PyPortal Pynt User Interface example
by oldblackcrow on Sat Feb 13, 2021 4:47 pm
Hello all!
I'm reworking the User Interface example but ran into a bit of an ignorance wall. I would like to completely remove the blue "meee" button below. When I go to that block and remove code, I get different errors. I know I'm not quite understanding CircuitPython yet, as I am still pretty new. Thanks for any help on this!
import time
import math
import board
import displayio
from terminalio import FONT
from adafruit_pyportal import PyPortal
from adafruit_display_shapes.circle import Circle
from adafruit_display_text.label import Label
#--| USER CONFIG |--------------------------
MARK_SIZE = 10           # marker radius
MARK_COLOR = 0xFF3030    # marker color
MARK_THICKNESS = 5       # marker thickness
TRAIL_LENGTH = 200       # trail length
TRAIL_COLOR = 0xFFFF00   # trail color
DATE_COLOR = 0x111111    # date color
TIME_COLOR = 0x111111    # time color
LAT_MAX = 80             # latitude (deg) of map top/bottom edge
UPDATE_RATE = 10         # update rate in seconds
DATA_SOURCE = "http://api.open-notify.org/iss-now.json"
DATA_LOCATION = ["iss_position"]
WIDTH = board.DISPLAY.width
HEIGHT = board.DISPLAY.height
# determine the current working directory needed so we know where to find files
cwd = ("/"+__file__).rsplit('/', 1)[0]
pyportal = PyPortal(url=DATA_SOURCE,
                    json_path=DATA_LOCATION,
                    status_neopixel=board.NEOPIXEL,
                    default_bg=cwd+"/map.bmp")
# Connect to the internet and get local time
pyportal.get_local_time()
# Date and time label
date_label = Label(FONT, text="0000-00-00", color=DATE_COLOR, x=165, y=223)
time_label = Label(FONT, text="00:00:00", color=TIME_COLOR, x=240, y=223)
pyportal.splash.append(date_label)
pyportal.splash.append(time_label)
# ISS trail
trail_bitmap = displayio.Bitmap(3, 3, 1)
trail_palette = displayio.Palette(1)
trail_palette[0] = TRAIL_COLOR
trail = displayio.Group(max_size=TRAIL_LENGTH)
pyportal.splash.append(trail)
# ISS location marker
marker = displayio.Group(max_size=MARK_THICKNESS)
for r in range(MARK_SIZE - MARK_THICKNESS, MARK_SIZE):
    marker.append(Circle(0, 0, r, outline=MARK_COLOR))
pyportal.splash.append(marker)
def get_location(width=WIDTH, height=HEIGHT):
    """Fetch current lat/lon, convert to (x, y) tuple scaled to width/height."""
    # Get location
    try:
        location = pyportal.fetch()
    except RuntimeError:
        return None, None
    # Compute (x, y) coordinates
    lat = float(location["latitude"])   # degrees, -90 to 90
    lon = float(location["longitude"])  # degrees, -180 to 180
    # Scale latitude for cropped map
    lat *= 90 / LAT_MAX
    # Mercator projection math
    # https://stackoverflow.com/a/14457180
    # https://en.wikipedia.org/wiki/Mercator_projection#Alternative_expressions
    x = lon + 180
    x = width * x / 360
    y = math.radians(lat)
    y = math.tan(math.pi / 4 + y / 2)
    y = math.log(y)
    y = (width * y) / (2 * math.pi)
    y = height / 2 - y
    return int(x), int(y)
def update_display(current_time, update_iss=False):
    """Update the display with current info."""
