PyPortal Pynt User Interface example
- oldblackcrow
Re: PyPortal Pynt User Interface example
Well, that worked... thank you very much! It's now booting properly. Now, I need to figure out how to display the data in the appropriate screen. I'll work on that this week.
- oldblackcrow
Ok... I think I got most of it... but I've hit a bit of a wall.
First, here is the working code in it's entirety:
So, in line 163 - 166, I changed the text Label to the sensor.distance and when it boots, it does, indeed, show me a distance.
However, I want that to be updated in real time just as the data reads out in the RPEL. Anyone know how to do that?
Thanks so much!
import time
import board
import microcontroller
import displayio
import busio
from digitalio import DigitalInOut
from analogio import AnalogIn
import neopixel
from adafruit_bitmap_font import bitmap_font
from adafruit_display_text.label import Label
from adafruit_button import Button
import adafruit_touchscreen
from adafruit_pyportal import PyPortal
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
import adafruit_lidarlite
# ------------- Inputs and Outputs Setup ------------- #
try: # attempt to init. the distance sensor
i2c_bus = busio.I2C(board.SCL, board.SDA)
except ValueError:
# Did not find ADT7410. Probably running on Titano or Pynt
sensor = None
# init. the distance sensor
sensor = adafruit_lidarlite.LIDARLite(i2c_bus)
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=1)
WHITE = 0xffffff
RED = 0xff0000
YELLOW = 0xffff00
GREEN = 0x00ff00
BLUE = 0x0000ff
PURPLE = 0xff00ff
BLACK = 0x000000
# ---------- Sound Effects ------------- #
soundDemo = '/sounds/sound.wav'
soundBeep = '/sounds/beep.wav'
soundTab = '/sounds/tab.wav'
# ------------- Other Helper Functions------------- #
# Helper for cycling through a number set of 1 to x.
def numberUP(num, max_val):
num += 1
if num <= max_val:
return num
else:
return 1
# ------------- Screen Setup ------------- #
pyportal = PyPortal()
display = board.DISPLAY
display.rotation = 0
# Backlight function
# Value between 0 and 1 where 0 is OFF, 0.5 is 50% and 1 is 100% brightness.
def set_backlight(val):
val = max(0, min(1.0, val))
board.DISPLAY.auto_brightness = False
board.DISPLAY.brightness = val
# Set the Backlight
set_backlight(0.3)
# Touchscreen setup
# ------Rotate 0:
screen_width = 320
screen_height = 240
ts = adafruit_touchscreen.Touchscreen(board.TOUCH_XL, board.TOUCH_XR,
board.TOUCH_YU, board.TOUCH_YD,
calibration=((5200, 59000),
(5800, 57000)),
size=(screen_width, screen_height))
# ------------- Display Groups ------------- #
splash = displayio.Group(max_size=15) # The Main Display Group
view1 = displayio.Group(max_size=15) # Group for View 1 objects
view2 = displayio.Group(max_size=15) # Group for View 2 objects
view3 = displayio.Group(max_size=15) # Group for View 3 objects
def hideLayer(hide_target):
try:
splash.remove(hide_target)
except ValueError:
pass
def showLayer(show_target):
try:
time.sleep(0.1)
splash.append(show_target)
except ValueError:
pass
# ------------- Setup for Images ------------- #
# Display an image until the loop starts
pyportal.set_background('/images/loading.bmp')
bg_group = displayio.Group(max_size=1)
splash.append(bg_group)
icon_group = displayio.Group(max_size=1)
icon_group.x = 180
icon_group.y = 120
icon_group.scale = 1
view2.append(icon_group)
# This will handel switching Images and Icons
def set_image(group, filename):
"""Set the image file for a given goup for display.
This is most useful for Icons or image slideshows.
