DHT22 sensor Unable to set line XX to input
by Trollpatrol on Mon Feb 08, 2021 8:11 pm
Hello everyone,
i am having the same issue as this post:
viewtopic.php?f=19&t=169472
the first time that i run the code on a new pin it is working. although, when changing the pin wiring i get the message "Unable to set line XX to input".
Has this problem been solved by Adafruit?
Python Code:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import adafruit_dht
# Initial the dht device, with data pin connected to:
dhtDevice = adafruit_dht.DHT22(board.D10)
# you can pass DHT22 use_pulseio=False if you wouldn't like to use pulseio.
# This may be necessary on a Linux single board computer like the Raspberry Pi,
# but it will not work in CircuitPython.
# dhtDevice = adafruit_dht.DHT22(board.D18, use_pulseio=False)
while True:
    try:
        # Print the values to the serial port
        temperature_c = dhtDevice.temperature
        temperature_f = temperature_c * (9 / 5) + 32
        humidity = dhtDevice.humidity
        print(
            "Temp: {:.1f} F / {:.1f} C    Humidity: {}% ".format(
                temperature_f, temperature_c, humidity
    except RuntimeError as error:
        # Errors happen fairly often, DHT's are hard to read, just keep going
        print(error.args[0])
        time.sleep(2.0)
        continue
    except Exception as error:
        dhtDevice.exit()
        raise error
    time.sleep(2.0)
Thanks for your help.
Jean
Trollpatrol
Re: DHT22 sensor Unable to set line XX to input
by FrankBS on Wed Mar 03, 2021 5:06 pm
Same problem. Using Pie v4. Works first time then error when re-running. Switched pin and it worked first time, then error again.
Python 3.7.3 (/usr/bin/python3)
>>> %Run working_dht_simpletest.py
Temp: 73.9 F / 23.3 C Humidity: 24.2%
Temp: 73.6 F / 23.1 C Humidity: 24.9%
Temp: 73.4 F / 23.0 C Humidity: 24.8%
Unable to set line 4 to input
FrankBS
by adafruit_support_carter on Fri Mar 05, 2021 4:44 pm
There's an open issue tracking this here:
https://github.com/adafruit/Adafruit_Ci ... /issues/63
by adafruit_support_carter on Fri Mar 05, 2021 5:37 pm
I think the general issue here is that these codes are all infinite loops that are being aborted using <CTRL><C>. As a result, the DHT exit() never gets called:
https://github.com/adafruit/Adafruit_Ci ... dht.py#L59
and so the pulseio deinit() does not get called:
https://github.com/adafruit/Adafruit_Bl ... eIn.py#L99
and so the background process handling the pulsein does not get terminated. So when the code is run a second time, that still running process still has the pin taken.
Further, the current example has some try/except logic:
https://github.com/adafruit/Adafruit_Ci ... pletest.py
but this will not catch a <CTRL><C> event since KeyboardInterrupt inherits from BaseException, not Exception:
https://docs.python.org/3/library/excep ... dInterrupt
So....just need to somehow make sure the deinit stuff gets called. Try the code below. This is not tested, but attempts to restructure things to try and catch the <CTRL><C> and call the deinit stuff.
import time
import board
import adafruit_dht
try:
    while True:
        try:
            print(
            time.sleep(2.0)
            time.sleep(2.0)
            continue
except KeyboardInterrupt as error:
    print("CTRL-C pressed. Deiniting everything...")
    dhtDevice.exit()
    raise error
by FrankBS on Fri Mar 05, 2021 10:58 pm
Is there no way to initialize the board to break the sequence when the program is re-run after interrupt short-circuits the code?
When my error occurs, I am stopping the code in Thonny and then re-running the code.
FrankBS
by adafruit_support_carter on Sat Mar 06, 2021 11:19 am
There are ways of registering callback functions for various signals, like SIGINT, which is what <CTRL><C> generates. How do you "stop code" in Thonny?
by FrankBS on Sat Mar 06, 2021 3:16 pm
I click the red stop button (Red circle with white square) in the Thonny menu while running the referenced code.
FrankBS
by adafruit_support_carter on Thu Mar 18, 2021 7:38 pm
I can't recreate this. I'm running the example from the first post above, which is the simpletest example from the library:
I can run it, abort with <CTRL><C>, and run again.
(blinka) pi@raspberrypi:~ $ python3 dht_simpletest.py
Temp: 77.7 F / 25.4 C    Humidity: 30.0%
^CTraceback (most recent call last):
  File "dht_simpletest.py", line 37, in <module>
received SIGINT
    time.sleep(2.0)
KeyboardInterrupt
Temp: 77.7 F / 25.4 C    Humidity: 29.9%
Temp: 77.7 F / 25.4 C    Humidity: 29.8%
Temp: 77.7 F / 25.4 C    Humidity: 29.7%
^Creceived SIGINT
    time.sleep(2.0)
KeyboardInterrupt
Is this only happening with people using Thonny?
by FrankBS on Fri Mar 19, 2021 9:54 am
I tried your new code in Thonny. Same issue. It runs once and then no matter how I stop it, STOP or CTRL-C, it will not run again unless I reboot the Pi.
Also tried in MU, same results.
FrankBS