    # ISS location
    if update_iss:
        x, y = get_location()
        if x and y:
            marker.x = x
            marker.y = y
            if len(trail) >= TRAIL_LENGTH:
                trail.pop(0)
            trail.append(displayio.TileGrid(trail_bitmap,
                                            pixel_shader=trail_palette,
                                            x = x - 1,
                                            y = y - 1) )
    # Date and time
    date_label.text = "{:04}-{:02}-{:02}".format(current_time.tm_year,
                                                 current_time.tm_mon,
                                                 current_time.tm_mday)
    time_label.text = "{:02}:{:02}:{:02}".format(current_time.tm_hour,
                                                 current_time.tm_min,
                                                 current_time.tm_sec)
    try:
        board.DISPLAY.refresh(target_frames_per_second=60)
    except AttributeError:
        board.DISPLAY.refresh_soon()
# Initial refresh
update_display(time.localtime(), True)
last_update = time.monotonic()
# Run forever
while True:
    now = time.monotonic()
    new_position = False
    if now - last_update > UPDATE_RATE:
        new_position = True
        last_update = now
    update_display(time.localtime(), new_position)
    time.sleep(0.5)
oldblackcrow
Re: PyPortal Pynt User Interface example
by oldblackcrow on Sat Feb 13, 2021 6:05 pm
Sorry... wrong code above. It wouldn't let me edit it.
import time
import board
import microcontroller
import displayio
import busio
from analogio import AnalogIn
import neopixel
import adafruit_adt7410
from adafruit_bitmap_font import bitmap_font
from adafruit_button import Button
import adafruit_touchscreen
# ------------- Inputs and Outputs Setup ------------- #
try:  # attempt to init. the temperature sensor
    i2c_bus = busio.I2C(board.SCL, board.SDA)
    adt = adafruit_adt7410.ADT7410(i2c_bus, address=0x48)
    adt.high_resolution = True
except ValueError:
    # Did not find ADT7410. Probably running on Titano or Pynt
    adt = None
# init. the light sensor
light_sensor = AnalogIn(board.LIGHT)
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=1)
WHITE = 0xffffff
RED = 0xff0000
YELLOW = 0xffff00
GREEN = 0x00ff00
BLUE = 0x0000ff
PURPLE = 0xff00ff
BLACK = 0x000000
# ---------- Sound Effects ------------- #
soundDemo = '/sounds/sound.wav'
soundBeep = '/sounds/beep.wav'
soundTab = '/sounds/tab.wav'
# ------------- Other Helper Functions------------- #
# Helper for cycling through a number set of 1 to x.
def numberUP(num, max_val):
    num += 1
    if num <= max_val:
        return num
    else:
        return 1
# ------------- Screen Setup ------------- #
pyportal = PyPortal()
display = board.DISPLAY
display.rotation = 0
# Backlight function
# Value between 0 and 1 where 0 is OFF, 0.5 is 50% and 1 is 100% brightness.
def set_backlight(val):
    val = max(0, min(1.0, val))
    board.DISPLAY.auto_brightness = False
    board.DISPLAY.brightness = val
# Set the Backlight
set_backlight(0.3)
# Touchscreen setup
# ------Rotate 0:
screen_width = 320
screen_height = 240
ts = adafruit_touchscreen.Touchscreen(board.TOUCH_XL, board.TOUCH_XR,
                                      board.TOUCH_YU, board.TOUCH_YD,
                                      calibration=((5200, 59000),
                                                   (5800, 57000)),
                                      size=(screen_width, screen_height))
# ------------- Display Groups ------------- #
splash = displayio.Group(max_size=15)  # The Main Display Group
view1 = displayio.Group(max_size=15)  # Group for View 1 objects
view2 = displayio.Group(max_size=15)  # Group for View 2 objects
view3 = displayio.Group(max_size=15)  # Group for View 3 objects
def hideLayer(hide_target):
    try:
        splash.remove(hide_target)
    except ValueError:
        pass
def showLayer(show_target):
    try:
        time.sleep(0.1)
        splash.append(show_target)
    except ValueError:
        pass
# ------------- Setup for Images ------------- #
# Display an image until the loop starts
pyportal.set_background('/images/loading.bmp')
bg_group = displayio.Group(max_size=1)
splash.append(bg_group)
icon_group = displayio.Group(max_size=1)
icon_group.x = 180
icon_group.y = 120
icon_group.scale = 1
view2.append(icon_group)
# This will handel switching Images and Icons
def set_image(group, filename):
    """Set the image file for a given goup for display.