:param group: The chosen group
:param filename: The filename of the chosen image
print("Set image to ", filename)
if group:
group.pop()
if not filename:
return # we're done, no icon desired
image_file = open(filename, "rb")
image = displayio.OnDiskBitmap(image_file)
try:
image_sprite = displayio.TileGrid(image, pixel_shader=displayio.ColorConverter())
except TypeError:
image_sprite = displayio.TileGrid(image, pixel_shader=displayio.ColorConverter(),
position=(0, 0))
group.append(image_sprite)
set_image(bg_group, "/images/BGimage.bmp")
# ---------- Text Boxes ------------- #
# Set the font and preload letters
font = bitmap_font.load_font("/fonts/Helvetica-Bold-16.bdf")
font.load_glyphs(b'abcdefghjiklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890- ()')
# Default Label styling:
TABS_X = 20
TABS_Y = 50
# Text Label Objects
feed1_label = Label(font, text="Text Wondow 1", color=0xE39300, max_glyphs=200)
feed1_label.x = TABS_X+25
feed1_label.y = TABS_Y
view1.append(feed1_label)
feed2_label = Label(font, text="Text Wondow 2", color=0xFFFFFF, max_glyphs=200)
feed2_label.x = TABS_X
feed2_label.y = TABS_Y
view2.append(feed2_label)
sensors_label = Label(font, text="Data View", color=0x03AD31, max_glyphs=200)
sensors_label.x = TABS_X
sensors_label.y = TABS_Y
view3.append(sensors_label)
sensor_data = Label(font, text=(sensor.distance,), color=0x03AD31, max_glyphs=100)
sensor_data.x = TABS_X+150
sensor_data.y = 120
# view3.append(sensor_data)
text_hight = Label(font, text="M", color=0x03AD31, max_glyphs=10)
# return a reformatted string with word wrapping using PyPortal.wrap_nicely
def text_box(target, top, string, max_chars):
text = pyportal.wrap_nicely(string, max_chars)
new_text = ""
test = ""
for w in text:
new_text += '\n'+w
test += 'M\n'
text_hight.text = test # Odd things happen without this
glyph_box = text_hight.bounding_box
target.text = "" # Odd things happen without this
target.y = int(glyph_box[3]/2)+top
target.text = new_text
# ---------- Display Buttons ------------- #
# Default button styling:
BUTTON_HEIGHT = 20
BUTTON_WIDTH = 80
# We want three buttons across the top of the screen
TAPS_HEIGHT = 30
TAPS_WIDTH = int(screen_width/3)
TAPS_Y = 0
# We want two big buttons at the bottom of the screen
BIG_BUTTON_HEIGHT = int(screen_height/5.2)
BIG_BUTTON_WIDTH = int(screen_width/2)
BIG_BUTTON_Y = int(screen_height-BIG_BUTTON_HEIGHT)
# This group will make it easy for us to read a button press later.
buttons = []
# Main User Interface Buttons
button_view1 = Button(x=0, y=0,
width=TAPS_WIDTH, height=TAPS_HEIGHT,
label="Distance", label_font=font, label_color=0xff7e00,
fill_color=0x5c5b5c, outline_color=0x767676,
selected_fill=0x1a1a1a, selected_outline=0x2e2e2e,
selected_label=0x525252)
buttons.append(button_view1) # adding this button to the buttons group
button_view2 = Button(x=TAPS_WIDTH, y=0,
label="IR Camera", label_font=font, label_color=0xff7e00,
#buttons.append(button_view2) # adding this button to the buttons group
button_view3 = Button(x=TAPS_WIDTH*2, y=0,
label="Gas Sensor", label_font=font, label_color=0xff7e00,
buttons.append(button_view3) # adding this button to the buttons group
button_switch = Button(x=0, y=BIG_BUTTON_Y,
width=BIG_BUTTON_WIDTH, height=BIG_BUTTON_HEIGHT,
label="Switch", label_font=font, label_color=0xff7e00,
# buttons.append(button_switch) # adding this button to the buttons group
button_2 = Button(x=BIG_BUTTON_WIDTH, y=BIG_BUTTON_Y,
label="Light ON/OFF", label_font=font, label_color=0xff7e00,
# buttons.append(button_2) # adding this button to the buttons group
# Add all of the main buttons to the splash Group
for b in buttons:
splash.append(b.group)
# Make a button to change the icon image on view2
button_icon = Button(x=150, y=60,
width=BUTTON_WIDTH, height=BUTTON_HEIGHT,
label="Icon", label_font=font, label_color=0xffffff,
fill_color=0x8900ff, outline_color=0xbc55fd,
selected_fill=0x5a5a5a, selected_outline=0xff6600,
selected_label=0x525252, style=Button.ROUNDRECT)
# buttons.append(button_icon) # adding this button to the buttons group
#pylint: disable=global-statement
def switch_view(what_view):
global view_live
if what_view == 1:
hideLayer(view2)
hideLayer(view3)
button_view1.selected = True
button_view2.selected = False
button_view3.selected = False
showLayer(view1)
view_live = 1
print("View1 On")
elif what_view == 2:
# global icon
hideLayer(view1)
hideLayer(view3)
button_view1.selected = False
button_view2.selected = True
button_view3.selected = True
showLayer(view2)
view_live = 2
print("View2 On")
else:
hideLayer(view1)
hideLayer(view2)
showLayer(view3)
view_live = 3
print("View3 On")
#pylint: enable=global-statement
# Set veriables and startup states
showLayer(view1)
hideLayer(view2)
hideLayer(view3)
view_live = 1
icon = 1
icon_name = "Ruby"
button_mode = 1
switch_state = 0
button_switch.label = "OFF"
