I installed and ran the test program shown here https://circuitpython.readthedocs.io/pr ... en/latest/ .
I was running successfully for weeks.
Now, when I run the program, i get a number of errors all seeming related to the bmp library?
I did update of Pi and re-installed library.
Suggestions??
[quote]Python 3.7.3 (/usr/bin/python3)
>>> %cd /home/pi/MyPython/MyScripts
>>> %Run bmp280_test_plot.py
File "/home/pi/MyPython/MyScripts/bmp280_test_plot.py", line 38, in <module>
print("\nTemperature: %0.1f C" % bmp280.temperature)
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_bmp280.py", line 319, in temperature
self._read_temperature()
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_bmp280.py", line 151, in _read_temperature
while self._get_status() & 0x08:
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_bmp280.py", line 184, in _get_status
return self._read_byte(_REGISTER_STATUS)
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_bmp280.py", line 380, in _read_byte
return self._read_register(register, 1)[0]
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_bmp280.py", line 412, in _read_register
i2c.write(bytes([register & 0xFF]))
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_bus_device/i2c_device.py", line 102, in write
self.i2c.writeto(self.device_address, buf, start=start, end=end)
File "/home/pi/.local/lib/python3.7/site-packages/busio.py", line 115, in writeto
return self._i2c.writeto(address, memoryview(buffer)[start:end], stop=stop)
File "/home/pi/.local/lib/python3.7/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 49, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_PureIO/smbus.py", line 308, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
bmp280 library not working?
- dastels
Re: bmp280 library not working?
It sounds more like a hardware problem. It's having trouble talking to the sensor. My first step would be to check the wiring.
- cbrucewarren
when I run "i2cdetect -y -1" it shows the device, also a test probe of the device in python [ detect it, not read it] without using the adafruit library works....
- dastels
OK, That's odd.
- cbrucewarren
yes, very odd; especially since it had been working and I hadn't updated/upgraded or changed any of the code and then this happened. However, as I type this I recall that I had tried to implement a Dallas 1-wire connection in python so now i'm wondering if any of that has messed with the library?
- dastels
Messing with a libary seems odd, unless it or parts of it were replaced during the other work.
- cbrucewarren
status:
1) have -wire code working
2) i2cdetect finds BMP280 address
3) this code runs OK:
4) runniing this code give error that I2C not found:
5: code in (4) ran continously for a week or so
"""CircuitPython Essentials I2C Scan example"""
# If you run this and it seems to hang, try manually unlocking
# your I2C bus from the REPL with
# >>> import board
# >>> board.I2C().unlock()
import time
import board
i2c = board.I2C()
while not i2c.try_lock():
pass
try:
while True:
print("I2C addresses found:", [hex(device_address)
for device_address in i2c.scan()])
time.sleep(2)
finally: # unlock the i2c bus when ctrl-c'ing out of the loop
i2c.unlock()
import time
import board
# import digitalio # For use with SPI
import busio
import adafruit_bmp280
# import time
import psutil
import matplotlib.pyplot as plt
#%matplotlib notebook
#plt.rcParams['animation.html'] = 'jshtml'
fig = plt.figure()
fig1 = plt.figure()
ax = fig.add_subplot(111)
bx = fig1.add_subplot(111)
fig.show()
fig1.show()
i=0
x,y = [],[]
x1,y1 = [],[]
#Create library object using our Bus I2C port
bmp280 = adafruit_bmp280.Adafruit_BMP280_I2C(i2c)
# OR create library object using our Bus SPI port
# spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
# bmp_cs = digitalio.DigitalInOut(board.D10)
# bmp280 = adafruit_bmp280.Adafruit_BMP280_SPI(spi, bmp_cs)
# change this to match the location's pressure (hPa) at sea level
# bmp280.sea_level_pressure = 1013.25
while True:
#time.sleep(20)
print("Pressure: %0.1f hPa" % bmp280.pressure)
print(" Cycle no: %0.1f" % i)
print("Minutes from Start: %0.1f" % (i*5))
print("Hours from Start: %0.1f" % (i/12))
# print("Altitude = %0.2f meters" % bmp280.altitude)
#------ setup pressure plot -----------
x.append(i)
y.append(bmp280.pressure)
ax.set_title("Barometric Pressure")
ax.plot(x,y,color ='b')
fig.canvas.draw()
ax.set_xlim(left=max(0,i-200),right = i+200)
ax.set_ylim(870,900)
#--- set up temperature graph?
x1.append(i)
y1.append(bmp280.temperature)
bx.set_title("Room Temp")
bx.plot(x1,y1,color ='b')
fig1.canvas.draw()
bx.set_xlim(left=max(0,i-200),right = i+200)
bx.set_ylim(8,25)
i+=1
time.sleep(300)
- cbrucewarren
In terminal mode:
1) "i2cdetect -y 1 " finds the BMP280 address
2) "i2get 1 0x77 " results in "Error: read failed"
It is not the module; i swapped it with another module running on an Arduino set up.
I'm baffled as to what to try next -- thoughts??