    This is most useful for Icons or image slideshows.
        :param group: The chosen group
        :param filename: The filename of the chosen image
    print("Set image to ", filename)
    if group:
        group.pop()
    if not filename:
        return  # we're done, no icon desired
    image_file = open(filename, "rb")
    image = displayio.OnDiskBitmap(image_file)
    try:
        image_sprite = displayio.TileGrid(image, pixel_shader=displayio.ColorConverter())
    except TypeError:
        image_sprite = displayio.TileGrid(image, pixel_shader=displayio.ColorConverter(),
                                          position=(0, 0))
    group.append(image_sprite)
set_image(bg_group, "/images/BGimage.bmp")
# ---------- Text Boxes ------------- #
# Set the font and preload letters
font = bitmap_font.load_font("/fonts/Helvetica-Bold-16.bdf")
font.load_glyphs(b'abcdefghjiklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890- ()')
# Default Label styling:
TABS_X = 20
TABS_Y = 50
# Text Label Objects
feed1_label = Label(font, text="Text Wondow 1", color=0xE39300, max_glyphs=200)
feed1_label.x = TABS_X+25
feed1_label.y = TABS_Y
view1.append(feed1_label)
feed2_label = Label(font, text="Text Wondow 2", color=0xFFFFFF, max_glyphs=200)
feed2_label.x = TABS_X
feed2_label.y = TABS_Y
view2.append(feed2_label)
sensors_label = Label(font, text="Data View", color=0x03AD31, max_glyphs=200)
sensors_label.x = TABS_X
sensors_label.y = TABS_Y
view3.append(sensors_label)
sensor_data = Label(font, text="Data View", color=0x03AD31, max_glyphs=100)
sensor_data.x = TABS_X+150
sensor_data.y = 120
view3.append(sensor_data)
text_hight = Label(font, text="M", color=0x03AD31, max_glyphs=10)
# return a reformatted string with word wrapping using PyPortal.wrap_nicely
def text_box(target, top, string, max_chars):
    text = pyportal.wrap_nicely(string, max_chars)
    new_text = ""
    test = ""
    for w in text:
        new_text += '\n'+w
        test += 'M\n'
    text_hight.text = test  # Odd things happen without this
    glyph_box = text_hight.bounding_box
    target.text = ""  # Odd things happen without this
    target.y = int(glyph_box[3]/2)+top
    target.text = new_text
# ---------- Display Buttons ------------- #
# Default button styling:
BUTTON_HEIGHT = 20
BUTTON_WIDTH = 80
# We want three buttons across the top of the screen
TAPS_HEIGHT = 30
TAPS_WIDTH = int(screen_width/3)
TAPS_Y = 0
# We want two big buttons at the bottom of the screen
BIG_BUTTON_HEIGHT = int(screen_height/5.2)
BIG_BUTTON_WIDTH = int(screen_width/2)
BIG_BUTTON_Y = int(screen_height-BIG_BUTTON_HEIGHT)