button_switch.selected = True
# Update out Labels with display text.
text_box(feed1_label, TABS_Y,
"Gas Readings ### x ###.", 30)
'Gas Readings from AdafruitIO'
.format(feed1_label.bounding_box[2], feed1_label.bounding_box[3]*2), 30)
text_box(feed2_label, TABS_Y, sensor_data.text, 18)
text_box(sensors_label, TABS_Y,
"SENSOR DATA", 28 )
board.DISPLAY.show(splash)
# ------------- Code Loop ------------- #
while True:
touch = ts.touch_point
try:
# We print tuples so you can plot with Mu Plotter
print((sensor.distance,))
except RuntimeError as e:
# If we get a reading error, just print it and keep truckin'
print(e)
time.sleep(1.00) # you can remove this for ultra-fast measurements!
# ------------- Handle Button Press Detection ------------- #
if touch: # Only do this if the screen is touched
# loop with buttons using enumerate() to number each button group as i
for i, b in enumerate(buttons):
if b.contains(touch): # Test each button to see if it was pressed
print('button%d pressed' % i)
if i == 0 and view_live != 1: # only if view1 is visable
pyportal.play_file(soundTab)
switch_view(1)
while ts.touch_point:
pass
if i == 1 and view_live != 2: # only if view2 is visable
switch_view(2)
pass
if i == 2 and view_live != 3: # only if view3 is visable
switch_view(3)
pass
if i == 3:
pyportal.play_file(soundBeep)
# Toggle switch button type
if switch_state == 0:
switch_state = 1
b.label = "COLOR"
b.selected = False
pixel.fill(WHITE)
print("Swich ON")
else:
switch_state = 0
b.label = "OFF"
b.selected = True
pixel.fill(BLACK)
print("Swich OFF")
# for debounce
pass
print("Swich Pressed")
if i == 4:
# Momentary button type
b.selected = True
print('Button Pressed')
button_mode = numberUP(button_mode, 5)
if button_mode == 1:
pixel.fill(RED)
elif button_mode == 2:
pixel.fill(YELLOW)
elif button_mode == 3:
pixel.fill(GREEN)
elif button_mode == 4:
pixel.fill(BLUE)
elif button_mode == 5:
pixel.fill(PURPLE)
switch_state = 1
button_switch.label = "COLOR"
button_switch.selected = False
# for debounce
pass
print("Button released")
b.selected = False
if i == 5 and view_live == 2: # only if view2 is visable
b.selected = True
pass
print("Icon Button Pressed")
icon = numberUP(icon, 3)
if icon == 1:
icon_name = "Ruby"
elif icon == 2:
icon_name = "Gus"
elif icon == 3:
icon_name = "Billie"
b.selected = False
"Image".format(icon_name), 18)
set_image(icon_group, "/images/"+icon_name+".bmp")
if i == 6 and view_live == 3: # only if view3 is visable
b.selected = True
pass
print("Sound Button Pressed")
pyportal.play_file(soundDemo)
b.selected = False
sensor_data.y = 120
Thanks so much!
- mikeysklar
Your code is too scattered to follow. The brute force insertion of multiple projects and incorrect indentation make for chaos.
You'll need to dumb it down to a few lines as possible.
Take a look at the other PyPortal examples and get your sensor input going to the display with the minimal amount of code.
https://learn.adafruit.com/search?q=pyportal
- oldblackcrow
mikeysklar wrote:Your code is too scattered to follow. The brute force insertion of multiple projects and incorrect indentation make for chaos.
I appreciate the link... But if the code is too scattered, then that would be the one who wrote the GUI ..
It is a PyPortal example.
