Trying to convert my C++ to Micropython and I have questions
by chipnod2020 on Thu Mar 11, 2021 6:06 pm
#define NAV_LED_PIN 2
// Navigation Lights
#define NAV_LED_ON 150
#define NAV_LED_OFF 1000
unsigned long NAV_msLast;  // last time the LED changed state
boolean NAV_ledState;    // current LED state
void setup(void)
  pinMode(NAV_LED_PIN, OUTPUT);
void loop(void)
  // Normal Stuff
  now = millis();
  // MUST call the button.loop() functions within the loop()
  buttonPC.loop();
  buttonQT.loop();
  buttonPT.loop();
  buttonWP.loop();
  buttonPH.loop();
  ledPC.loop();
  ledPH.loop();
  if (now - NAV_msLast > (NAV_ledState ? NAV_LED_ON : NAV_LED_OFF)) {
    digitalWrite(NAV_LED_PIN, NAV_ledState = !NAV_ledState);
    NAV_msLast = now;
Can someone give me a pointer on the proper syntax of the IF statement? The goal is to have an LED on for 500 ms, then off for 1000 ms.
This is my very broken Python code that is not complete.
from machine import Pin
import time
led = Pin(25, Pin.OUT)
on = 500
off = 1000
led_state = 0
now = time.ticks_ms()
last = 0
while True:
    if ( now - last > ON*OFF BROKEN):
        led.toggle()
        last = time.ticks_ms()
chipnod2020
Re: Trying to convert my C++ to Micropython and I have quest
by dastels on Thu Mar 11, 2021 6:24 pm
The equivalent of
condition ? true_value : false_value
is
true_value if condition else false_value
So your if would look something like:
if (now - last > (on if led_state else off)):
dastels
by chipnod2020 on Mon Mar 15, 2021 2:09 pm
Thanks Dave!
So I've reworked it this far:
import utime
from machine import Pin, PWM
#Global Variables
now = 0    #time from millis()
#Pin Definitions
NAV_LED_PIN = 4
#Navigation Lights
NAV_LED_ON = 150
NAV_LED_OFF = 1000
NAV_msLast = 0  # last time the LED changed state
NAV_ledState = False    # current LED state
def main():
    now = utime.time_ms()
    #Navigation Lights
    if(NAV_ledState):
        if(now - NAV_msLast > NAV_LED_ON):
            NAV_LED_PIN.toggle()
            NAV_msLast = now
    else:
        if(now - NAV_msLast > NAV_LED_OFF):
            NAV_msLast = now
main()
Thonny is complaining about NAV_ledState = !NAV_ledState
>>> %Run -c $EDITOR_CONTENT
  File "<stdin>", line 21
SyntaxError: invalid syntax
chipnod2020
by dastels on Mon Mar 15, 2021 4:44 pm
Use not, not !
dastels
by chipnod2020 on Mon Mar 15, 2021 6:20 pm
Dave, how do you tolerate people?!? ;-) Thank you so much for pointing out my Noobery!!
So I have modified the code once again to this.
import utime
def main():
    #Pin Definition
    NAV_LED_PIN = Pin(2, Pin.OUT)
    #Navigation Lights
    NAV_LED_ON = 150
    NAV_LED_OFF = 1000
    NAV_msLast = 0
    now = utime.ticks_ms()
    if(NAV_ledState):
            NAV_ledState = not NAV_ledState
            NAV_msLast = now
    else:
            NAV_msLast = now
main()
I have a 470 ohm resistor on GPIO pin 2 and connecting it to ground of the Pico. If I do ye olde "led.on()", it works just fine. But the code does not turn up my LED. I still must be basic and missing something as I thought toggle would work.
chipnod2020
by dastels on Mon Mar 15, 2021 6:34 pm
I'm probably missing some of the finer points since it's micropython and not circuitpython.
You need a loop around that if statement (and including the assignment to now), yes?
dastels
by chipnod2020 on Tue Mar 16, 2021 8:57 am
very simple solution...
I placed a while loop above the section with timers and it works great now.
import utime
def main():
    #Pin Definition
    #Navigation Lights
    NAV_LED_ON = 150
    NAV_LED_OFF = 1000
    NAV_msLast = 0
    while(1):
      if(NAV_ledState):
            NAV_msLast = now
      else:
            NAV_msLast = now
main()
Thanks for the sounding board Dave!!! I really appreciate your help!
chipnod2020
by dastels on Tue Mar 16, 2021 9:14 am
My pleasure.
dastels