# This group will make it easy for us to read a button press later.
buttons = []
# Main User Interface Buttons
button_view1 = Button(x=0, y=0,
                      width=TAPS_WIDTH, height=TAPS_HEIGHT,
                      label="Distance", label_font=font, label_color=0xff7e00,
                      fill_color=0x5c5b5c, outline_color=0x767676,
                      selected_fill=0x1a1a1a, selected_outline=0x2e2e2e,
                      selected_label=0x525252)
buttons.append(button_view1)  # adding this button to the buttons group
button_view2 = Button(x=TAPS_WIDTH, y=0,
                      label="IR Camera", label_font=font, label_color=0xff7e00,
buttons.append(button_view2)  # adding this button to the buttons group
button_view3 = Button(x=TAPS_WIDTH*2, y=0,
                      label="Gas Sensor", label_font=font, label_color=0xff7e00,
buttons.append(button_view3)  # adding this button to the buttons group
button_switch = Button(x=0, y=BIG_BUTTON_Y,
                       width=BIG_BUTTON_WIDTH, height=BIG_BUTTON_HEIGHT,
                       label="Switch", label_font=font, label_color=0xff7e00,
buttons.append(button_switch)  # adding this button to the buttons group
button_2 = Button(x=BIG_BUTTON_WIDTH, y=BIG_BUTTON_Y,
                  label="Light ON/OFF", label_font=font, label_color=0xff7e00,
buttons.append(button_2)  # adding this button to the buttons group
# Add all of the main buttons to the splash Group
for b in buttons:
    splash.append(b.group)
# Make a button to change the icon image on view2
button_icon = Button(x=150, y=60,
                     width=BUTTON_WIDTH, height=BUTTON_HEIGHT,
                     label="Icon", label_font=font, label_color=0xffffff,
                     fill_color=0x8900ff, outline_color=0xbc55fd,
                     selected_fill=0x5a5a5a, selected_outline=0xff6600,
                     selected_label=0x525252, style=Button.ROUNDRECT)
buttons.append(button_icon)  # adding this button to the buttons group
# Add this button to view2 Group
# view2.append(button_icon.group)
# Make a button to play a sound on view2
button_sound = Button(x=25, y=130,
                       label="meee", label_font=font, label_color=0xffffff,
buttons.append(button_sound)  # adding this button to the buttons group
view3.append(button_sound.group)
#pylint: disable=global-statement
def switch_view(what_view):
    global view_live
    if what_view == 1:
        hideLayer(view2)
        hideLayer(view3)
        button_view1.selected = True
        button_view2.selected = False
        button_view3.selected = False
        showLayer(view1)
        view_live = 1
        print("View1 On")
    elif what_view == 2:
        # global icon
        hideLayer(view1)
        hideLayer(view3)
        button_view1.selected = False
        button_view2.selected = True
        showLayer(view2)
        view_live = 2
        print("View2 On")
    else:
        hideLayer(view1)
        hideLayer(view2)
        button_view3.selected = True
        showLayer(view3)
        view_live = 3
        print("View3 On")
#pylint: enable=global-statement
# Set veriables and startup states
showLayer(view1)
hideLayer(view2)
hideLayer(view3)
view_live = 1
icon = 1
icon_name = "Ruby"
button_mode = 1
switch_state = 0
button_switch.label = "OFF"
button_switch.selected = True
# Update out Labels with display text.
text_box(feed1_label, TABS_Y,
         "Testy ### x ###.", 30)
         'Test {} x {}.'
         .format(feed1_label.bounding_box[2], feed1_label.bounding_box[3]*2), 30)
text_box(feed2_label, TABS_Y, 'Image', 18)
text_box(sensors_label, TABS_Y,
         "SENSOR DATA", 28)
board.DISPLAY.show(splash)
# ------------- Code Loop ------------- #
while True:
    touch = ts.touch_point
    light = light_sensor.value
    if adt:  # Only if we have the temperature sensor
        tempC = adt.temperature
    else:  # No temperature sensor
        tempC = microcontroller.cpu.temperature
    tempF = tempC * 1.8 + 32
    sensor_data.text = 'Touch: {}\nLight: {}\n Temp: {:.0f}°F'.format(touch, light, tempF)
    # ------------- Handle Button Press Detection  ------------- #
