Finally! Got my original PyPortal updated to 1.7.1!
For those of you with the same issue:
I just kept at it every weekend... I've probably rebooted the thing 1000 times. Today, I erased everything, upgraded to Python 6.2.0-rc.0 and rebooted probably 5 or 6 times and then it worked... but specifically from a charge only cable... I've been experimenting between plugging in to my computer and a dedicated power source. It seems as though it obtained a higher percentage when on power only. Maybe this is just a coincidence, but I felt I should at least note it.
So just run the esptool.py:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import busio
from digitalio import DigitalInOut, Direction # pylint: disable=unused-import
import adafruit_miniesptool
print("ESP32 Nina-FW")
# Override these if you are manually wiring. Otherwise, this will use ESP pins from board.
tx = board.ESP_TX
rx = board.ESP_RX
resetpin = board.ESP_RESET
gpio0pin = board.ESP_GPIO0
uart = busio.UART(tx, rx, baudrate=115200, timeout=1)
esptool = adafruit_miniesptool.miniesptool(
uart, DigitalInOut(gpio0pin), DigitalInOut(resetpin), flashsize=4 * 1024 * 1024
esptool.sync()
print("Synced")
print("Found:", esptool.chip_name)
if esptool.chip_name != "ESP32":
raise RuntimeError("This example is for ESP32 only")
esptool.baudrate = 912600
print("MAC ADDR: ", [hex(i) for i in esptool.mac_addr])
# Note: Make sure to use the LATEST nina-fw binary release!
esptool.flash_file("NINA_W102-1.7.1.bin", 0x0, "dc81f0433dfba6de33c78b5c5911261d")
esptool.reset()
time.sleep(0.5)
Then check to see if it works... The green light
should come on, but always confirm:
# SPDX-FileCopyrightText: 2019 ladyada for Adafruit Industries
import board
import busio
import adafruit_requests as requests
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
# Get wifi details and more from a secrets.py file
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
print("ESP32 SPI webclient test")
TEXT_URL = "http://wifitest.adafruit.com/testwifi/index.html"
JSON_URL = "http://api.coindesk.com/v1/bpi/currentprice/USD.json"
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an AirLift Shield:
# esp32_cs = DigitalInOut(board.D10)
# esp32_ready = DigitalInOut(board.D7)
# esp32_reset = DigitalInOut(board.D5)
# If you have an AirLift Featherwing or ItsyBitsy Airlift:
# esp32_cs = DigitalInOut(board.D13)
# esp32_ready = DigitalInOut(board.D11)
# esp32_reset = DigitalInOut(board.D12)
# If you have an externally connected ESP32:
# NOTE: You may need to change the pins to reflect your wiring
# esp32_cs = DigitalInOut(board.D9)
# esp32_ready = DigitalInOut(board.D10)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
requests.set_socket(socket, esp)
if esp.status == adafruit_esp32spi.WL_IDLE_STATUS:
print("ESP32 found and in idle mode")
print("Firmware vers.", esp.firmware_version)
print("MAC addr:", [hex(i) for i in esp.MAC_address])
for ap in esp.scan_networks():
print("\t%s\t\tRSSI: %d" % (str(ap["ssid"], "utf-8"), ap["rssi"]))
print("Connecting to AP...")
while not esp.is_connected:
try:
esp.connect_AP(secrets["ssid"], secrets["password"])
except RuntimeError as e:
print("could not connect to AP, retrying: ", e)
continue
print("Connected to", str(esp.ssid, "utf-8"), "\tRSSI:", esp.rssi)
print("My IP address is", esp.pretty_ip(esp.ip_address))
print(
"IP lookup adafruit.com: %s" % esp.pretty_ip(esp.get_host_by_name("adafruit.com"))
print("Ping google.com: %d ms" % esp.ping("google.com"))
# esp._debug = True
print("Fetching text from", TEXT_URL)
r = requests.get(TEXT_URL)
print("-" * 40)
print(r.text)
print("-" * 40)
r.close()
print()
print("Fetching json from", JSON_URL)
r = requests.get(JSON_URL)
print("-" * 40)
print(r.json())
print("-" * 40)
r.close()
print("Done!")
Keep trying! :-)
