_a_pressed:
        magtag.set_text("A")
    elif magtag.peripherals.button_b_pressed:
        magtag.set_text("b")
    elif magtag.peripherals.button_c_pressed:
    time.sleep(.1)
code.py
(554 Bytes) Downloaded 2 times
snaxter
Re: MagTag .reset() causes crash
by mikeysklar on Mon Jan 11, 2021 9:15 pm
Thanks for the clear summary.
Your system looks up to date in terms of CircuitPython and the libraries. Can you confirm that your bootloader is also current?
https://circuitpython.org/board/adafrui ... grayscale/
On the Arduino side we can use the CMSIS ARM standard and call:
NVIC_SystemReset()
I mention it that there might be an alternative to microcontroller.reset() for CircuitPython that you can find that I was not able to locate.
mikeysklar