    if touch:  # Only do this if the screen is touched
        # loop with buttons using enumerate() to number each button group as i
        for i, b in enumerate(buttons):
            if b.contains(touch):  # Test each button to see if it was pressed
                print('button%d pressed' % i)
                if i == 0 and view_live != 1:  # only if view1 is visable
                    pyportal.play_file(soundTab)
                    switch_view(1)
                    while ts.touch_point:
                        pass
                if i == 1 and view_live != 2:  # only if view2 is visable
                    switch_view(2)
                        pass
                if i == 2 and view_live != 3:  # only if view3 is visable
                    switch_view(3)
                        pass
                if i == 3:
                    pyportal.play_file(soundBeep)
                    # Toggle switch button type
                    if switch_state == 0:
                        switch_state = 1
                        b.label = "COLOR"
                        b.selected = False
                        pixel.fill(WHITE)
                        print("Swich ON")
                    else:
                        switch_state = 0
                        b.label = "OFF"
                        b.selected = True
                        pixel.fill(BLACK)
                        print("Swich OFF")
                    # for debounce
                        pass
                    print("Swich Pressed")
                if i == 4:
                    # Momentary button type
                    b.selected = True
                    print('Button Pressed')
                    button_mode = numberUP(button_mode, 5)
                    if button_mode == 1:
                        pixel.fill(RED)
                    elif button_mode == 2:
                        pixel.fill(YELLOW)
                    elif button_mode == 3:
                        pixel.fill(GREEN)
                    elif button_mode == 4:
                        pixel.fill(BLUE)
                    elif button_mode == 5:
                        pixel.fill(PURPLE)
                    switch_state = 1
                    button_switch.label = "COLOR"
                    button_switch.selected = False
                    # for debounce
                        pass
                    print("Button released")
                    b.selected = False
                if i == 5 and view_live == 2:  # only if view2 is visable
                    b.selected = True
                        pass
                    print("Icon Button Pressed")
                    icon = numberUP(icon, 3)
                    if icon == 1:
                        icon_name = "Ruby"
                    elif icon == 2:
                        icon_name = "Gus"
                    elif icon == 3:
                        icon_name = "Billie"
                    b.selected = False
                             "Image".format(icon_name), 18)
                    set_image(icon_group, "/images/"+icon_name+".bmp")
                if i == 6 and view_live == 3:  # only if view3 is visable
                    b.selected = True
                        pass
                    print("Sound Button Pressed")
                    pyportal.play_file(soundDemo)
                    b.selected = False
oldblackcrow
by mikeysklar on Mon Feb 15, 2021 4:56 pm
Two thoughts.
1) comment out this line:
2) Change the label="meee" to label="" or even remove label=xxxx entirely:
mikeysklar
by oldblackcrow on Mon Feb 15, 2021 6:50 pm
mikeysklar wrote:Two thoughts.
Excellent! Thank you!
I just commented out that whole thing and it worked.
oldblackcrow
by oldblackcrow on Mon Feb 22, 2021 2:03 pm
I'm getting the hang of the User Interface, but I have another question... this is pertaining to integrating code into the User Interface.
I want to integrate two things: 1. the Garmin Lidar v4 example and the AdafruitIO examples in the respective tabs. I have no idea where to start on this aside from adding the libraries at the beginning of the sketch.
