I am using the PyPortal Pynt and am trying to connect to Adafruit IO. I have the correct information in the 'secrets.py' file, but am getting the following error:
File "code.py", line 5, in <module>
ImportError: no module named 'ssl'
The code is as follows:
- Code: Select all | TOGGLE FULL SIZE
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# adafruit_circuitpython_adafruitio usage with native wifi networking
import ssl
from random import randint
import adafruit_requests
import socketpool
import wifi
from adafruit_io.adafruit_io import IO_HTTP, AdafruitIO_RequestError
# Add a secrets.py to your filesystem that has a dictionary called secrets with "ssid" and
# "password" keys with your WiFi credentials. DO NOT share that file or commit it into Git or other
# source control.
# pylint: disable=no-name-in-module,wrong-import-order
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
# Set your Adafruit IO Username and Key in secrets.py
# (visit io.adafruit.com if you need to create an account,
# or if you need your Adafruit IO key.)
aio_username = secrets["aio_username"]
aio_key = secrets["aio_key"]
print("Connecting to %s" % secrets["ssid"])
wifi.radio.connect(secrets["ssid"], secrets["password"])
print("Connected to %s!" % secrets["ssid"])
pool = socketpool.SocketPool(wifi.radio)
requests = adafruit_requests.Session(pool, ssl.create_default_context())
# Initialize an Adafruit IO HTTP API object
io = IO_HTTP(aio_username, aio_key, requests)
try:
# Get the 'temperature' feed from Adafruit IO
temperature_feed = io.get_feed("temperature")
except AdafruitIO_RequestError:
# If no 'temperature' feed exists, create one
temperature_feed = io.create_new_feed("temperature")
# Send random integer values to the feed
random_value = randint(0, 50)
print("Sending {0} to temperature feed...".format(random_value))
io.send_data(temperature_feed["key"], random_value)
print("Data sent!")
# Retrieve data value from the feed
print("Retrieving data from temperature feed...")
received_data = io.receive_data(temperature_feed["key"])
print("Data from temperature feed: ", received_data["value"])
I can't find any library files with "ssl". Am I using the wrong code and/or library?
