Installed Library following setup of MCP2221 to working with Blinka: [url]pip3 install adafruit-circuitpython-pm25[/url]
Have Python 3.7.4 and thought I installed it: see list [img] [/img]
Plugged in and added the RST to GPIO 0, error ensured: Why?
Code Error:
- Code: Select all | TOGGLE FULL SIZE
File "A_Sensor_PM25_AQ_R0.py", line 10, in <module>
from adafruit_pm25.i2c import PM25_I2C
ModuleNotFoundError: No module named 'adafruit_pm25.i2c'; 'adafruit_pm25' is not a package
Adapted for windows with COM4 port:
# pylint: disable=unused-import
import time
import board
import busio
from digitalio import DigitalInOut, Direction, Pull
reset_pin = None
# If you have a GPIO, its not a bad idea to connect it to the RESET pin
reset_pin = DigitalInOut(board.G0)
reset_pin.direction = Direction.OUTPUT
reset_pin.value = False
# For use with a computer running Windows:
import serial
uart = serial.Serial("COM4", baudrate=9600, timeout=1)
# For use with microcontroller board:
# (Connect the sensor TX pin to the board/computer RX pin)
# uart = busio.UART(board.TX, board.RX, baudrate=9600)
# For use with Raspberry Pi/Linux:
# import serial
# uart = serial.Serial("/dev/ttyS0", baudrate=9600, timeout=0.25)
# For use with USB-to-serial cable:
# import serial
# uart = serial.Serial("/dev/ttyUSB0", baudrate=9600, timeout=0.25)
# Connect to a PM2.5 sensor over UART
# from adafruit_pm25.uart import PM25_UART
# pm25 = PM25_UART(uart, reset_pin)
# Create library object, use 'slow' 100KHz frequency!
i2c = busio.I2C(board.SCL, board.SDA, frequency=100000)
# Connect to a PM2.5 sensor over I2C
pm25 = PM25_I2C(i2c, reset_pin)
print("Found PM2.5 sensor, reading data...")
while True:
time.sleep(1)
try:
aqdata = pm25.read()
# print(aqdata)
except RuntimeError:
print("Unable to read from sensor, retrying...")
continue
print()
print("Concentration Units (standard)")
print("---------------------------------------")
print(
"PM 1.0: %d\tPM2.5: %d\tPM10: %d"
% (aqdata["pm10 standard"], aqdata["pm25 standard"], aqdata["pm100 standard"])
print("Concentration Units (environmental)")
print(
% (aqdata["pm10 env"], aqdata["pm25 env"], aqdata["pm100 env"])
print("Particles > 0.3um / 0.1L air:", aqdata["particles 03um"])
print("Particles > 0.5um / 0.1L air:", aqdata["particles 05um"])
print("Particles > 1.0um / 0.1L air:", aqdata["particles 10um"])
print("Particles > 2.5um / 0.1L air:", aqdata["particles 25um"])
print("Particles > 5.0um / 0.1L air:", aqdata["particles 50um"])
print("Particles > 10 um / 0.1L air:", aqdata["particles 100um"])