UI Code:
import time
import board
import displayio
import busio
import neopixel
except ValueError:
    adt = None
WHITE = 0xffffff
RED = 0xff0000
YELLOW = 0xffff00
GREEN = 0x00ff00
BLUE = 0x0000ff
PURPLE = 0xff00ff
BLACK = 0x000000
    num += 1
    if num <= max_val:
        return num
    else:
        return 1
# Set the Backlight
set_backlight(0.3)
# Touchscreen setup
# ------Rotate 0:
screen_width = 320
screen_height = 240
                                                   (5800, 57000)),
    try:
    except ValueError:
        pass
    try:
        time.sleep(0.1)
    except ValueError:
        pass
icon_group.x = 180
icon_group.y = 120
    if group:
        group.pop()
    if not filename:
    try:
    except TypeError:
                                          position=(0, 0))
TABS_X = 20
TABS_Y = 50
sensor_data.y = 120
# view3.append(sensor_data)
    new_text = ""
    test = ""
    for w in text:
        new_text += '\n'+w
        test += 'M\n'
BUTTON_HEIGHT = 20
BUTTON_WIDTH = 80
TAPS_HEIGHT = 30
TAPS_Y = 0
buttons = []
#buttons.append(button_view2)  # adding this button to the buttons group
# buttons.append(button_switch)  # adding this button to the buttons group
# buttons.append(button_2)  # adding this button to the buttons group
for b in buttons:
# buttons.append(button_icon)  # adding this button to the buttons group
    global view_live
    if what_view == 1:
        hideLayer(view2)
        hideLayer(view3)
        showLayer(view1)
        view_live = 1
        print("View1 On")
        # global icon
        hideLayer(view1)
        hideLayer(view3)
        showLayer(view2)
        view_live = 2
        print("View2 On")
    else:
        hideLayer(view1)
        hideLayer(view2)
        showLayer(view3)
        view_live = 3
        print("View3 On")
showLayer(view1)
hideLayer(view2)
hideLayer(view3)
view_live = 1
icon = 1
icon_name = "Ruby"
button_mode = 1
switch_state = 0
         "Gas Readings ### x ###.", 30)
         'Gas Readings from AdafruitIO'
text_box(feed2_label, TABS_Y, 'Garmin Distance Sensor', 18)
         "SENSOR DATA", 28)
while True:
    # sensor_data.text = 'Touch: {}\nLight: {}\n Temp: {:.0f}°F'.format(touch, light, tempF)
                    switch_view(1)
                        pass
                    switch_view(2)
                        pass
                    switch_view(3)
                        pass
                if i == 3:
                        switch_state = 1
                        b.label = "COLOR"
                        b.selected = False
                        pixel.fill(WHITE)
                        print("Swich ON")
                    else:
                        switch_state = 0
                        b.label = "OFF"
                        b.selected = True
                        pixel.fill(BLACK)
                        print("Swich OFF")
                    # for debounce
                        pass
                if i == 4:
                    b.selected = True
                        pixel.fill(RED)
                        pixel.fill(YELLOW)
                        pixel.fill(GREEN)
                        pixel.fill(BLUE)
                        pixel.fill(PURPLE)
                    switch_state = 1
                    # for debounce
                        pass
                    b.selected = False
                    b.selected = True
                        pass
                    if icon == 1:
                        icon_name = "Ruby"
                    elif icon == 2:
                        icon_name = "Gus"
                    elif icon == 3:
                    b.selected = False
                    b.selected = True
                        pass
                    b.selected = False
AdafruitIO code:
import time
import board
import busio
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
print("ESP32 SPI webclient test")
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
"""Use below for Most Boards"""
status_light = neopixel.NeoPixel(
    board.NEOPIXEL, 1, brightness=0.2
)  # Uncomment for Most Boards
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
counter = 0
while True:
    try:
        print("Posting data...", end="")
        data = counter
        feed = "test"
        payload = {"value": data}
        response = wifi.post(
            "https://io.adafruit.com/oldblackcrow/"
            + secrets["aio_username"]
            + "/feeds/"
            + feed
            + "/rx",
            json=payload,
            headers={"X-AIO-KEY": secrets["aio_key"]},
        print(response.json())
        response.close()
        counter = counter + 1
        print("OK")
    except (ValueError, RuntimeError) as e:
        print("Failed to get data, retrying\n", e)
        wifi.reset()
        continue
    response = None
    time.sleep(15)
Garmin Distance Sensor code:
import time
import board
import busio
import adafruit_lidarlite
# Create library object using our Bus I2C port
i2c = busio.I2C(board.SCL, board.SDA)
# Default configuration, with only i2c wires
sensor = adafruit_lidarlite.LIDARLite(i2c)
# Optionally, we can pass in a hardware reset pin, or custom config
# import digitalio
# reset = digitalio.DigitalInOut(board.D5)
# sensor = adafruit_lidarlite.LIDARLite(i2c, reset_pin=reset,
#    configuration=adafruit_lidarlite.CONFIG_MAXRANGE)
# If you want to reset, you can do so, note that it can take 10-20 seconds
# for the data to 'normalize' after a reset (and this isnt documented at all)
# sensor.reset()
while True:
    try:
        # We print tuples so you can plot with Mu Plotter
        print((sensor.distance,))
    except RuntimeError as e:
        # If we get a reading error, just print it and keep truckin'
        print(e)
    time.sleep(0.01)  # you can remove this for ultra-fast measurements!import time
Thanks again for any help on this!
oldblackcrow
by mikeysklar on Mon Feb 22, 2021 10:44 pm
This will take some time to integrate all three chunks of code.
