Audio Problem
Audio Problem
by lawrenceyy on Thu Feb 11, 2021 9:31 pm
I have a feather M4 Express with a Prop-Maker stacked on top. I also have a HC-SR04 and speaker (attached to Prop-Maker). The problem I am running into has to do with the order of my code. When I initialize the HC-SR04 before the audio code, the speaker plays fine. When I initialize the HC-SR04 after the audio code, the speaker plays a bunch of static.
I've stripped down my code to highlight the problem. This one plays the wave file fine.
import board
import digitalio
import audioio
from audiocore import WaveFile
import adafruit_hcsr04
#initialize HC-SR04
sonar = adafruit_hcsr04.HCSR04(trigger_pin=board.RX, echo_pin=board.D4)
#audio
propMakerPower = digitalio.DigitalInOut(board.D10)
propMakerPower.direction = digitalio.Direction.OUTPUT
propMakerPower.value = True
speaker = audioio.AudioOut(board.A0)
wave = WaveFile(open("StreetChicken.wav", "rb"))
#play wave
speaker.play(wave)
while speaker.playing:
    pass
This one plays static noise.
import board
import digitalio
import audioio
#audio
#initialize HC-SR04
#play wave
speaker.play(wave)
    pass
What is causing the speaker to play static noise in the second code example?
Lawrence Yun
lawrenceyy
Re: Audio Problem
by tannewt on Fri Feb 12, 2021 3:30 pm
This sounds like a bug! Please file an issue here with all of the files needed to replicate it: https://github.com/adafruit/circuitpython/issues Thanks!
tannewt
Re: Audio Problem
by lawrenceyy on Fri Feb 12, 2021 4:51 pm
Okay, I'll post the bug to github.
I should also mention that in the code where audio does play (example 1), the sonar readings are off. The values are still proportional - smaller reading when target is close and larger when target is far. But the readings are 10-20x larger.
How long will it take for someone to find a solution to this bug? Will it be posted in a new version of CircuitPython? I kind of need a solution in the next week or two.
lawrenceyy
Re: Audio Problem
by tannewt on Tue Feb 16, 2021 2:08 pm
lawrenceyy wrote:How long will it take for someone to find a solution to this bug? Will it be posted in a new version of CircuitPython? I kind of need a solution in the next week or two.
We make no promises if/when things will be fixed. Yes, fixes would be pushed in new versions. Like most open source projects, we provide no warranty.
tannewt
Re: Audio Problem
by kevinjwalters on Thu Feb 18, 2021 9:05 am
Is it worth trying different versions of CircuitPython here to see if older/newer versions work?
kevinjwalters
