MCP2221 + PM25 Circuit Python Not Running
by scotch1 on Sun Jan 10, 2021 8:34 pm
Following this tutorial to read the PM2.5 AQ sensor to Python thru MCP2221: https://learn.adafruit.com/pmsa003i/python-circuitpython
Installed Library following setup of MCP2221 to working with Blinka: [url]pip3 install adafruit-circuitpython-pm25[/url]
Have Python 3.7.4 and thought I installed it: see list [img]
[/img]
Plugged in and added the RST to GPIO 0, error ensured: Why?
Code Error:
  File "A_Sensor_PM25_AQ_R0.py", line 10, in <module>
    from adafruit_pm25.i2c import PM25_I2C
ModuleNotFoundError: No module named 'adafruit_pm25.i2c'; 'adafruit_pm25' is not a package
Adapted for windows with COM4 port:
# pylint: disable=unused-import
import time
import board
import busio
from digitalio import DigitalInOut, Direction, Pull
reset_pin = None
# If you have a GPIO, its not a bad idea to connect it to the RESET pin
reset_pin = DigitalInOut(board.G0)
reset_pin.direction = Direction.OUTPUT
reset_pin.value = False
# For use with a computer running Windows:
import serial
uart = serial.Serial("COM4", baudrate=9600, timeout=1)
# For use with microcontroller board:
# (Connect the sensor TX pin to the board/computer RX pin)
# uart = busio.UART(board.TX, board.RX, baudrate=9600)
# For use with Raspberry Pi/Linux:
# import serial
# uart = serial.Serial("/dev/ttyS0", baudrate=9600, timeout=0.25)
# For use with USB-to-serial cable:
# import serial
# uart = serial.Serial("/dev/ttyUSB0", baudrate=9600, timeout=0.25)
# Connect to a PM2.5 sensor over UART
# from adafruit_pm25.uart import PM25_UART
# pm25 = PM25_UART(uart, reset_pin)
# Create library object, use 'slow' 100KHz frequency!
i2c = busio.I2C(board.SCL, board.SDA, frequency=100000)
# Connect to a PM2.5 sensor over I2C
pm25 = PM25_I2C(i2c, reset_pin)
print("Found PM2.5 sensor, reading data...")
while True:
    time.sleep(1)
    try:
        aqdata = pm25.read()
        # print(aqdata)
    except RuntimeError:
        print("Unable to read from sensor, retrying...")
        continue
    print()
    print("Concentration Units (standard)")
    print("---------------------------------------")
    print(
        "PM 1.0: %d\tPM2.5: %d\tPM10: %d"
        % (aqdata["pm10 standard"], aqdata["pm25 standard"], aqdata["pm100 standard"])
    print("Concentration Units (environmental)")
    print(
        % (aqdata["pm10 env"], aqdata["pm25 env"], aqdata["pm100 env"])
    print("Particles > 0.3um / 0.1L air:", aqdata["particles 03um"])
    print("Particles > 0.5um / 0.1L air:", aqdata["particles 05um"])
    print("Particles > 1.0um / 0.1L air:", aqdata["particles 10um"])
    print("Particles > 2.5um / 0.1L air:", aqdata["particles 25um"])
    print("Particles > 5.0um / 0.1L air:", aqdata["particles 50um"])
    print("Particles > 10 um / 0.1L air:", aqdata["particles 100um"])
scotch1
Re: MCP2221 + PM25 Circuit Python Not Running
by adafruit_support_carter on Mon Jan 11, 2021 1:39 pm
Something with your Python setup is not finding the module. Do you get the same thing if you try a simple import from a Python REPL prompt?
import adafruit_pm25
by scotch1 on Thu Jan 14, 2021 2:12 am
Got further except the call for the "PM25_I2C", tried subbing with "adafruit_pm25" and keeping removing the "
  File "A_Sensor_PM25_AQ_R0.py", line 47, in <module>
NameError: name 'PM25_I2C' is not defined
Code:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
Example sketch to connect to PM2.5 sensor with either I2C or UART.
