Resizing Icons and Images for PyPortal Titano
by MattPackwood on Wed Feb 17, 2021 2:55 pm
I am looking at using a PyPortal Titano and need to resize some images/icons that are used with the "Regular" PyPortal, is there a good tool to do this (I have tried using the Photos app on the Mac with no success), does anyone have any suggestions?
Matt
MattPackwood
Re: Resizing Icons and Images for PyPortal Titano
by mikeysklar on Thu Feb 18, 2021 2:05 pm
Hi Matt,
Are you trying to convert existing image files (JPG/BMP/etc.) to another the Titano screen resolution which is 320x480?
I often use the MacOS Preview App for that kind of change.
Preview --> Tools --> Adjust Size
(then type in your Titano 320x480) resoltion
mikeysklar
by MattPackwood on Fri Feb 19, 2021 9:45 pm
I tried that on the various files in the Weather Demo but if I modify them they just "become blank".
https://learn.adafruit.com/pyportal-wea ... cuitpython
Clearly, I am missing something...
MattPackwood
by mikeysklar on Mon Feb 22, 2021 9:10 pm
Matt,
If you select one of the original images on your mac through the finder and hit CMD-I you should see the GetInfo screen that has a few more details about the image type and resolution. Maybe we can compare the original format information with the ones you have converted and find a clue about what the difference is between the two images that could be causing an issue on the Titano displaying?
mikeysklar
by MattPackwood on Tue Feb 23, 2021 8:24 pm
Screen Shot 2021-02-23 at 7.21.18 PM.png (362.43 KiB) Viewed 41 times
Here you go, I "adjusted" the file 04n.bmp, the resized version is o4n copy.bmp,
The original works (but is small on the Titano screen) the resized version will not display.
Matt
MattPackwood
by mikeysklar on Wed Feb 24, 2021 3:44 pm
Matt,
I have feeling you just have the resolution reversed.
The image you are starting with is 320x240 and the image you are converting to is 480x320. However, when I lookup the Pyportal Titano it look like the resolution is 320x480. Can you try resizing again and flipping the width/height you had been using?
Titano has a bigger 3.5″ diagonal 320 x 480 color TFT
mikeysklar
