Loops for Everything ?
by hitsware2 on Thu Mar 11, 2021 5:02 pm
I would like to simply set a frequency and pulsewidth .
All the PWM examples use a loop to control one and / or the other .
Is there a simpler way to output a constant PWM signal ,
without the ' while True : ' ?
"""CircuitPython Essentials: PWM with Fixed Frequency example."""
import time
import board
import pwmio
# LED setup for most CircuitPython boards:
led = pwmio.PWMOut(board.D13, frequency=5000, duty_cycle=0)
# LED setup for QT Py M0:
# led = pwmio.PWMOut(board.SCK, frequency=5000, duty_cycle=0)
while True:
    for i in range(100):
        # PWM LED up and down
        if i < 50:
            led.duty_cycle = int(i * 2 * 65535 / 100)  # Up
        else:
            led.duty_cycle = 65535 - int((i - 50) * 2 * 65535 / 100)  # Down
        time.sleep(0.01)
hitsware2
Re: Loops for Everything ?
by dastels on Thu Mar 11, 2021 6:51 pm
The duty cycle is changed in the loop in that example only to fade the brightness of the LED up & down over time. Once you set the frequency and/or duty cycle of a PWM it keeps going until you change it.
dastels
by hitsware2 on Thu Mar 11, 2021 7:07 pm
How do I set it without a loop ?
No output with this :
import board; import pwmio
pwmio.PWMOut(board.A2, duty_cycle=30000, frequency=1000)
hitsware2
by dastels on Thu Mar 11, 2021 8:28 pm
That looks right.
Make sure that A2 is a PWM capable pin.
dastels
by hitsware2 on Thu Mar 11, 2021 9:27 pm
With this there is output on A2
n = pwmio.PWMOut(board.A2, duty_cycle=30000, frequency=1000)
while True:
  n.duty_cycle = 30000
hitsware2
by dastels on Thu Mar 11, 2021 9:42 pm
Ah! What if you try:
import board
import pwmio
while True:
  pass
The PWM is most likely shut down when the program ends.
dastels
by hitsware2 on Thu Mar 11, 2021 10:26 pm
[code}
while True: pass
[/code]
Thank You !
I ' ll dance at Your wedding : )
hitsware2
