code.py output:
File "code.py", line 15
SyntaxError: invalid syntax
CODE is as such
- Code: Select all | TOGGLE FULL SIZE
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import busio
from digitalio import DigitalInOut, Direction # pylint: disable=unused-import
import adafruit_miniesptool
print("ESP32 Nina-FW")
# Override these if you are manually wiring. Otherwise, this will use ESP pins from board.
tx = board.ESP_TX
rx = board.ESP_RX
in = board.ESP_RESET
gpio0pin = board.ESP_GPIO0
uart = busio.UART(tx, rx, baudrate=115200, timeout=1)
esptool = adafruit_miniesptool.miniesptool(
uart, DigitalInOut(gpio0pin), DigitalInOut(resetpin), flashsize=4 * 1024 * 1024
esptool.sync()
print("Synced")
print("Found:", esptool.chip_name)
if esptool.chip_name != "ESP32":
raise RuntimeError("This example is for ESP32 only")
esptool.baudrate = 912600
print("MAC ADDR: ", [hex(i) for i in esptool.mac_addr])
# Note: Make sure to use the LATEST nina-fw binary release!
esptool.flash_file("NINA_W102-1.7.1.bin", 0x0, "dc81f0433dfba6de33c78b5c5911261d")
esptool.reset()
time.sleep(0.5)
