I trying to retrieve some text from the follow website.
https://ssd.jpl.nasa.gov/horizons_batch.cgi?batch=1&TABLE_TYPE=OBSERVER&QUANTITIES=%274%27&COMMAND=%224%22&SOLAR_ELONG=%220%2C180%22&LHA_CUTOFF=0&CSV_FORMAT=YES&CAL_FORMAT=BOTH&ANG_FORMAT=DEG&APPARENT=AIRLESS&REF_SYSTEM=J2000&EXTRA_PREC=NO&CENTER=coord%40399&COORD_TYPE=GEODETIC&SITE_COORD=%27-63.131100%2C46.238200%2C0.060000%27
I set up the the following Json_path = [0, 'text']
and issuing command : magtag.fetch()
gets the following errors
- Code: Select all | TOGGLE FULL SIZE
Retrieving data...Traceback (most recent call last):
File "code.py", line 27, in <module>
File "magtag.py", line 355, in fetch
File "adafruit_magtag/network.py", line 464, in fetch_data
File "adafruit_magtag/network.py", line 436, in fetch
File "adafruit_requests.py", line 594, in get
File "adafruit_requests.py", line 551, in request
File "adafruit_requests.py", line 546, in request
AttributeError: 'NoneType' object has no attribute 'split'
Any ideas how I can work around the problem?
Is there a way I can use the fetch command just to download raw bytes
Thanks for the help.
Rod