I'm a newbie, but all I did was comment out a few blocks and inserted the Garmin LIDAR code in one place, so idk what you mean by "scattered".
- oldblackcrow
This evening, I'll be comparing the original code to the changes I made to see if I messed up the formatting and/or errors I may have made.
Maybe some of the formatting problems are due to the copy/paste? Most of the time I use Notepad++ for that but I may have used Mu these last few times.
- mikeysklar
The issue here is this is too much code to work with at once. You need to walk before you can run. Simplify to getting sensor data and basic output on the TFT before trying to merge it into a massive graphical display code base.
- oldblackcrow
mikeysklar wrote:The issue here is this is too much code to work with at once. You need to walk before you can run. Simplify to getting sensor data and basic output on the TFT before trying to merge it into a massive graphical display code base.
Ah... That part is already done. The LIDAR works, I get data in a continuous stream with no issues. The problem I'm having here is that I just get the first measurement from the LIDAR on the GUI screen (I'll provide a pic later today). I want to see the continuous stream on the GUI screen.
When I replace the "sensor_data = Label(font, text=(sensor.distance,)" block with a "while True" loop, the Garmin runs with no issues in the RPEL and the Portal boots up but only shows the splash screen. My guess is that the loop is running too early in the process so it just holds at that point. I get no error messages, it just doesn't bring up the GUI.
Like I said, I'm close, just need to work out this one thing... Then I'll move on to the other integration. I really am trying to just change as little as possible and when something doesn't work, I just undo my change to revert back to the original code.
- oldblackcrow
[/quote]oldblackcrow wrote:I'll provide a pic later today.
I'm traveling this week and forgot my LIDAR... :-(
But will do so this weekend.
- oldblackcrow
Looking through the code, I *think* I found the problem. I can't test it until Saturday because if I don't have the LIDAR plugged in, the code won't run.
So, I found that I had commented out line 165... probably just forgot to change it back at one point in testing.
I'm thinking that if I uncomment that line, the data should be streaming. In the original code, it was meant to be a streaming data flow. Only, I think it was using temperature or light.
Man, I hope that's it... I hate having to wait that long to test it. Grrrr! At least it's a binary and shouldn't cause any errors. At least check my logic, please. :-D
161 sensor_data = Label(font, text=(sensor.distance,), color=0x03AD31,
162 max_glyphs=100)
163 sensor_data.x = TABS_X+150
164 sensor_data.y = 120#
165 # view3.append(sensor_data)`
- oldblackcrow
Sorry, copy/paste errors... Reads as such
162 sensor_data = Label(font, text=(sensor.distance,), color=0x03AD31, max_glyphs=100)
- oldblackcrow
And I just realized that I inadvertently deleted the magic line that allows for the data to stream.
I'm working it out... My way of doing it is pretty messed up, but that's how I learn.
sensor_data.text = 'Touch: {}\nLight: {}\n Temp: {:.0f}°F'.format(touch, light, tempF)
- oldblackcrow
Okay, I figured it out!
In the Code Loop section, I just changed that to the following:
It was easier than I was making it out to be. But hey, my methods may be brute force, but that is how I learn.
Now on to the Adafruit IO integration. I anticipate a slightly easier path since I'm wrapping my head around how this code works. Well, I say that, but we'll see. :-)
Here is the code in its entirety:
while True:
try:
print(e)
time.sleep(0.01) # you can remove this for ultra-fast measurements!