I suggest makeing sure each piece is working correctly independently and slowly merging once chunk at a time. The Garmin distance sensor is really minimal so you should be able to integrate with the graphics with the least amount of time. The AIO is more involved so I would save that for last.
Just break it down in pieces line by line. You can do it.
mikeysklar
by oldblackcrow on Tue Feb 23, 2021 1:04 pm
Thanks... I am starting with the Garmin code and have been trying to integrate for a couple weeks. Unfortunately, every place I insert the code, I get unexplained errors and it won't boot. If I can get an idea of which part of the code I can insert the Garmin code, that would be helpful.
My starting point has been finding the block where the text I inserted "Garmin distance sensor". But no matter where I put it in that block, the PyPortal won't boot.
oldblackcrow
by oldblackcrow on Thu Feb 25, 2021 11:00 am
So, here's one of my attempts...
import time
import board
import displayio
import busio
import neopixel
import neopixel
except ValueError:
    sensor = None
sensor = adafruit_lidarlite.LIDARLite(i2c_bus)
WHITE = 0xffffff
RED = 0xff0000
YELLOW = 0xffff00
GREEN = 0x00ff00
BLUE = 0x0000ff
PURPLE = 0xff00ff
BLACK = 0x000000
    num += 1
    if num <= max_val:
        return num
    else:
        return 1
# Set the Backlight
set_backlight(0.3)
# Touchscreen setup
# ------Rotate 0:
screen_width = 320
screen_height = 240
                                                   (5800, 57000)),
    try:
    except ValueError:
        pass
    try:
        time.sleep(0.1)
    except ValueError:
        pass
icon_group.x = 180
icon_group.y = 120
    if group:
        group.pop()
    if not filename:
    try:
    except TypeError:
                                          position=(0, 0))
TABS_X = 20
TABS_Y = 50
sensor_data.y = 120
    new_text = ""
    test = ""
    for w in text:
        new_text += '\n'+w
        test += 'M\n'
BUTTON_HEIGHT = 20
BUTTON_WIDTH = 80
TAPS_HEIGHT = 30
TAPS_Y = 0
buttons = []
for b in buttons:
    global view_live
    if what_view == 1:
        hideLayer(view2)
        hideLayer(view3)
        showLayer(view1)
        view_live = 1
        print("View1 On")
        # global icon
        hideLayer(view1)
        hideLayer(view3)
        showLayer(view2)
        view_live = 2
        print("View2 On")
    else:
        hideLayer(view1)
        hideLayer(view2)
        showLayer(view3)
        view_live = 3
        print("View3 On")
showLayer(view1)
hideLayer(view2)
hideLayer(view3)
view_live = 1
icon = 1
icon_name = "Ruby"
button_mode = 1
switch_state = 0
         "SENSOR DATA", 28)
while True:
    try:
        print(e)
                    switch_view(1)
                        pass
                    switch_view(2)
                        pass
                    switch_view(3)
                        pass
                if i == 3:
                        switch_state = 1
                        b.label = "COLOR"
                        b.selected = False
                        pixel.fill(WHITE)
                        print("Swich ON")
                    else:
                        switch_state = 0
                        b.label = "OFF"
                        b.selected = True
                        pixel.fill(BLACK)
                        print("Swich OFF")
                    # for debounce
                        pass
                if i == 4:
                    b.selected = True
                        pixel.fill(RED)
                        pixel.fill(YELLOW)
                        pixel.fill(GREEN)
                        pixel.fill(BLUE)
                        pixel.fill(PURPLE)
                    switch_state = 1
                    # for debounce
                        pass
                    b.selected = False
                    b.selected = True
                        pass
                    if icon == 1:
                        icon_name = "Ruby"
                    elif icon == 2:
                        icon_name = "Gus"
                    elif icon == 3:
                    b.selected = False
                    b.selected = True
                        pass
                    b.selected = False
And I get this in the REPL:
File "code.py", line 29, in <module>
File "adafruit_lidarlite.py", line 94, in __init__
File "adafruit_bus_device/i2c_device.py", line 50, in __init__
File "adafruit_bus_device/i2c_device.py", line 166, in __probe_for_device
File "adafruit_bus_device/i2c_device.py", line 163, in __probe_for_device
ValueError: No I2C device at address: 0x62
This is all Greek to me... and I failed Greek in college.
