ESP32 tutorial change suggestion
by Systembolaget on Sat Feb 20, 2021 7:24 am
Hej Brent,
the tutorial page https://learn.adafruit.com/adafruit-airlift-featherwing-esp32-wifi-co-processor-featherwing/upgrade-external-esp32-airlift-firmware says Make sure to solder all three of these pads together. You will not be able to upload firmware to your ESP32 if they are not connected. This is somewhat misleading, because many students literally solder all three pads together (so that all three pads are interconnected!) instead of bridging each pad with solder. Maybe that should be changed?
Systembolaget
Re: ESP32 tutorial change suggestion
by brubell on Mon Feb 22, 2021 10:50 am
Hi, I've changed the text to reflect that each of the pads should be soldered together. Does that clear it up?
brubell
by Systembolaget on Mon Feb 22, 2021 12:38 pm
Definitely, thanks!
Systembolaget