sensor_data.text = '{} cm'.format(sensor.distance)
import time
import board
import displayio
import busio
import neopixel
import adafruit_adt7410
try: # attempt to init. the temperature sensor
adt = adafruit_adt7410.ADT7410(i2c_bus, address=0x48)
adt.high_resolution = True
except ValueError:
adt = None
# init. the light sensor
light_sensor = AnalogIn(board.LIGHT)
WHITE = 0xffffff
RED = 0xff0000
YELLOW = 0xffff00
GREEN = 0x00ff00
BLUE = 0x0000ff
PURPLE = 0xff00ff
BLACK = 0x000000
num += 1
if num <= max_val:
return num
else:
return 1
# Set the Backlight
set_backlight(0.3)
# Touchscreen setup
# -------Rotate 0:
screen_width = 320
screen_height = 240
board.TOUCH_YD, board.TOUCH_YU,
calibration=((5200, 59000), (5800, 57000)),
size=(320, 240))
try:
except ValueError:
pass
try:
time.sleep(0.1)
except ValueError:
pass
icon_group.x = 180
icon_group.y = 120
if group:
group.pop()
if not filename:
try:
except TypeError:
position=(0, 0))
TABS_X = 5
TABS_Y = 50
sensor_data = Label(font, text="Data View", color=0x03AD31, max_glyphs=100)
sensor_data.x = TABS_X+50
sensor_data.y = 100
new_text = ""
test = ""
for w in text:
new_text += '\n'+w
test += 'M\n'
BUTTON_HEIGHT = 40
BUTTON_WIDTH = 80
TAPS_HEIGHT = 40
TAPS_Y = 0
BIG_BUTTON_HEIGHT = int(screen_height/3.2)
buttons = []
label="View1", label_font=font, label_color=0xff7e00,
label="View2", label_font=font, label_color=0xff7e00,
label="DISTANCE", label_font=font, label_color=0xff7e00,
#buttons.append(button_switch) # adding this button to the buttons group
label="Button", label_font=font, label_color=0xff7e00,
#buttons.append(button_2) # adding this button to the buttons group
for b in buttons:
splash.append(b)
#buttons.append(button_icon) # adding this button to the buttons group
# Add this button to view2 Group
view2.append(button_icon)
# Make a button to play a sound on view2
button_sound = Button(x=150, y=170,
label="Sound", label_font=font, label_color=0xffffff,
#buttons.append(button_sound) # adding this button to the buttons group
#view3.append(button_sound)
global view_live
if what_view == 1:
hideLayer(view2)
hideLayer(view3)
showLayer(view1)
view_live = 1
print("View1 On")
# global icon
hideLayer(view1)
hideLayer(view3)
showLayer(view2)
view_live = 2
print("View2 On")
else:
hideLayer(view1)
hideLayer(view2)
showLayer(view3)
view_live = 3
print("View3 On")
showLayer(view1)
hideLayer(view2)
hideLayer(view3)
view_live = 1
icon = 1
icon_name = "Ruby"
button_mode = 1
switch_state = 0
"The text on this screen is wrapped so that all of it fits nicely into a \
text box that is ### x ###.", 30)
'The text on this screen is wrapped so that all of it fits nicely into a \
text box that is {} x {}.'
text_box(feed2_label, TABS_Y, 'Tap on the Icon button to meet a new friend.', 18)
"", 28)
while True:
try:
print(e)
switch_view(1)
pass
switch_view(2)
pass
switch_view(3)
pass
if i == 3:
switch_state = 1
b.label = "ON"
b.selected = False
pixel.fill(WHITE)
print("Swich ON")
else:
switch_state = 0
b.label = "OFF"
b.selected = True
pixel.fill(BLACK)
print("Swich OFF")
# for debounce
pass
if i == 4:
b.selected = True
pixel.fill(RED)
pixel.fill(YELLOW)
pixel.fill(GREEN)
pixel.fill(BLUE)
pixel.fill(PURPLE)
switch_state = 1
button_switch.label = "ON"
# for debounce
pass
b.selected = False
b.selected = True
pass
if icon == 1:
icon_name = "Ruby"
elif icon == 2:
icon_name = "Gus"
elif icon == 3:
b.selected = False
"Every time you tap the Icon button the icon image will \
change. Say hi to {}!".format(icon_name), 18)
b.selected = True
pass
b.selected = False
- oldblackcrow
- oldblackcrow
Alrighty then... I am using the following code to integrate with with User Interface example. It works on its own and I am slowly inserting lines of code until I hit an error.
Here's the AdafruitIO example in full (working):
And here is the Original UI code (working):
I've confirmed that the import library files are no issue.
Then I inserted the try statement from the AdafruitIO below the try statement into the UI code... so, it looks like this:
That works.
However. when I paste in the following lines:
I get the following error:
File "code.py", line 67, in <module>
File "adafruit_pyportal/__init__.py", line 152, in __init__
File "adafruit_pyportal/network.py", line 90, in __init__
File "adafruit_pyportal/wifi.py", line 67, in __init__
ValueError: ESP_BUSY in use
And if I add the lines (I did this in case those previous lines refer to the following):
File "code.py", line 70, in <module>
File "adafruit_pyportal/__init__.py", line 139, in __init__
ValueError: SCK in use
So, I am guessing that the ESP_BUSY is reffering to the screen being used... but that is just a guess on my part.
Can someone confirm this and is there a solution to get around this? Thanks!