Someone, please help!
oldblackcrow
by mikeysklar on Thu Feb 25, 2021 2:17 pm
Just using the LIDAR code without anything else is that working? Right now it is not finding your LIDAR on the i2c bus.
mikeysklar
by oldblackcrow on Thu Feb 25, 2021 3:21 pm
mikeysklar wrote:Just using the LIDAR code without anything else is that working? Right now it is not finding your LIDAR on the i2c bus.
Well, egg on my face... :-(
Just found out my LIDAR is non-functional. So, once I get the new one, I'll re-try the code and see what happens. Be about a week or so. Yes, I'm sad but hopeful.
oldblackcrow
by mikeysklar on Thu Feb 25, 2021 3:31 pm
Are you sure the LIDAR is a no go? You can post your wiring here for us to look at if there is any doubt.
mikeysklar
by oldblackcrow on Thu Feb 25, 2021 6:36 pm
mikeysklar wrote:Are you sure the LIDAR is a no go? You can post your wiring here for us to look at if there is any doubt.
Unfortunately, yes it is confirmed. Just finished a session with one of your colleagues to nail it down. I had fried the I2C channel by connecting the SCL and SDA to 5v instead of the required 3v. Oh, well.
oldblackcrow
by oldblackcrow on Sat Feb 27, 2021 9:38 am
As mentioned above, it has been determined that the LIDAR does not work (viewtopic.php?f=60&t=169496)... giving me a "measurement failure" which is why I didn't bother connecting it when running the UI example. So, this time, I did connect it and it does go through without the "I2C not found" error but instead gives me the following:
Warning: The group property is being deprecated. User code should be updated to add the Button directly to the Display or other Groups.
Measurement failure
File "code.py", line 333, in <module>
NameError: name 'touch' is not defined
Same code as above... but line 333 is:
That is confusing, because that seems to have nothing to do with what I plugged in and did not change any of this part of the code. This kind of stuff is where I really need help. I'm very slowly learning Python but I'm 54yo... so my brain doesn't process the way it used to. :-(
oldblackcrow
by mikeysklar on Sun Feb 28, 2021 2:23 pm
I see why the code has failed on 'touch' not being defined. The first line of your main loop uses:
The ts construction is in the backlight method, but you never call it and it is not properly indented to be called correctly. You need a tab for everything in a method to be included.
                                                   (5800, 57000)),
You should start with smaller code chunks and not take on such a complex '433' line python project for your first go around. It takes some practice.
mikeysklar
by oldblackcrow on Sun Feb 28, 2021 5:39 pm
mikeysklar wrote:You should start with smaller code chunks and not take on such a complex '433' line python project for your first go around. It takes some practice.
I would love that... but I'm super busy with my job and I'm trying to build a TOS Tricorder with this and the Clue. With the Clue, I have a friend who is really good at Arduino, but doesn't do Python... so, I'm trying to learn as I go. If my requests are outside of reason here, I totally understand if you think I should look elsewhere. I know you guys are busy too.
I truly appreciate any help I get on all this.
oldblackcrow