import time
import board
import busio
#from adafruit_pm25.i2c import PM25_I2C
reset_pin = None
# reset_pin = DigitalInOut(board.G0)
# reset_pin.direction = Direction.OUTPUT
# reset_pin.value = False
import serial
#uart = busio.UART(board.TX, board.RX, baudrate=9600)
# import serial
# import serial
while True:
    time.sleep(1)
    try:
        # print(aqdata)
        continue
    print()
    print(
    print(
scotch1
by scotch1 on Thu Jan 14, 2021 2:14 am
ALso: to show I installed it:
(base) D:\Michael_Master\Engineering\Python_Coding\029_Serial_MP_USB_C>pip install adafruit-circuitpython-pm25
Requirement already satisfied: adafruit-circuitpython-pm25 in c:\programdata\anaconda3\lib\site-packages (1.0.3)
Requirement already satisfied: Adafruit-Blinka in c:\programdata\anaconda3\lib\site-packages (from adafruit-circuitpython-pm25) (5.7.0)
Requirement already satisfied: adafruit-circuitpython-busdevice in c:\programdata\anaconda3\lib\site-packages (from adafruit-circuitpython-pm25) (5.0.1)
Requirement already satisfied: Adafruit-PlatformDetect>=2.18.1 in c:\programdata\anaconda3\lib\site-packages (from Adafruit-Blinka->adafruit-circuitpython-pm25) (2.21.0)
Requirement already satisfied: pyftdi>=0.40.0 in c:\programdata\anaconda3\lib\site-packages (from Adafruit-Blinka->adafruit-circuitpython-pm25) (0.52.0)
Requirement already satisfied: Adafruit-PureIO>=1.1.7 in c:\programdata\anaconda3\lib\site-packages (from Adafruit-Blinka->adafruit-circuitpython-pm25) (1.1.7)
Requirement already satisfied: pyserial>=3.0 in c:\programdata\anaconda3\lib\site-packages (from pyftdi>=0.40.0->Adafruit-Blinka->adafruit-circuitpython-pm25) (3.4)
Requirement already satisfied: pyusb>=1.0.0 in c:\programdata\anaconda3\lib\site-packages (from pyftdi>=0.40.0->Adafruit-Blinka->adafruit-circuitpython-pm25) (
scotch1
by adafruit_support_carter on Thu Jan 14, 2021 12:35 pm
Looks like you are using an anaconda setup. Not sure if that matters, but does that require anything special for installing packages? Instead of just regular pip?
by scotch1 on Fri Jan 15, 2021 1:53 am
Most of the time, not a problem, unless it has to be a specific environment.
'pip3' is not recognized as an internal or external command,
operable program or batch file.
Python 3. All other adafruit items seem to be installing and working.
And it gets past the import library down to lines beyond the import, indicating it found the library, so it's something to do with the i2c library class call or pathing either in guthub or the install package, methinks with limited knowledge of the libraries :)
scotch1
by adafruit_support_carter on Fri Jan 15, 2021 1:21 pm
So it's not finding pip3 in your setup? Try running:
pip --version
and see what it reports.
by scotch1 on Sat Jan 16, 2021 1:49 am
pip 19.2.3 from C:\ProgramData\Anaconda3\lib\site-packages\pip (python 3.7)
scotch1
by scotch1 on Sat Jan 16, 2021 1:50 am
adafruit_support_carter wrote:So it's not finding pip3 in your setup? Try running:
pip --version
normally I have to just use pip install xxxxx to get packages, not pip3.
scotch1
by adafruit_support_carter on Mon Jan 18, 2021 11:45 am
Thanks. That seems to look OK. How about trying a forced re-install of the PM25 library and see if it can find it then?
by scotch1 on Mon Jan 18, 2021 7:06 pm
adafruit_support_carter wrote:Thanks. That seems to look OK. How about trying a forced re-install of the PM25 library and see if it can find it then?
Were the directions there for that and do I have to figure out the python for removal of what's there?
scotch1
by adafruit_support_carter on Tue Jan 19, 2021 12:07 pm
Try:
pip install --upgrade --force-reinstall adafruit-circuitpython-pm25
by scotch1 on Tue Jan 19, 2021 3:18 pm
Well, Well, that Worked (thanks)... but here's what's bizarre:
It works without the need to uncooment the windows lines for UART;
[img]
[/img]
or with it:
[img]
[/img]
How come?
scotch1
by adafruit_support_carter on Tue Jan 19, 2021 3:44 pm
Are you using I2C in both cases maybe? Can't see those lines in the screen cap showing the uart setup.
by scotch1 on Tue Jan 19, 2021 6:48 pm
yeah: i2C running:
[img]
[/img]
scotch1