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# adafruit_circuitpython_adafruitio usage with an esp32spi_socket
from random import randint
import board
import busio
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
import adafruit_requests as requests
from adafruit_io.adafruit_io import IO_HTTP, AdafruitIO_RequestError
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
print("Connecting to AP...")
while not esp.is_connected:
try:
esp.connect_AP(secrets["ssid"], secrets["password"])
print("could not connect to AP, retrying: ", e)
continue
print("Connected to", str(esp.ssid, "utf-8"), "\tRSSI:", esp.rssi)
socket.set_interface(esp)
requests.set_socket(socket, esp)
aio_username = secrets["aio_username"]
aio_key = secrets["aio_key"]
# Initialize an Adafruit IO HTTP API object
io = IO_HTTP(aio_username, aio_key, requests)
while True:
try:
# Get the 'gas' feed from Adafruit IO
gas_feed = io.get_feed("rx")
# Retrieve data value from the feed
print("Retrieving data from gas feed...")
receive_data = io.receive_data(gas_feed["key"])
print("Data from gas feed: ", receive_data["value"])
except AdafruitIO_RequestError:
# If no 'gas' feed exists, create one
gas_feed = io.create_new_feed("rx")
import time
import board
import displayio
import busio
import neopixel
except ValueError:
adt = None
WHITE = 0xffffff
RED = 0xff0000
YELLOW = 0xffff00
GREEN = 0x00ff00
BLUE = 0x0000ff
PURPLE = 0xff00ff
BLACK = 0x000000
num += 1
if num <= max_val:
return num
else:
return 1
# Set the Backlight
set_backlight(0.3)
# Touchscreen setup
# ------Rotate 0:
screen_width = 320
screen_height = 240
size=(320, 240))
try:
except ValueError:
pass
try:
time.sleep(0.1)
except ValueError:
pass
icon_group.x = 180
icon_group.y = 120
if group:
group.pop()
if not filename:
try:
except TypeError:
position=(0, 0))
TABS_X = 5
TABS_Y = 50
sensor_data.y = 170
new_text = ""
test = ""
for w in text:
new_text += '\n'+w
test += 'M\n'
BUTTON_HEIGHT = 40
BUTTON_WIDTH = 80
TAPS_HEIGHT = 40
TAPS_Y = 0
buttons = []
label="View3", label_font=font, label_color=0xff7e00,
for b in buttons:
splash.append(b)
global view_live
if what_view == 1:
hideLayer(view2)
hideLayer(view3)
showLayer(view1)
view_live = 1
print("View1 On")
# global icon
hideLayer(view1)
hideLayer(view3)
showLayer(view2)
view_live = 2
print("View2 On")
else:
hideLayer(view1)
hideLayer(view2)
showLayer(view3)
view_live = 3
print("View3 On")
showLayer(view1)
hideLayer(view2)
hideLayer(view3)
view_live = 1
icon = 1
icon_name = "Ruby"
button_mode = 1
switch_state = 0
"This screen can display sensor readings and tap Sound to play a WAV file.", 28)
while True:
light = light_sensor.value
if adt: # Only if we have the temperature sensor
tempC = adt.temperature
else: # No temperature sensor
tempC = microcontroller.cpu.temperature
tempF = tempC * 1.8 + 32
switch_view(1)
pass
switch_view(2)
pass
switch_view(3)
pass
if i == 3:
switch_state = 1
b.label = "ON"
b.selected = False
pixel.fill(WHITE)
print("Swich ON")
else:
switch_state = 0
b.label = "OFF"
b.selected = True
pixel.fill(BLACK)
print("Swich OFF")
# for debounce
pass
if i == 4:
b.selected = True
pixel.fill(RED)
pixel.fill(YELLOW)
pixel.fill(GREEN)
pixel.fill(BLUE)
pixel.fill(PURPLE)
switch_state = 1
# for debounce
pass
b.selected = False
b.selected = True
pass
if icon == 1:
icon_name = "Ruby"
elif icon == 2:
icon_name = "Gus"
elif icon == 3:
b.selected = False
b.selected = True
pass
b.selected = False
try:
except ImportError:
raise
except ValueError:
adt = None
try:
except ImportError:
raise
- mikeysklar
The SPI code with ESP32 pins is already defined in your AIO code example. The error you are getting about ESP_BUSY in use is due to you already having that exact code in place.
